| to v or not to v |
 to v or not to v World Chat Champion
 Posted: 16:59 - 15 Jul 2024 Post subject: |
am contemplating buying a new shock for my bike.
Nitron are for people way beyond my riding capabilities though.
YSS are the cheapest ive been able to find and they are still around the £300 mark.
seems like a lot of money to throw down when i may buy a new bike soon.
2nd hand market is practically non existent  ____________________ current bike Yamaha Thunderace.
Moto Guzzi V7. |
| MarJay |
 MarJay But it's British!
| recman |
 recman World Chat Champion
 Posted: 19:51 - 16 Jul 2024 Post subject: |
Had a quick check that the solar battery maintainer is still maintaining.
| Easy-X |
 Easy-X Super Spammer
| Easy-X |
| DaddyStu |
 DaddyStu Crazy Courier
| that_impulse_guy |
 that_impulse_guy Scooby Slapper
 Posted: 21:35 - 25 Jul 2024 Post subject: |
printed out some fairing lugs in anticipation of repairing some fairings. What a world we live in eh! ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R |
| to v or not to v |
 Posted: 19:34 - 26 Jul 2024 Post subject: |
dragged it out for a ride and it wouldnt bloody start  ____________________ current bike Yamaha Thunderace.
Moto Guzzi V7. |
| to v or not to v |
| Ayrton |
 Ayrton World Chat Champion
| blurredman |
 blurredman World Chat Champion
 Posted: 07:35 - 30 Jul 2024 Post subject: |
Need to get motivated to get the TS150 in working order before I start using it more for work, and then eventually moving it on.
Swapped coil from one bike to it in a hope it would resolve the (when warm) wanting to stall at lower RPM. Then wouldn't start, float bowl valve sealed. Compressed air down the fuel line fixed that. Then when eventually running realised I had a throttle cable issue that I forgot occured on the last test ride - So I seperated and cut the broken strand of wire on the inner cable. And also loctited and found good replacement bolts for the ones that went missing that hold on the rear mudguard.
Then when I got it going again, I heared a tapping sound from the inlet and the throttle response seemed lean- there had developed a hole in the aluminium inlet where the carb clamps to. Replace that with one I have spare.
Go for a ride, 25 miles, stalling problem seems resolved. But battery is not good so when lights are on the bike cannot hold itself at idle. What's more it seems the 40w low beam has blown too.  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| Easy-X |
 Posted: 14:43 - 10 Aug 2024 Post subject: |
Wiring up another set of Harley lights. The original filament bulbs are low beam on one side, high beam on the other. The replacement LED elements do both so need wiring in parallel:
https://i.imgur.com/bQT8uCN.jpeg
The finished article:
https://i.imgur.com/8rAF8xA.jpeg ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| tinkicker |
 tinkicker Scooby Slapper
 Posted: 08:08 - 11 Aug 2024 Post subject: |
For several months I have been squinting at the right hand seat cowl on the VFR. I concentrate a little more and close one eye in concentration and then shrug my shoulders and walk away.
The feeling persists.. And turns into a niggle that will not go away. Once again I have a squint at the cowling with deep suspicion. The focus of my attention is the area under the cowling wherin the reg rec lies.
The VFRs achiles heel has always been failure of the reg rec and specifically, the crimps on the wires, or the terminals themselves losing good electrical contact and pretty much just failing to set the unit on fire by a whisker. Much smell of burning insulation and melted plastic.
I have absolutely no evidence that it is going to fail. Everything is peachy, yet the feeling will not go away. I learned long ago, never to ignore niggling thoughts and pulled off the cowl to look at reg.
Absolutely no sign of any problems. Nothing overheating and yet...
It was a finned aftermarket one, I recall the one on my brand new VFR back in 97 that it was a potted one without fins. Funnily enough, when I restored the VFR back in 2019, I never noticed.
A closer look gleaned the info that it was made by Sun electronics. Never heard of them. Hmmm.
A look on the net revealled that a new Electrex mosfet unit for the VFR750 was £92 inc heavy duty connector block and terminals.
Being a vintage bike restorer, I have some skill in ferreting around on the internet looking for parts no longer available and cross referencing numbers, so back to my sources..
Electrex part number for VFR reg is RR58. A look on the honda parts fiche revealed the OEM unit part number, and a revised part number for a modern finned equivalent at £280
A cross reference of part numbers revealed the modern unit is fitted across many Honda models, so model types in hand I go exploring and strike gold.
Electrex VFR750 reg rec part number RR58 is £92.
Electrex CB500 reg rec part number RR58 is £60 with the heavy duty connector block.
Disparities like this happen a lot. You have to go scratting about to get a good price. I call it the "vintage bike" premium. If it is for an older or "sexier"bike it must be worth more...
CB500 reg duly ordered..and arrived.
Yesterday, pulled the old one, cut off the old plug, crimped on the new heavy duty terminals and soldered them to ensure good electrical contact is maintained, as per electrex recommendations.
The whole plug was liberally treated to a good slathering of petroleum jelly to keep corrosion away. Took a lot of effort to plug in. Those new terminals are TIGHT.
Then fitted the reg body with a nice amount of Arctic MX4 thermal paste twixt frame and rear heat sink plate. The paste should keep it a couple of degrees cooler.
A quick test gleaned 14.65v at 3000 rpm with lights on and 14.85v with lights off.
Goodo.
Of course I have the old reg stuffed under the seat with the tools required to swap it again if required. New electronics need some time before they can be trusted and you all know what sort of luck I have... ____________________ Wading through the thick tapestry of life one day at a time. |
| Nobby the Bastard |
| Nobby the Bastard |
| panrider_uk |
 panrider_uk World Chat Champion
| Rob W |
 Rob W World Chat Champion
| struan80 |
 struan80 World Chat Champion
| Rob W |
| CrypticCrud |
 CrypticCrud Trackday Trickster
| Easy-X |
 Posted: 12:21 - 06 Oct 2024 Post subject: |
Bike had been sat a few weeks so before riding out yesterday...
Checked and I had 1.8 / 2.2 bar front & back. Spec: 2.5 / 2.9
Another reminder to regularly check your tyre pressures  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| to v or not to v |
| Nobby the Bastard |
| Easy-X |
| Nobby the Bastard |
The last post was made 1 year, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
