Bump starting possible? Hold clutch in to start normally.
Bike Chat Forums Index -> The Workshop via View All Topics
thx1138
PostPosted: 11:36 - 13 Nov 2024    Post subject: Bump starting possible? Hold clutch in to start normally. Reply with quote
VanVan 200cc battery nearly dead, bike wont start.
Bike 8.5 years old.
Ordered a battery charger anyway(lost mine) anyway, before i buy a replacement battery, which have removed and i expect to replace.
No kick start. To start with electric start i have to hold clutch in, is it possible to
somehow bump start ?
piazza
PostPosted: 12:02 - 13 Nov 2024    Post subject: Reply with quote
How long have you been driving bikes!? Laughing
Clutch in, 2nd gear and push the bugger. Dunno if you need the battery in on that particular bike tho, expect more advice and mocking shortly Thumbs Up
thx1138
PostPosted: 12:05 - 13 Nov 2024    Post subject: Reply with quote
Well i tries bump starting it, battery in and it did not work, so i thought thatt
was the reason.
PostPosted: 15:14 - 13 Nov 2024    Post subject: Reply with quote
What he's saying is that it has a clutch interlock switch which would prevent traditional bump starting.
rpsmith79
PostPosted: 15:25 - 13 Nov 2024    Post subject: Reply with quote
Does that not just interlock the starter motor/switch though, shouldn't affect bumping it as long as key is in ignition position
Nobby the Bastard
Harley Gaydar
PostPosted: 15:39 - 13 Nov 2024    Post subject: Reply with quote
Efi or carb?
Triumph Sprint ST 1050
WD Forte
PostPosted: 16:00 - 13 Nov 2024    Post subject: Reply with quote
Had a look at a Vanvan pic and they appear to be side stand only
with no kick start.
If so, the clutch switch is only to prevent starting when the stand is down and shouldn't prevent you doing a bump start.
bikers smell of wee
PostPosted: 16:04 - 13 Nov 2024    Post subject: Reply with quote
Clutch interlock is usually just to lock out the starter motor, not the ignition.
If it's EFI, on most bikes if there's not enough juice to power the starter, there's not enough to power up the fuel pump, efi and ecu so bumping is a waste of time.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:13 - 13 Nov 2024    Post subject: Reply with quote
I was actually thinking if its efi if you are not pressing the starter the fuel.line won't be pressurised by the fuel pump.
WD Forte
PostPosted: 16:17 - 13 Nov 2024    Post subject: Reply with quote
Yep, If its EFI then you'd need to use the tired old battery as long as it has enough power to prime/run the fuel pump and ignition.
If it hasn't then its pointless trying.
If the battery is 50/50 turn off or whip out the headlamp bulb or light fuses so you can use as much of the limited available power as possible for fuel and ignition
bikers smell of wee
The last post was made 2 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via View All Topics All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 65.79 Kb
