Servicing an Indicator Switch
kawakid
PostPosted: 20:55 - 15 Oct 2025    Post subject: Servicing an Indicator Switch Reply with quote
On my ER6 , the turn switch is becoming a bit of a pain, in that I really have to push it, to cancel the indicator and I'm frequently leaving it on.
My son took his full A test on Monday (coming from A2) and he got a minor for leaving it on. Crying or Very sad
Are they easily serviceable or should I just change the switch gear.
Thanks Laughing
I've a twin and a 4.
PostPosted: 21:01 - 15 Oct 2025    Post subject: Reply with quote
My first port of call would be to spray contact cleaner or WD40 or the like in the button slot and see if that helps.
Triumph Trophy Launch Edition
PostPosted: 21:20 - 15 Oct 2025    Post subject: Reply with quote
As above, a scoosh of WD40 in the slot and work the switch a bit.
Better, open the switch, clean the moving parts with solvent contact cleaner then lubricate with silicone grease.
doggone
PostPosted: 08:04 - 16 Oct 2025    Post subject: Reply with quote
It's either worn or got some sort of debris inside, you could open it up for a look at what's going on.
kawakid
PostPosted: 10:03 - 16 Oct 2025    Post subject: Reply with quote
Thanks all, I didn't want to open it up before as not to jinx the bike before my son had his test.
I've ordered some silicone grease, I do have some contact cleaner, I'll open it up.
Son unfortunately didn't pass his test (so still stuck on A2) and I want it right before his 2nd attempt.
Kawasaki Jimbo
PostPosted: 18:36 - 16 Oct 2025    Post subject: Reply with quote
I once took a kill switch apart and it was tricky to get the tiny spring and plastic parts back into place (once I’d found the spring after it pinged across the garage). Hosing contact cleaner in hadn’t fixed the problem but opening it up and Emery-clothing the metal contact fixed it. An indicator switch could be the same but it might not need full disassembly. Good luck!
PostPosted: 23:32 - 16 Oct 2025    Post subject: Reply with quote
Yes, don't be afraid of opening up the switchgear housing itself, Usually two screws and it just undoes off the bar like a clamshell. You'll can see all the switches and things in there. You can usually get reasonably good access to the moving parts and contacts.
As Kasasaki Jimbo points out, stripping it further down from there is totally possible but with a vastly increased risk of small springs and ball bearings pinging off into a corner of the workshop and of you not being able to put it all back together again.
Copycat73
PostPosted: 09:50 - 17 Oct 2025    Post subject: Reply with quote
last one i did was a kawasaki zzr14 ..wd-40 is not a lubricant and proved to be a short lived solution.. took it off the handlebars and forced silicone grease into the workings with by thumb.. sorted.
caveat emptor
blurredman
PostPosted: 11:17 - 17 Oct 2025    Post subject: Reply with quote
Because of the dodgy indicator? Crying or Very sad
kawakid
PostPosted: 16:37 - 17 Oct 2025    Post subject: Reply with quote
Having rebuilt a freehub on my mountain bike earlier this year, its not something I ever want to do again...
jeffyjeff
PostPosted: 17:43 - 19 Oct 2025    Post subject: Reply with quote
I have had one experience with push-to-cancel turn signal switch gear. The sticky switch was caused by petrified grease in the mechanism. I cleaned that out with a cotton swab soaked in alcohol and lubricated the assembly with dielectric grease. I was surprised at the simplicity of design; one spring, one detent ball, and two switch contacts on a plastic pivot. Any three-handed person should have no trouble reconditioning their turn signal switch and have it working like new.
BanditsHigh
Worse than a woman
PostPosted: 19:46 - 19 Oct 2025    Post subject: Reply with quote
Copycat73 wrote:
... wd-40 is not a lubricant and proved to be a short lived solution ...
It is a lubricant, just not a very effective or long lasting one ... even says so on the WD40 website Thumbs Up
Easy-X
PostPosted: 21:26 - 19 Oct 2025    Post subject: Reply with quote
I believe the 'WD' in WD40 stands for 'water dispersant' which hints at its primary use Wink
to v or not to v
PostPosted: 06:35 - 20 Oct 2025    Post subject: Reply with quote
it makes for quite a good flamethrower too.
Moto Guzzi V7.
BanditsHigh
Worse than a woman
PostPosted: 11:24 - 20 Oct 2025    Post subject: Reply with quote
Agreed, specifically to prevent corrosion on missiles, but it's still a lubricant as well Thumbs Up
kawakid
PostPosted: 14:41 - 21 Oct 2025    Post subject: Reply with quote
Thanks all, I opened up the housing and the mechanism, well the metal plate was very rusty and the selector at the top had looked to have gone sharp.
I managed to clean it up (Without taking all the moving bits out/spring/ball bearing etc) I've greased it up with silicone grease and its soo much better.
jeffyjeff
PostPosted: 23:05 - 21 Oct 2025    Post subject: Reply with quote
kawakid wrote:
...I managed to clean it up (Without taking all the moving bits out/spring/ball bearing etc) I've greased it up with silicone grease and its soo much better.
Good on you, mate. Chalk up another DIY repair success story. May your achievement be an inspiration for others to trust their skills and try new things that they never did before. Cheers.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.38 - MySQL Queries: 13 - Page Size: 94.85 Kb
