What threadlocker do you recommend for fairing bolts and scr
John Proton
PostPosted: 20:34 - 12 Jul 2025    Post subject: What threadlocker do you recommend for fairing bolts and scr Reply with quote
Hello, I'm John and I am looking for some help please.
Had a recent experience of a fairing bolt come out (never happened before) so want to stop them unscrewing but be able to remove them for bike servicing etc
​A friend suggested clear silicone sealant but not sure if that'll be up to the job.
Thank you
Easy-X
PostPosted: 21:00 - 12 Jul 2025    Post subject: Reply with quote
A dab of something that's billed as threadlocker is usually the way Wink
Blue is medium strength, for stuff that might need to come out some day, and red for one step away from superglue "I never want to see this again" Smile
https://www.loctiteproducts.com/ideas/build-things/threadlocker-red-or-blue-which-ones-right-for-you.html
John Proton
PostPosted: 21:06 - 12 Jul 2025    Post subject: Reply with quote
Thank you for your help
jeffyjeff
PostPosted: 04:38 - 13 Jul 2025    Post subject: Reply with quote
Most fairings are held in place with capscrews threaded into rubber well nuts, which expand (behind a drilled tab) as the fastener is tightened. If you apply a threadlocker to the capscrew on assembly, you risk creating a threaded coupling that cannot be disassembled, as the rubber well nut freely turns inside it's bore. ---more friction between the capscrew and well nut than between the well nut and the tab. If that happens, you will have a very difficult time removing your fairing without resorting to some potentially destructive methods.
Rather than use a threadlocker, I suggest using a new well nut and capscrew, and tightening the screw snug. Wink
PostPosted: 08:45 - 13 Jul 2025    Post subject: Reply with quote
Or replace them
with dzeus 1/4 turn fasteners which are both quick and easy to remove and lock in bayonet style so won't come loose. Also racebike.
The last post was made 1 year, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 43.73 Kb
