Help!!! Moped won’t start
tobyrt96
PostPosted: 20:52 - 08 Sep 2025    Post subject: Help!!! Moped won’t start Reply with quote
Hi everyone, hope you’re well.
I’ve inherited a Honda Fes Swing 125 2008 from a friend, and I’m desperate to fix it.
My friend said the issue started suddenly one day when he was driving, the bike suddenly died. It did struggle or bog down, it just died. He started it again briefly, but it died minutes later and never started again.
I done some research into possible issues and assessed the bike (I am a complete novice, however I have an interest in gaining skills in fixing mopeds).
I had a quick look over the bike. When turned on, the dashboard and lights/ indicators all work. I replaced the spark plug and checked for spark, but I couldn’t see any spark coming from the spark plug. When I try to start the bike, a fast drumming like noise comes from the relay. I have attached a video of the noise. I believe this may indicate where the fault is coming from.
The bike starts from a remote key, the electric start button on the handlebar was disconnected by the previous owner, I’m not sure if this has something to do with it.
Any thoughts or advice would be greatly appreciated.
From the research I have done, I assume it’s likely it is an electrical fault rather than air/ compression, as the engine doesn’t even start.
Thanks, Toby.
Video: https://youtube.com/shorts/ybb9Ewz3pPA?si=21BI2Y6JK5yhNPFE
that_impulse_guy
PostPosted: 09:14 - 09 Sep 2025    Post subject: Reply with quote
the clicking noise sounds like it is the starter solenoid. If theres not enough juice in the battery it doesnt latch and will go into a latch/nolatch/latch doom cycle, which is the clicking noise.
this can be either flat battery due to age/non use
or flat battery due to charging circuit faulty (can only easily test this with the bike running)
or starter solenoid faulty
or starter motor faulty.
and its happened before
https://www.bikechatforums.com/viewtopic.php?t=326759
Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
doggone
PostPosted: 09:50 - 09 Sep 2025    Post subject: Reply with quote
It very likely has flat battery so needs charging or you could try it with jump leads from another vehicle.
If it spins over on starter after that at least it isn't seized.
Electrical problems are probably most likely.
Could just be loose or damaged wire.
WD Forte
PostPosted: 17:43 - 10 Sep 2025    Post subject: Reply with quote
its a scooter not a moped
bikers smell of wee
The last post was made 1 year, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 39.82 Kb
