What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 47, 48, 49 ... 57, 58, 59  Next
blurredman
PostPosted: 19:40 - 12 May 2024    Post subject: Reply with quote
Sometimes it just seems easier to remove brake fluid from the reservoir and put new stuff in once a year and never 'bleed' it.
Islander
PostPosted: 20:25 - 12 May 2024    Post subject: Reply with quote
I replaced the failing hall effect sensor on the R850R. I made an indicator box to allow me to set the timing (simple device and simple procedure) and replaced the alternator belt as I had to remove the old one to get the crank pulley off anyway.
I went to turn the engine over to make sure the belt was centred and discovered that I had no power at all. Checked the battery, all good.
Checked for power on the fuses, nothing. Checked for power going to the ignition switch, all good. Checked for power on the other side of the switch, sod all.
Arse. The ignition switch has decided to give up the ghost. Replacement switch module ordered £124...
UncleFester
PostPosted: 04:57 - 13 May 2024    Post subject: Reply with quote
This has separate front and rear reservoirs- you empty that with a syringe, fill it with new then 'bleed' the brakes pulling new fluid through. As soon as it's clear from the bleed nipple you top up the reservoirs and put the cap back on etc.
Honestly the easiest 30 minutes of work I've ever done. So easy with a syringe, a 2m length of 5.5mm ID tubing, no need for a vacuum kit.
2017 Z1000SX
Serendipity
PostPosted: 08:45 - 13 May 2024    Post subject: Reply with quote
I had a job that was never going to go well. Removing the blowing exhaust headers from my old 2007 CBF1000.
The bike has now done 122,000 miles and 16 winters with the original exhaust never being disturbed. I could see that 2 of the nuts were visibly eaten away by corrosion, but the rest looked ok. However I was expecting everything to be totally seized.
I cleaned them up as best as I could reach and treated them to a week of daily Plusgas soaking.
The nuts to the furthest left and right both moved, but they've lived their lives with the least spray from the front wheel. The rest of the nuts were solid.
The results so far? Out of the 8 I managed to get 4 to come out cleanly, although it was the studs that turned out. All the nuts are firmly welded to the studs with corrosion. 2 snapped studs and the 2 heavily corroded nuts just crumbled.
So, next step is to try to clear the remains of the 2 crumbled nuts from the studs so I can get the headers off. Then I'll waste time and effort trying to turn out the 4 stuck studs before I eventually lose patience, cut them off, drill them out and helicoil them. Laughing
I've got new(ish) headers with only 25k miles to fit.
2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
UncleFester
PostPosted: 05:06 - 16 May 2024    Post subject: Reply with quote
Ugh - feel your pain with ^^^
My job today is resetting the rear wheel alignment cams, cleaning them and the swingarm locating sockets and then doing the chain tension. That and an oil and filter change - finally going to get her C90 off MY bike lift and do it at a height my back won't sulk at me for.
2017 Z1000SX
UncleFester
2017 Z1000SX
UncleFester
PostPosted: 16:25 - 18 May 2024    Post subject: Reply with quote
Note to self .... the reason your bike isn't showing anything on the glass level is because you bought a 4 litre tub not the usual 5 litre size you get for the car you dick Brick Wall Brick Wall Brick Wall
Spent a good 10 minutes wondering why it wasn't showing up even though i'd emptied down to just above the 1L remaining mark ( it takes 3.8ish L to fill) before i realised i'd only stuck 3L in the bloody thing. Mr. Green
2017 Z1000SX
PostPosted: 13:38 - 19 May 2024    Post subject: Reply with quote
Polished it, filled it with fuel and sold it.
Dean, you're a lucky man.
https://pbs.twimg.com/media/GN8Mph2XcAAqHAk?format=jpg&name=4096x4096
Last edited by Howling TerrorOutOfOffice on 19:10 - 29 May 2024; edited 1 time in total
Kawasaki Jimbo
PostPosted: 15:13 - 19 May 2024    Post subject: Reply with quote
The ZX6R was running on 3 cylinders and my £15 infrared laser temperature gun said downpipe 3 was at 80 degrees C compared to 200 in its neighbours. The spark plug looked like new (it is, quite) but there was some crud around the base which I’m hoping was the problem. Tank back on, noting (not for the first time) that the fuel lines are original and not necessarily ethanol-proof but meh! they look alright. The fuel pump doesn’t operate until you press the starter, and when I did there was fuel splashing onto the floor. Split S-hose between fuel tap and in-line filter! I’ve just bought some 7.8mm ID hose from Halfords (OE is supposedly 8mm) but it will need some force (in a confined space) to get it on. Today I gave up.
I also noted that my new lithium battery was ‘dead’ (2.4v). It’s the bike’s mysterious parasitic drain again, but worse than ever. I think it might be the ignition barrel. I can take the key out with the engine running. My Noco charger recovered the battery though.
Islander
PostPosted: 18:35 - 19 May 2024    Post subject: Reply with quote
I fitted the new switch module to the ignition switch. It should be a simple job to unbolt the ignition switch, undo a grub screw, remove the knackered switch module and replace it with the new one.
Should be. Except BMW use security screws to fit the ignition switch so I ended up drilling a hole in the centre of the head and whacking a torx bit in to get them out. I replaced the security bolts with standard M8 Allen bolts. The use of security bolts is utterly pointless simply because if you have access to the bottom of the switch you have access to the wires and can bypass the whole assembly. Yes there's a steering lock as well but we all know how easily they're broken. So what should have been a 10 minute job turned into an hour plus faff as I had to remove the headlight and one of the indicator mounts to get enough clearance for the drill.
Bah.
Kawasaki Jimbo
PostPosted: 19:22 - 19 May 2024    Post subject: Reply with quote
I had another try at fitting the new fuel hose to a fuel pump on the bench with a smear of Vaseline but there’s no way it’s going on, and I note the new hose is braided (so less flexible) where the originals are not.
NOS is available, cheap and pre-shaped but I don’t know if it is ethanol-resistant. I’m going for it anyway.
to v or not to v
PostPosted: 07:45 - 20 May 2024    Post subject: Reply with quote
why dont you just buy some cheap hose off the bay?
Moto Guzzi V7.
Kawasaki Jimbo
PostPosted: 18:27 - 20 May 2024    Post subject: Reply with quote
A quick look suggests most is braided. I’ve fannied about long enough and already bought hose I can’t use (-I shouldn’t have removed the packaging). Buy cheap, buy twice. I know the Kawasaki stuff will fit perfectly and I suspect it’ll be ethanol-proof even if Kawasaki can’t say so. Afterwards I’ll take some of the old hose to work and sonicate it in ethanol to see what happens.
PostPosted: 19:04 - 21 May 2024    Post subject: Reply with quote
My old Ducati ST2.
Put a new battery in it.
Ordered a rev counter.
Refreshed the brake and clutch fluids.
Insured it.
Gave it a spin and for a bike with 55700 on the clock she still sounds and pulls great.
Next up MOT and tax. *I'll be out on it this weekend.
*Wednesday
Easy-X
PostPosted: 14:34 - 24 May 2024    Post subject: Reply with quote
Got the XSR a fresh MoT. Advisories: noisy exhaust* and chain a bit slack.
* "Bet this sounds fantastic!" - MoT examiner.
blurredman
PostPosted: 22:14 - 24 May 2024    Post subject: Reply with quote
Still slowly working on this mz ts150. Unseized the tacho drive shaft from the bushing, meaning the ratchet mechanism on the rear of the clutch basket (primarily for kickstarter- but also the tacho mechanism rides on it) isn't always...ratcheting. Laughing
PostPosted: 12:03 - 25 May 2024    Post subject: Reply with quote
Fitted replacement rev counter and noticed the clips for the reservoir are rusted.
Ordered clips and new tubing.
blurredman
PostPosted: 14:51 - 29 May 2024    Post subject: Reply with quote
Got some indicators, kinda working. In real life, they flash so fast they seem solid.
https://gemoo.com/tools/upload-video/share/654362283819188224?codeId=v6aKjmabYN52N&card=654362280769970176
Easy-X
PostPosted: 15:06 - 29 May 2024    Post subject: Reply with quote
The rear running light is pulsing in sync. Bad earth or just very weak power generation from the engine?
PostPosted: 16:19 - 29 May 2024    Post subject: Reply with quote
The big red thing passed the MOT.
Taxed it and took it out to rattle some windows.
Rode to superbike factory bike sales and sat on loads of bikes.
The Triumph Tiger felt homely as did the Tracer 900 GT. To be honest you can tour on anything if you put your mind to it.
Still adore the Norton Commando but don't have the confidence in those Stuart Garner years of production. The latest models are out of my price range.
That led me onto the Bonniville range of Triumphs.
ThruxtonR now that's a bike that fitted me well.
Once we've got the roof done on the house and if I'm a sensible it's a contender for next bike down the line.
Back home on the duke and still pulls like a locomotive and handles so well.
https://pbs.twimg.com/media/GOwEgyzWcAAwdry?format=jpg&name=4096x4096
Kawasaki Jimbo
PostPosted: 19:58 - 29 May 2024    Post subject: Reply with quote
I bought a new fuel filter from Wemoto but then thought it must be wrong because the inlet and outlet diameters were visibly different. However, the old one is the same, and when I unwrapped the short, S-shaped, non-braided OE hose (£8.48 from Colchester Kawasaki) which connects the fuel tap to the filter I saw that one end of the hose (on the right here) is also slightly bigger inside (and out) than the other (9.3mm ID vs 7.5mm ID). If fitted the wrong way round the hose is too loose on the filter. So it was OE hose or nothing, I suppose. Seems like an odd design.
https://i.postimg.cc/fL9jWpZH/IMG-1390.jpg
blurredman
PostPosted: 07:08 - 30 May 2024    Post subject: Reply with quote
Actually no, front pulses too. Indicators don't work at all with main lamp on unless you rev the thing. I've cut back all the wires to good core and terminated properly so not sure I can do much else for free. The battery however was reading 5.95v so needs a good long charge. That'll probably help a bit. Cool The thing actually had mostly original factory bulbs in it which I thought was cool.
Easy-X
PostPosted: 12:01 - 30 May 2024    Post subject: Reply with quote
As you were then. There's only so much you can do with old 6 volt systems.
Kawasaki Jimbo
PostPosted: 14:12 - 02 Jun 2024    Post subject: Reply with quote
Cured a misfire by replacing the spark plug cap on cylinder #3. Very Happy
Islander
PostPosted: 18:52 - 02 Jun 2024    Post subject: Reply with quote
Still fettling the R850R but this time I wanted the gear lever to be slightly higher to accommodate my thick toed Richa boots. There wasn't enough adjustment in the lever link so I ended up shortening both the male and femaie parts of the link to gain 1cm. I'd have liked a bit more but I wanted to leave a decent amount of thread. Ho hum.
The last post was made 1 year, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Page 48 of 59
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 141.21 Kb
