| Bunzena |
 Bunzena Two Stroke Sniffer
 Posted: 11:36 - 28 Sep 2026 Post subject: Rapid Battery Drain |
Hi. Have fitted a brand new battery as bike wouldn't start.
Voltage showing on dash as 11.9 - and this corresponded to a multimeter reading too. Was original battery - 5 years old. Always been on a tender - but ho hum.
New battery [which has been fully charged] shows initial voltage [with ignition on] as 12.6 - and bike starts. However after 5-10 minutes voltage has dropped to around 12.0 volts and bike won't turn over.
There's no apparent heavy or even parasitic drain other than the LED lights. But can't see how these would have an impact in such a short time.
My suspicion is that the Regulator/Rectifier may be kapput?
Bike is a 5 year old NC750X - low mileage.
Any thoughts on what could be happening? |
| Rob W |
 Rob W World Chat Champion
| Bunzena |
| A100man |
 A100man World Chat Champion
 Posted: 15:37 - 28 Sep 2026 Post subject: |
could be a duff new battery - does it charge off the bike? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Bunzena |
 Posted: 16:33 - 28 Sep 2026 Post subject: |
I did think it might be the new battery - but the retailer [who was very pro-active] sent a new one I fitted this morning [after charging].
Had exactly the same issue.
When newly fitted and charged - showed a static 12.6v
After 30 minutes had fallen to 12.3v - now [6 hours later] at 12.1v
So there's a significant drain. I have heated grips and fog lights [using factory harness] - but they've been onboard for a while. The bike is garaged and has no corrosion. Earths look good.
So - and I'm guessing - the Reg/Rec may be playing up. Dodgy diode.
The Reg/Rec an absolute pig to get at. Petrol tank has to come out, rear mudguard, brake light, and multiple body panels off. Previous nakeds have always had the Reg/Rec in the airstream.  |
| Easy-X |
 Easy-X Super Spammer
| Bunzena |
| A100man |
 Posted: 18:02 - 28 Sep 2026 Post subject: |
| Bunzena wrote: | Thanks Easy-X
With the ignition off it's not registering any drain at all.
I guess that's possible?
Not likely on a modern bike I'd think - clocks and computers need to be kept awake, no?
Can you try pulling fuses in turn to see if it helps? Those electrons must be going somewhere! ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Bunzena |
 Posted: 18:55 - 28 Sep 2026 Post subject: |
Good thinking A100man.
I have a more modern multimeter on the way that might reveal more.
In the morning - I shall start pulling fuses...  |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Bunzena |
| doggone |
 doggone World Chat Champion
| A100man |
 Posted: 11:43 - 29 Sep 2026 Post subject: |
| doggone wrote: | If you pull the fuses in a rather dark place you will see a small spark most likely especially with a serious draw like that.
There aren't many things live with ignition off as a rule. |
You mean lights off or a rather sombre mood? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Bunzena |
