GPz750 Fork Oil Recommendations
Grumpy Grandad
PostPosted: 20:51 - 27 Mar 2025    Post subject: GPz750 Fork Oil Recommendations Reply with quote
I'm planning on changing the fork seals as I've noticed a small leak in one of them.
Good News is they weren't changed when the bike was recommissioned last year, so they're OLD!
I was pissed off because I'd thought they were New Seals that had failed after only 7 months.
I'm not impressed with the 39 year old suspension but such is life. I have heard that putting a heavier 15W oil can make an improvement, anybody had any experience of that?
The A3 model is fitted with Anti-Dive but I'm sure that was more a gimmick than a practical solution. I understand a common mod is to bypass it, anyone tried the bypass kits?
Cheers. Chequered Flag
Life may begin at 30, but it doesn't get interesting until about 75 mph.
PostPosted: 21:11 - 27 Mar 2025    Post subject: Reply with quote
I have a friend who used to have an A1 back in the day, he said that the anti dive, when it worked, was really damn good. He thinks the A models handled better than the later ones with more modern tyre sizes and suspension.
PostPosted: 22:59 - 27 Mar 2025    Post subject: Reply with quote
I run halfords multigrade oil in most of mine. Less fade if you've been working them hard.
However, is damping the issue or is 40 year old springs that were probably on the soft side when they were new anyway the problem?
The oil viscosity will only affect the damping rate, which is a function of the valving and hole sizes in the damper. That's probably not changed much over the years.
So my suggestion would be to plug your details into the spring calculator on https://racetech.com/product-search/ . It'll give you a suggested linear spring rate, spacer size, oil viscosity and air gap. Do that. It's a US site so you may need to look at different years for your model.
For example, if I plug my details in there for your bike, it recommends a spring rate double that of standard and 20wt oil. Then set your static sag by adjusting spacers.
Having done this on a couple of bikes, I'll say the only downside is it'll make you realise you now also need a new shock. Having done that, you'll realise you need to upgrade the brakes.
There's no point fucking with any of the other settings on your suspension if the spring rate is wrong. Then sag, then other stuff.
Grumpy Grandad
PostPosted: 10:26 - 28 Mar 2025    Post subject: Reply with quote
As always great technical info SW Thumbs Up
I take it that's the 5W30?
I hear what you say about the springs and maybe that's a job for another day. Although it's a 40 year old bike it's only got 16'000 miles on it so the springs may not be that knackered, same goes for the bushes Thinking
I've read suggestions to always change the bushes with the oil seals, is that much of a balls ache, I've not had do them before.
Cheers for the info Chequered Flag
PostPosted: 12:15 - 28 Mar 2025    Post subject: Reply with quote
Well, you can at least check the springs are still within spec. Your workshop manual will have a minimum free length listed. I can almost garauntee they are under it, just by dint of being compressed in a fork with a bike sat on them for nearly 40 years.
Bushes are easy to fit, the hard bit is sometimes getting the forks apart, this necessitates slide-hammering them apart to remove the bottom bush. It generally either goes very easy, a few knocks and they're apart or they start to override and you're on the struggle bus.
My other top-tip is, if at all possible, use OEM bushes and seals and check the bush end gap is correct. Aftermarket seals are a false economy.
If you don't have a sel driver tool, it's a good investment.
Grumpy Grandad
PostPosted: 15:43 - 28 Mar 2025    Post subject: Reply with quote
stinkwheel wrote:
My other top-tip is, if at all possible, use OEM bushes and seals and check the bush end gap is correct. Aftermarket seals are a false economy. Thumbs Up
I've got some OEM oil seals , I'll source some OEM bushes.
I'll also add a seal driver to my shopping list. Very Happy
Thanks for the guidance. Thumbs Up
Hope you're enjoying the nice weather. Chequered Flag
Robby
Dirty Old Man
PostPosted: 10:41 - 29 Mar 2025    Post subject: Reply with quote
I can highly recommend putting a set of cartridge emulators in traditional damper rod forks. In fact I would do that first, on standard springs and 10W oil, and work from there.
Heavier oil and stiffer springs both restrict your suspension movement. This is good when your suspension is moving too much - and bottoming out a lot, or diving too much for comfort under braking. The downside is that if you go too far you end up with suspension that only moves under the biggest loads, and moves slowly.
On my Guzzi, which is quite new but had awful suspension from new, I have the following setup:
Hagon springs progressive springs. I did previously have a set of racetech springs, but they were too hard. They only offered one spring rate, Hagon do a few.
10W oil. It's the right weight to allow good movement on my bike.
YSS cartridge emulators. They make the biggest difference.
I now (finally) have forks that use their full range of motion, are comfortable, and don't bottom out.
Make one change at a time. Each aspect affects everything else.
Grumpy Grandad
PostPosted: 15:45 - 01 Apr 2025    Post subject: Reply with quote
Thanks for the suggestion Robby Thumbs Up
Did you have to drill out the holes on the fork damper?
Just reread your post... glad I did as I was just about to look like a Dick! Embarassed
I note you used a Hagon/YSS Combination, that must have kept the price down a bit. Obviously US kit is a bit more pricey Sad
Cheers Chequered Flag
yen_powell
PostPosted: 22:03 - 01 Apr 2025    Post subject: Re: GPz750 Fork Oil Recommendations Reply with quote
It was a long time ago, but I seem to recall that after a shop changed my fork seals the forks were really soft because no one had put air into them, they improved once I added some. Mine was a 1986 faired/uni-track model.
XT1200Z and a DR350 in bits
Grumpy Grandad
PostPosted: 18:01 - 02 Apr 2025    Post subject: Re: GPz750 Fork Oil Recommendations Reply with quote
Thanks for the info Yen Thumbs Up
Lots of good input for this question, plenty to think about Thinking
I'm reading through the Haynes manual and they do make me laugh. Plenty of, ''This is not a serviceable item..... you'll have to replace it''!
Easier said than done in some cases. Very Happy
Robby
Dirty Old Man
PostPosted: 17:29 - 10 Apr 2025    Post subject: Reply with quote
Yes. That bit was easy, they're made of fairly soft mild steel.
Grumpy Grandad
PostPosted: 18:53 - 10 Apr 2025    Post subject: Reply with quote
I like the sound of the emulators but intially I think I'll just change the springs. I e-mailed Hagon about some (they stock GPZ750R & Turbo) so I asked if they're the same ... you'd have thought so. They're not sure.
I'll take Stinkwheel's advice and measure them ... As he said the RaceTech site Recommends a spring rate of 1.07kg/mm against a Stock spring rate of 0.5 kg/mm, so that should make a difference. Hagon don't supply any info but I'll ask.
The last post was made 1 year, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 80.95 Kb
