Hinson Steel Clutch Basket
flyingcbf
PostPosted: 16:10 - 12 Jul 2024    Post subject: Hinson Steel Clutch Basket Reply with quote
Hi Folks,
Hope you are all well.
Has anyone changed over their alloy clutch basket to a steel one?
My gear shifting is beginning to get a little stiff or harder to shift again and I'm worried it will only get worse Sad
I've already once sanded down the 'notches' on the alloy clutch basket 'tongues' which made is much better but after several hundred miles, the 'notchiness' is becoming little more apparent again.
2019 Suzuki V-Strom 250
2020 Cb125F @ 5k miles and going up!
to v or not to v
PostPosted: 19:28 - 12 Jul 2024    Post subject: Reply with quote
is your chain correctly tensioned?
Moto Guzzi V7.
flyingcbf
PostPosted: 19:36 - 12 Jul 2024    Post subject: Reply with quote
Yep. Yep, chain seems fantastically tensioned and all okay chain cleaned and lubed again
jeffyjeff
PostPosted: 00:29 - 13 Jul 2024    Post subject: Re: Hinson Steel Clutch Basket Reply with quote
flyingcbf wrote:
Hi Folks,
Haven't done it but sounds like a worthwhile upgrade. Back in the day, we used to have automatic transmission cases modified with steel inserts after the clutches wore grooves into the splines. Worked a treat and significantly improved the performance and service life of the transmissions. Wink
flyingcbf
PostPosted: 11:55 - 13 Jul 2024    Post subject: Reply with quote
Guess they don't make those anymore... Would be great to modify i
the existing one if anyone is able to recommend someone.
The last post was made 2 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 44 Kb
