Keeway RKF reset engine light HELP
jaybowuk
PostPosted: 12:43 - 08 Feb 2025    Post subject: Keeway RKF reset engine light HELP Reply with quote
Hi All
Does anyone know how to reset the engine management light on the keeyway RKF 2022 ?
I've seen loads of posts on the net but none of them work! All made by unknowledgeable hit hunters,
Disconnecting the battery for a few minuets- NO, I disconnect my battery on a weekly basis to charge it as we all know how good the RKF is at starting on cold mornings.
Turning the ignition on for 5 seconds , off for 15 on and off 5 times - NO
Think the poster of this one had had too many head injuries.
I would just like to know , if anyone does a way of resetting it, as I need to sell it and buy another lexmoto.
I have bought various leads etc for the OBD reader but these don't work, so just need the procedure.
Thanks in advance.
JayBow
WD Forte
PostPosted: 13:02 - 08 Feb 2025    Post subject: Reply with quote
Fix the damn fault of course !
The eml only comes on when the ecu detects a signal it 'doesn't like'
suggesting a component fault.
if it doesn't a detect a fault state it doesn't come on
Get fault codes, fix fault, eml goes off.
It's probably running a flavour of the Delphi EFI system and the dtc list may self clear or not
On a Honda PGM-Fi for instance, the ECU will retain some dtc's until you run a 'clear codes' process but the eml will only show when here is an active fault
bikers smell of wee
andys675
PostPosted: 18:05 - 08 Feb 2025    Post subject: Reply with quote
an enfield himalayan with similar problem
seller found out it was a normal clock bulb, removed it from the fitting and left it loose
WD Forte
PostPosted: 00:31 - 10 Feb 2025    Post subject: Reply with quote
That's an option as unlike a car it isn't checked during an MOT
bikers smell of wee
jaybowuk
PostPosted: 09:33 - 10 Feb 2025    Post subject: Reply with quote
It was the O2 sensor, I have replaced it but I was also told I will still need to reset the error.
Thank You
Jay
The last post was made 1 year, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 43.11 Kb
