Please help before i torch the fken thing
Mr Hammers
PostPosted: 18:31 - 25 May 2024    Post subject: Please help before i torch the fken thing Reply with quote
So. Three days i've wasted trying to sort the carbs out on the bandit. Three days of nice weather that i should be spending buzzing about hither and thither...but instead spent dicking around with the bastard carbs on the sodding thing. Man, i'm so pissed off with it right now.
Ok, deep breath.
Right. So it was running mostly ok, then started playing up by idling really fast, or slow to respond to throttle, and generally running a bit crap. So i pull the carbs off, give everything a damn good clean, blow out the jets etc.
Put it all back together and now it's only running on 2 and half cylinders (two pipes were 100 degrees, one about 70, and the other practically room temp).
Buy a carb repair kit. Fit new diaphrams, new jets, springs etc. Put it back on, and it runs. Sort of. It revs fine and is responsive, but shutting off the throttle causes it to drop the revs to a point where it stops completely.
It will idle, but only if you gently back off the throttle. As soon as you rev and shut off quickly, it dies.
One thing, in the new carb kit it looked like there were two main jets for each carb. As it's an aftermarket can on it thought it best to fit the bigger of the two. Now i'm not sure i should've used the smaller jets (maybe the big ones are for the 1200...?).
Could that be the cause?
I could just take it all apart yet fucking again, in fact sod it, i'll go and do that now.
But....am i missing something obvious here?
What else could cause it to die so quickly after revving?
Any help very much appreciated as the Striple is also on the naughty step as the bloody thing has yet more electrical issues (not charging this time) so i can't use that atm either. The Bandit was supposed to be the backup bike......
Cheers.
A Guide To Powerbands
PostPosted: 18:47 - 25 May 2024    Post subject: Reply with quote
Holding up idle revs is an indication of lean mixture. Diaphragms should have no part in it because the slides should be fully down at idle. It's either an intake air leak or not enough fuel.
Have you done all of the things in this thread?
https://www.banditforum.co.uk/forum/index.php?topic=69488.0
Mr Hammers
PostPosted: 19:05 - 25 May 2024    Post subject: Reply with quote
Cheers, Pete. Apart from taking out the brass plug (which i'm a bit reluctant to do tbh, as it just introduces another variable) i've done everything else on there.
Just before taking them apart again i took it for a quick spin up the road, see how it behaves. It was sounding ok but i think slower, and then it just stopped, wouldn't start again, and i had to push the bloody thing home (and uphill too).
Before i pull them off yet again, i'm going to double check the petcock as i repaired that a little while ago...and after you said it could be fuel starvation, i'm wondering if something's up with that.
struan80
PostPosted: 19:47 - 25 May 2024    Post subject: Reply with quote
The idle trimmer sticking?
PostPosted: 21:14 - 25 May 2024    Post subject: Reply with quote
Don't remove the brass plug. That's just something I did to show what was in there.
PostPosted: 22:24 - 25 May 2024    Post subject: Reply with quote
Does it have a fuel pump and is it working?
Mr Hammers
PostPosted: 10:55 - 26 May 2024    Post subject: Reply with quote
Ah, now...according to the Zenith website, this is an idle trimmer screw;
https://www.planetash.net/bcf/trimmer2.jpg
but i'm pretty sure it's not as that's the drain plug, as seen here;
https://www.planetash.net/bcf/carbs.jpg
These are in the bottom of the float bowl and as far as i can see have no connection to any circuit on the carb.
The idle screws i'm sure are the red circled ones. These were originally set at 2 3/4 turns out (and didn't run well). I've now set them to just 2 turns out (and still not right), but i'm not sure whether i should be turning them out more or turning them in, but more than 2 3/4 would seem a lot...?
I've replaced the main jets with the original ones as i'm not convinced the new ones were the right size tbh, so at least i know the problem isn't with them.
Ah, good that i didn't then Smile
No, no pump, just gravity. It's a Mk1 Bandit! Very Happy
PostPosted: 11:05 - 26 May 2024    Post subject: Reply with quote
Make sure the idle circuit metering screws are all assembled correctly. Spring, washer, o-ring. If they are wrong the idle mixture will be all to hell.
BTW you are right that is a drain screw not mixture control. The idle mixture screws are the ones with the springs.
EDIT: Bandit mk1 slow running circuit diagram:
Mr Hammers
PostPosted: 21:05 - 26 May 2024    Post subject: Reply with quote
Yes, i saw that and was very conscious of making sure i put them in correctly (looked at a parts diagram) but, i could only see one on the four idle screws i took out. I couldn't see anything left in the bottom of the other channels and tried using a pick to extract anything that might still be in there. Either there wasn't, or i couldn't see/get to them.
That said, if anything could cause the issues, that'd be a good bet i think. The pilot jets are now brand new btw, the old ones looked a bit ropey, so i don't think it's them.
Good to know! Incidentally, i can see the tops of the idle screws poking through into the main bore....is that normal?
It's all back together now, and i've opened the idle screws another 1 turn. Although it still idles unevenly and tries to cut off when shutting off the throttle, it seems to be better than it was. I'll go for a little ride tomorrow and see if it cuts out completely again. Hopefully not! Smile
WD Forte
PostPosted: 23:35 - 26 May 2024    Post subject: Reply with quote
Wouldn't you need to use some vac gauges to balance these carbs?
Never had me mitts on a Bandit but on most multi cylinder engines
we'd set it up to spec, (float height, mixture screws set the same
(often around 1/34 turns or so )
then finally use the gauges to fine adjust the butterflys
bikers smell of wee
PostPosted: 08:16 - 27 May 2024    Post subject: Reply with quote
Yes, butterflies badly out of whack can make them run very poorly. You can get them very passably balanced by holding them up to the light and matching the crescent of light around the throttle blades.
Mr Hammers
PostPosted: 14:33 - 27 May 2024    Post subject: Reply with quote
That's exactly what i did, and they do look to my eye at least, like they're all in sync with each other.
Just got back from a short ride out, and although the idle is still a bit hesitant and lumpy when it's anything but up to or above temp, it is riding quite nicely...so i'll take that as a win Smile Cheers guys! Thumbs Up
The last post was made 2 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 82.46 Kb
