What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 56, 57, 58, 59, 60  Next
CrypticCrud
PostPosted: 15:23 - 19 Aug 2025    Post subject: Reply with quote
Dropped it off at Two Wheel Centre. Handed over 100 notes & they'll wash, dry & polish it. Then they whip it inside, stick up in the air & give it the once over. Checking oil, water, air & lubing the chain too.
Happy to support a local business as I don't have the space / facilities to do it at home.
(took em some biscuits in to keep em sweet as well)
CBT - Aug24, Theory - Jun25, Mod 1 - Jul25, Mod 2 - Sep25
Kawasaki Z125 > Honda Z125 > GSX-R600 Y
Kawasaki Jimbo
PostPosted: 16:45 - 19 Aug 2025    Post subject: Reply with quote
blurredman wrote:
Kawasaki Jimbo wrote:
Both bikes need an MOT. The tyres on the Yamaha are not only worn but are over a decade old. Pale
And yet I just installed a tyre from 2012. Thinking Took it from the tip three years ago - finally have use for it.
My rear tyre is worn to the limit, squared and also starting to crack across the tread. The front is on the limit and also has a noticeably different radius on the right side (due to roundabouts, I guess.)
blurredman wrote:
If it was a case that your indicator stalk had brewers droop effect, could you not just swap it with the other side to eventually over time counter the effect?
The one on the right was replaced for the same reason 5 years ago. Actually I probably snagged both when squeezing past in the garage, but when they age they don’t bounce back, they tear off.
to v or not to v
PostPosted: 18:33 - 19 Aug 2025    Post subject: Reply with quote
am i reading this wrong or have you just paid someone £100 to wash your bike and grease the chain?
Moto Guzzi V7.
jeffyjeff
PostPosted: 21:21 - 19 Aug 2025    Post subject: Reply with quote
to v or not to v wrote:
...am i reading this wrong or have you just paid someone £100 to wash your bike and grease the chain?
...and bribed them with biscuits to do their job.
History shows again and again how nature points out the folly of men - BOC
blurredman
PostPosted: 11:21 - 20 Aug 2025    Post subject: Reply with quote
https://i.ibb.co/7JHnHWGC/pistongouge.jpg
Went to investigate what I thought might have been a hot seizure some weeks back - I put it in neutral and coasted for a few hundred yards and it came back to life fine when I put it in gear and I just carried on and have been riding it since.
But obviously it was a seizure in the making from the gudgeon pin retaining clip breaking. Classic occurance, that I had yet to experience until this point. Laughing
A100man
PostPosted: 11:49 - 20 Aug 2025    Post subject: Reply with quote
Shocked So that's a new circlip?
File down the high spots and add some new rings - job done Wink
CrypticCrud
PostPosted: 11:58 - 20 Aug 2025    Post subject: Reply with quote
Spot on! (I don’t have the facilities to do it at home. (Greasing I do myself but I let them do it on a mini service))
Not at all. Always on hand if I need something. Fit me in if I need something doing asap & drop me off back home if I leave the bike there.
A quids worth of biscuits doesn’t break the bank.
blurredman
PostPosted: 12:20 - 20 Aug 2025    Post subject: Reply with quote
Almot piston only 4k miles old. Used the gudeon and clips that came with it. I had to put this new one in as the old piston had a piston ring retaining pin recess into the piston allowing a ring to turn and get caught up in the exhaust port- thankfully little damage from that too.
Barrel is gouged but thankfully mostly only below the side/exhange port which is good. Might put another new piston in again. But cut the clip ends shorter to reduce likelihood of fatigue on the bend allowing the end to flex off. It's not rare for this to happen, i'm just disapointed. Laughing These sort of set backs continually seem to occur to me. Too many machines you see. Laughing
Easy-X
PostPosted: 18:04 - 22 Aug 2025    Post subject: Reply with quote
Another little run out with the GT today, sump plug bone dry. Hopefully I can mark the thread repair (2nd attempt!) a success.
CrypticCrud
PostPosted: 18:26 - 22 Aug 2025    Post subject: Reply with quote
Traded in the Z125 for a Monkey.
It's friggin awesome. I'll definitely be going up Matlock on Sunday!
A100man
PostPosted: 15:00 - 23 Aug 2025    Post subject: Reply with quote
Confused I thought a Z125 was a monkey Thinking
CrypticCrud
PostPosted: 15:18 - 23 Aug 2025    Post subject: Reply with quote
It sure is but my old one was a Kawasaki Z Wink
Easy-X
PostPosted: 16:52 - 25 Aug 2025    Post subject: Reply with quote
Tinkering with the Old Fella's Harley...
He couldn't get it to start this morning: press the button, click, thud and then the electrics died. Sounded expensive. Of course when I lay my hands on it the bike starts perfectly fine Rolling Eyes We had a natter about this and that, then he tried it again - click, thud, dead - but at least it was decent enough to do it in my presence Smile
Whipped the seat off to check the battery, 12.7 volts not too bad, and the bike sprang to life again Thinking So we cleaned the terminals (after a slight argument with the alarm system) and I'm pretty confident it should be fine now.
As a bonus we also discovered the source of the buzzing @2,500rpm on my GT! A lot easier when you have an extra pair of hands to prod things. Turns out it's the clock mounts, I'll order the upgraded versions from Hitchcocks.
blurredman
PostPosted: 18:31 - 25 Aug 2025    Post subject: Reply with quote
Replaced O-ring for the idle air bypass screw on the 251's BVF 30N3 carb. Idle speed was a bit up and down depending on ambient temperatures. Do need to do a tune and balance the idle fuel screw adjustment and air screw adjustment after a ride but should be fine now hopefully after doing so. Cool
jeffyjeff
PostPosted: 02:59 - 02 Sep 2025    Post subject: Reply with quote
Scrubbed down the chicken strips on my G310R up Mt. Hamilton road to the James Lick Observatory.
https://live.staticflickr.com/65535/54760185625_f1d1b6329e.jpg
Still got about a 4mm strip; getting along in my effort to erase the Michelin Man off the tread, but the directional arrow is still virgin. That's probably about as far as I'm going to get on these tyres. Today was a really nice day for spirited riding, and the rubber was just about as hot and grippy as it's going to get. Sad thing about the Pilot Streets is that they last too damn long, and I'm too cheap to replace them as long as there is usable tread. Thinking about Metzler Sportec rubber next time around. I was considering a pair of Dunlop Mutants, but they have almost doubled in price in the last 12 months. Wink
https://live.staticflickr.com/65535/54759004527_df1fc8a8a5_w.jpg
CrypticCrud
PostPosted: 12:45 - 21 Sep 2025    Post subject: Reply with quote
Spire Leathers in Chesterfield had a charity coffee morning, so spent a few quid there on tea, biscuits (x2) & a piece of cake.
Then shot off to The Green Hut for a cheese salad cob.
Definitely not in Ketosis but well under calories for the day.
PS Julie at Spire leathers does alterations, pretty good she is too!
(I wound post pics but I still can't seem to do it)
Easy-X
PostPosted: 16:19 - 21 Sep 2025    Post subject: Reply with quote
Checked tyre pressures before heading out on the GT. Back was fine but the front was down at least 10psi Sad I have a little rechargeable tyre inflator and given its intended use is car tyres I had it back to the correct pressure in mere moments. Hmmm...
I head out, head back, check the pressure after the bike's cooled down a bit. Pressure in the front has not altered even a hair's breadth on my gauge Thinking I can only put it down to a highly localised time distortion given a few months ago my Husky had 10psi extra air seemingly from nowhere. Now we know: it came out of the GT Laughing
panrider_uk
PostPosted: 22:40 - 21 Sep 2025    Post subject: Reply with quote
Ridden it (Guzzi V85 TT) for the first time since my test ride (in monsoon rain conditions).
'Tis a lovely bike.
blurredman
PostPosted: 08:55 - 22 Sep 2025    Post subject: Reply with quote
When was the last time you used the bike?
My cars and bikes, when simply sitting lose air- but when used constantly they don't seem to lose any air.
Rob W
PostPosted: 09:35 - 22 Sep 2025    Post subject: Reply with quote
Fitted a full Black Widow system minus the baffles, it makes a fair bit of noise now to say the least. Hoping to get it up to BSD in the next few weeks to get it mapped properly.
Annoyingly this morning it's showing an EML despite not having any issues when I tested it Friday/Saturday. I'm assuming some moisture has gotten in the o2 connector when I cleaned it yesterday.
TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900
Easy-X
PostPosted: 11:07 - 22 Sep 2025    Post subject: Reply with quote
Probably a week or so. If both tyres were down a bit I'd not have even mentioned it. BTW tubed tyres on the GT.
blurredman
PostPosted: 13:00 - 22 Sep 2025    Post subject: Reply with quote
Yeah, most of the time it's one tyre over the other- normally the older tube (some of mine are decades old so no surprise the rubber gets porous). Sometimes i've come back to the bike after the day working and seen they've lost some since the ride into work Laughing
panrider_uk
PostPosted: 19:19 - 22 Sep 2025    Post subject: Reply with quote
Did about 80 miles on mixed roads inc motorway testing out the Moto II satnav.
It was much better than I expected.
Easy to follow routing and a visual (flashing LEDs) and sound (loud beeps) notification when you're approaching a navigation "event" and when you arrive at it.
Recalculation was pretty quick when I deviated from the planned route.
The display was very easy to see.
A couple of times the sun made it hard to read but I just moved forward to create a shadow.
Annoyingly I bought it from Amazon for £200 + £30 for the handlebar mount.
When I went to buy some gloves from Gear Change they were selling the satnav + mount + carry case for £200
Easy-X
PostPosted: 13:26 - 23 Sep 2025    Post subject: Reply with quote
I have the original and functionally it works quite well (recalculating routes etc.) but the display is much harder to read.
The Tot
PostPosted: 22:44 - 23 Sep 2025    Post subject: Reply with quote
I went on my weekly commute to work for the first time and I have to say that I've been impressed with the small mods on the bike.
The Xitomer (Apex clones) clip-ons are absolute spot on. It's given me the right amount of wristiness that lets me know what that front end is doing. The Road 5 tyres turns in as good as any other sports tyre I've tried (S21s, M9RRs, Sportsmarts), but that weight over the front is something that's comfortingly familiar to me. No achy lumbar either.
The Eazigrip tank / knee grippers are a helluva lot nice than the stompgrip knobblies I've ran on previous bikes. Riding in kevlar jeans, you can comfortably grip and lock on to them with your thighs, which is an absolute godsend when riding 2 up. My daughter will love the fact that she can just use my back as a boogie board to brace against under heavy braking.
The Puig touring screen clone looks nicer than the stock screen. At its lowest setting, I didn't find the wind noise that bad when using my Shoei X Sprit 3. Will try to see if there's a discernable difference with my Arai Corsair X or HJC Rpha 11.
Given it was 6°C when I set off, I found the Oxfords HotGrips Pro Sports to be insanely hot in the medium setting. Hot was pretty much the same sensation as giving your boy lucifer a hand job on a cold Wednesday night in Stoke. Was wearing my Alpinestars GP Pro gloves, so they're not exactly cold weather gloves! That gives me some level of confidence for when winter comes around. Found them to be better than the original Oxford HotGrip Sports with the controller box.
Got to say that this bike is perfect for B-road blasting. The combination of suspension plushness, engine flexibility and now-sorted ergonomics means that I'll be picking up the keys to Megatron every time. I don't think I'll even bother with a decat bike since I don't think my local dyno guy/mechanic has the software to flash and map any exhaust mods. Plus, it's understatedly quiet, which means 7AM starts don't annoy the neighbours as much as a decatted R1 or choked out Fazer.
I sat on the R1 as I was wheeling the bikes around the garage and have to say that its days may be numbered. Everything felt so bloody stiff! The final thing I'm going to do to finish the bike off (on the cheap) is to stick some fly-eye perforrated dark vinyl over the indicators so that it takes away that orange bulb contrast. If I'm content with how it looks, I'll go with smoked LED front indicators, paired with an R&G touring tail tidy and indis when the time comes.
https://images.z1000sx.co.uk/ba561f83-5977-4857-abc8-e2211e294f45-1_all_84106.jpg
Anyway, soundbytes from the Black Widow and a 360°.
https://youtube.com/shorts/7w_3pmOG7TE?si=foRx-0o_xuVVyul4
Never argue with autism
Page 57 of 60
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 146.16 Kb
