Chain Cleaning - White Spirit VS Parafin
flyingcbf
PostPosted: 12:15 - 08 Jun 2024    Post subject: Chain Cleaning - White Spirit VS Parafin Reply with quote
Ok, So this must have been asked many times over but I want to know how many use what products. I use Parfafin as it's cheap and recommended and told it works.
What do you use and why?
2019 Suzuki V-Strom 250
2020 Cb125F @ 5k miles and going up!
Islander
PostPosted: 13:13 - 08 Jun 2024    Post subject: Reply with quote
Scott Oiler and a PD Oiler because fuck manually cleaning and lubricating chains. Laughing
ETA
Before I discovered the pleasures of automatic lubrication I used diesel to clean them. I had a diesel car and always had a 10l can of the stuff handy.
flyingcbf
PostPosted: 13:38 - 08 Jun 2024    Post subject: Reply with quote
Does that method clean the chain as well? Thanks Thumbs Up
Kawasaki Jimbo
PostPosted: 14:02 - 08 Jun 2024    Post subject: Reply with quote
Use gear oil on an O-ring chain, sparingly and infrequently. Excellent chain life, cheap, less messy and never have to clean the chain. No lump of wax and stones behind the sprocket cover either.
Islander
PostPosted: 14:03 - 08 Jun 2024    Post subject: Reply with quote
Yes. They put a drop of oil every minute onto the chain and that both lubricates and cleans. They're really good for chain life as well.
PostPosted: 15:03 - 08 Jun 2024    Post subject: Reply with quote
I'd have thought that white spirit might attack the o rings in the chain? I'd guess that paraffin is better?
DJP
PostPosted: 19:22 - 11 Jun 2024    Post subject: Reply with quote
That's exactly what I've done for years. Cheap, easy and very effective.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
DJP
PostPosted: 19:23 - 11 Jun 2024    Post subject: Reply with quote
I've seen paraffin attack O Ring seals. I've no idea what those seals were made of but I'd keep it well away from the chain just in case.
Suzuki Bandit 1250
struan80
PostPosted: 20:02 - 11 Jun 2024    Post subject: Reply with quote
Are the orings self lubricating? What material are they?
I always figured oiling a chain is futlie other than stopping the chain from surface rusting. Where there is movable parts on the chain would rub the chain dry of any lubricants.
Now if the chain and assembly were in an oil tight housing I could see the point.
Anyway I tend to just replace the chain when it gets to fucked up due to neglect.
flyingcbf
PostPosted: 09:35 - 12 Jun 2024    Post subject: Reply with quote
I've done some research on the internet and people do use PArafin to clean the motorcycle chain. Perhaps it's the old way of cleaning a chain. Only recently found out about white spirit.
So I take it you don't clean the chain just lube it and that's it?
Nobby the Bastard
Harley Gaydar
PostPosted: 10:03 - 12 Jun 2024    Post subject: Reply with quote
With a o-ring chain you are primarily oiling the interface between chain and sprockets. Cleaning chains a waste of time when you could just stick an auto-oiler on it.
Triumph Sprint ST 1050
flyingcbf
PostPosted: 11:04 - 12 Jun 2024    Post subject: Reply with quote
Let me try and be a little more clear.
I lube the chain with gear oil every 200 miles
But after 1000 miles, I will clean the chain with Parafin, Brush off then hose down with water to clear all the Parafin and muck. Wait for the water to dry before applying gear oil.
Ayrton
PostPosted: 14:34 - 12 Jun 2024    Post subject: Reply with quote
Always just used paraffin to clean using a chain brush and then a rag to dry it off. Then a small amount of gear oil on a toothbrush to oil it. Never tried white spirit but I think it's more expensive than paraffin and I've always got some around to run my heater Laughing
flyingcbf
PostPosted: 14:38 - 12 Jun 2024    Post subject: Reply with quote
DJP say's that Parafin attacks the O Rings Sad
flyingcbf
PostPosted: 12:02 - 13 Jul 2024    Post subject: Reply with quote
Just lubed the motorcycle chains with this...
https://lh3.googleusercontent.com/pw/AP1GczORNmJvX3W6by4_JyYW8G83eQLdaetYiYIPz7T6Hk4UZF9Miej5QWwSUn8tfsShI8e2t8ll_Ez4hbOqjOCwI83X_meyBZ4wcPoJMW1OkPoMlVCtJtknQpPo7tY7Rp_owJOEwvZ6RiPFbKl23ERhomOg=w1004-h457-s-no-gm-no
Appears to be slighly thicker than my previous 80W-90
Robby
Dirty Old Man
PostPosted: 12:56 - 13 Jul 2024    Post subject: Reply with quote
I don't clean them.
I generally go for bikes that are shaft or belt drive, because chains are messy. Chains gets oiled occasionally with a spray can. When they're worn out, they get replaced. My old 250 runs a plain chain that costs £20, not worth doing any more than the most basic maintenance.
The surprising thing for me is that I've seen this same thing come up for the 20 years that I've been riding. A scottoiler is still the recommended solution, but they're still a bit fiddly to set up and keep behaving. At least belts have come on a long way in that time.
flyingcbf
PostPosted: 08:40 - 14 Jul 2024    Post subject: Reply with quote
Shaft is defo the way but I've not seen any shaft bikes that can do over 80MPG
buddy
PostPosted: 15:57 - 04 Aug 2024    Post subject: Reply with quote
Ask the chain manufacturer.
When this baby hits 88 miles per hour... you're gonna see some serious shit.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:13 - 04 Aug 2024    Post subject: Reply with quote
FFS not again....
Kawasaki Jimbo
PostPosted: 16:19 - 04 Aug 2024    Post subject: Reply with quote
They’ll just recommend their own brand aerosol of precious unicorn’s tears.
PostPosted: 17:51 - 04 Aug 2024    Post subject: Reply with quote
I tend to not look at the MPG, but i get around 50 on a BMW R1200.. I ride fairly granny like though. It is however miles ahead of the underpowered motors you have, which is likely why a shaft isn't present, they aren't worth the development on such low powered cheaper vehicles.
I'd be less concerned about that factor. Chains are agg, messy and when they do snap, can take a chunk of engine or leg as a reminder.
flyingcbf
PostPosted: 03:52 - 05 Aug 2024    Post subject: Reply with quote
Everytime you fill up in the course of a year, the difference 30MPG's extra can make can add up but I wonder by how much? Then considering the greasing and maintence of chains add up. And then the replacement. I guess if you factor those things in, one can then make up his mind if the shaft drive would be a better option. Thumbs Up
PostPosted: 11:21 - 05 Aug 2024    Post subject: Reply with quote
I am not one who calculates fuel as a cost, its smiles per mile, not miles per gallon.
If I cared about fuel and cost, I'd have a moped or a 125. But this is off topic. I don't care about chains, add a lube option, forget about it.
The last post was made 2 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 116.13 Kb
