YBR ESD Power Loss
jeffyjeff
PostPosted: 19:09 - 12 Jun 2026    Post subject: YBR ESD Power Loss Reply with quote
12 June 2026
https://live.staticflickr.com/65535/54575078048_e81c6eccd1.jpg
2015 YBR125 ESD purchased new (old dealer stock) in 2019, 23100 km on the odometer. The ESD model has a carbureted engine (Mikuni BS25) sold primarily, dare I say, in the third world. The Pakistani YBRs are ESD models as are YBRs sold in Central and South America, to my knowledge. No electro-mechanical issues other than a TPS replaced at 20800 km. The bike is well-maintained (over-maintained to be honest) and runs better than it did when new…up until yesterday.
I was riding on Moroccan highway N6. It was 35 degrees C, and I was about 60 km into my trip and riding at 80 kph. Several km after turning the fuel tap to "reserve", the bike suddenly lost all power. To wit: instantaneous loss of throttle response and uncontrolled deceleration. After slowing to around 60 kph, the power magically returned. I kept riding, and after an uneventful 10 km, I started to think, "maybe that was just a little hiccup, nothing to be too concerned over." Then it happened again. No hesitation, no stumbling, nothing to indicate that the carburetor was starving for fuel; just an immediate loss of throttle and resulting deceleration. I thought "ignition power loss," but then I noticed my high-beam indicator illuminated even as the bike was in the state of power loss. As I slowed, the power immediately returned when I downshifted from 5th to 4th. Well that's odd. The glitch recurred 3 times over a 12 km stretch, and each time I was able to recover power by downshifting, except the last time required two downshifts to third before power returned. Six uneventful kilometers to the petrol station, where I filled the tank. I rode twenty-eight kilometers to home (after filling up) without any recurrence whatsoever. I had the fuel tap on reserve most of the way to see if that might be a contributing factor.
The instantaneous onset of power loss suggests ignition system failure, but it is odd that downshifting the transmission could bring about such an immediate return of power; coincidence? Maybe, but I have never experienced a repeatable coincidence like that.
I would normally dismiss the fuel system as the cause due to the split-second onset of symptoms, but it is hard to ignore that the problem manifested shortly after turning to "reserve", and only occurred when the engine was drawing fuel on the reserve standpipe.
I'm in Morocco until September. When I return, I'll probably have a spare fuel cock and an extra ignition coil in my bag. In the meantime, I intend to keep the fuel tap in the reserve position to see if that makes a difference. I checked the fuel filter (part of the petcock) and it was unobstructed. Once I run the tank down to less than 5 liters, maybe I'll drain it and remove/inspect the petcock. Specifically, I will be looking for a crack, hole, or damage to the shorter standpipe.
If anyone can suggest actions or observations I might make in the meantime, I'm all ears.
Thanks for reading.
History shows again and again how nature points out the folly of men. BOC
Getting old ain't for wimps. R.S. Hain
PostPosted: 20:51 - 12 Jun 2026    Post subject: Reply with quote
Well, a fuel tap obstruction seems possible.
Or even vapour locking in that kind of heat with a prolonged ride (fuel in the float bowl boiling). Especially with a small amount of fuel in the tank to get heated up.
jeffyjeff
PostPosted: 19:36 - 17 Jun 2026    Post subject: Reply with quote
stinkwheel wrote:
...Or even vapour locking in that kind of heat with a prolonged ride (fuel in the float bowl boiling). Especially with a small amount of fuel in the tank to get heated up.
Thanks for that idea. I had not considered vapor lock, last week the temperature around here got up into the low 40's and the bike performed normally (albeit with a little more fuel in the tank.) I spent part of 1976 in Arizona, and vapor lock was a common occurrence on some of the military vehicles we had in our fleet. Similar to fuel starvation, vapor lock would make the engine falter before stalling out altogether.
I did drain the carburetor, and found 5 or six small (<1mm) water droplets in the fuel. Morocco had an unusually wet winter this year. I'm wondering if maybe some water momentarily obstructed the main jet, and when I down-shifted the increase in vacuum caused the water to pass. Probably a little far fetched as theories go, but worthy of further investigation, I suppose. I intend to drain the tank, or at least measure rate of flow on the fuel tap normal and reserve positions. I will carefully inspect the fuel for water inclusion, especially from the reserve tap. Being in a rural area here, there is no fuel line available in the nearest village, and that has delayed me so far.
I also took a peek under the tank where the coil resides. It is covered in dust and the mounting bolts look a little rusty. I'll probably remove it for a good physical inspection and clean up of contacts and mounting points. It also occurred to me to inspect the magnetic pickup and circuit connections to the ecm.
This is a relatively remote area, and I really don't want to risk the bike taking a big shit miles from nowhere. Once i poke around a little bit, I'll feel a little better about venturing further afield. Hopefully I'll find something out of the ordinary.
jeffyjeff
PostPosted: 20:52 - 22 Jun 2026    Post subject: Reply with quote
Yesterday I drained 1.5 litres out of the tank on both fuel tap positions: 78.9 seconds on the run tap, and 78.4 seconds on the reserve tap; so there is no apparent obstruction in the petcock reserve position. Also, no evidence of water in the fuel whatsoever.
I checked the side stand switch circuit for continuity. Seems that a momentary open in that circuit could result in the symptoms I was experiencing without generating a check engine light. Especially considering the downshifts brought the engine back to life. Maybe it wasn't the downshift, but the clutch action (clutch switch closed) that caused the ignition circuit to reactivate. Possible, but does not explain why the engine kept running after the clutch was reengaged. I should keep a paper clip on the bike in order to bypass the side stand switch if need be. I did not trace the wiring further than the side stand switch and pigtail, so if the problem lies further inside the wiring loom the paper clip idea won't work. I do not intend to dissect the wiring harness until I'm more convinced that the problem lies there. In the meantime, I'll keep poking around looking for abnormality.
Upon removal of the side cover, I did notice that a wire for the carburetor heater circuit had come loose from the thermo sensor, but that is totally independent of the ecu and the ignition circuit.
WD Forte
PostPosted: 11:46 - 01 Jul 2026    Post subject: Reply with quote
Might be fuel might not.
Member the YBR that went from Bristol to Stornoway and back in a wet cold winter and got with 24 miles from home and suddenly stopped?
it started again then stopped but had to be shipped the last few miles home just in case
It was the EFI model and the fault code said 'bad coil' but that was bollocks
It was oxidised contacts on the regulator. Once they were
cleaned it ran just fine again.
the point?
check/clean electrical connections and grounds from time to time
but especially if experiencing intermittent problems
Also the side stand switches on YBRs have been known to cause problems and can easily be by passed if suspect
bikers smell of wee
jeffyjeff
PostPosted: 22:16 - 02 Jul 2026    Post subject: Reply with quote
So I took the bike out on my local test route last week, and the sudden no-power glitch manifested 4 times in 40 km under very similar environmental conditions. It happened with the fuel tap in both run and reserve positions, and in each case the power returned before I could even react; so there are two more data points. I decided to dive deeper into the ignition system, and was surprised at the apparent condition of the wiring upon removal of the fuel tank. Much of the harness was spotted with a kind of furry discoloration; resembling mold growth. Some of the exposed wire insulation also had dark spots. I cleaned up the harness with a damp rag and compressed air, and inspected the terminals at the accessible connectors, including the ECU and ignition coil. I removed the coil and cleaned up the spade terminal and mounting points with 400 grit sandpaper, then reinstalled and checked the spark.
I was surprised to observe a really weak spark. It was indeed a blue spark, but it was really small, a micro-spark that appeared to dance around the spark plug center electrode. I removed the coil once again and checked primary and secondary winding resistance against the manual specs.
My coil measured 0.9 ohms on the primary, and 7.84 k ohms on the secondary.
https://live.staticflickr.com/65535/55371031618_cd48e2f3c2_c.jpg
My coil has a single spade, like those on the 2005-06 YBRs and all XT models. As stated earlier, mine is a 2015 YBR ESD model, an orphan (at least in terms of available technical information), so I'm really not sure if my readings are out of spec or not.
On a hunch, I went down to my local hardware guy, who sold me a Chinese coil for a Honda GB125 (less than 5 quid!) that matched my OE coil dimensions exactly. It also matched my OE coil ohm readings exactly. I mounted it and found, unsurprisingly, no change in my weak spark condition.
Then I remembered that last year I had replaced the spark plug. My YBR takes an NGK CR6HSA spark plug. Last year, I found a set of four at an attractive price off Ebay. Oddly, they came in a Honda branded box (probably for a Honda inline four of some sort), but I really wasn't concerned about that much at the time.
https://live.staticflickr.com/65535/55370983643_3482b79398.jpg
I checked the spark on a used OE NGK plug and voila! The spark strength returned to about 80% of what I expected. I reassembled the motorcycle, and today I took it for a 60 km test ride with no recurrence of the issue.
So now my suspicions are focused on the spark plug. Perhaps I unintentionally installed a resistor type spark plug into a resistor type spark plug cap. Or perhaps I unknowingly obtained counterfeit NGK spark plugs that do not perform up to standard. Maybe both.
At any rate, that is where things stand today. Time will tell if the abnormal operation has been repaired permanently or temporarily.
WD Forte
PostPosted: 13:14 - 03 Jul 2026    Post subject: Reply with quote
Hopefully its fixed
the coil specs on your bike especially the primary suggest CDI ignition to me so you could probably swap out all manner of cheap GY6 coils an stuff to keep it running
Re the plug cap
The early CDI type CXs used resistor plug caps and they were notorious for rotting out internally so it if occurs again it's maybe worth checking
bikers smell of wee
jeffyjeff
PostPosted: 13:41 - 03 Jul 2026    Post subject: Reply with quote
WD Forte wrote:
....Re the plug cap..The early CDI type CXs used resistor plug caps and they were notorious for rotting out internally so it if occurs again it's maybe worth checking
Good to know, thanks. Haynes says the plug cap is 5k ohms. I tried to measure but the reading was all over the place. Right now, I'm using the cap that came fitted to the GB125 coil. It's a bit of a tight fit due to the angle that the lead connects, but useable. Interesting to learn that some OE plug caps have a finite service life. Maybe that was a contributing factor. Cheers.
twowheelwonde...
PostPosted: 08:27 - 21 Aug 2026    Post subject: Reply with quote
That furry green on the harness is copper corroding under the insulation, which gives exactly this kind of intermittent high resistance. Instant recovery with no light points at a connector or a safety switch, not fuelling. Worth a wiggle test with it running, and clean the side stand and clutch switches and the main earth.
jeffyjeff
PostPosted: 15:04 - 25 Sep 2026    Post subject: Reply with quote
UPDATE 25 SEP 26: I now have ridden the bike 1361 km since the power loss incident without recurrence. I recently performed the 24000 km service, which includes a valve lash check and adjust. Valve lash was within Yamaha specification. I opened the petcock to drain the tank, then tried to invert the tank to remove all remaining fuel. Unfortunately, the steel cup (with the fuel nozzle restrictor hole) prevented the unusable volume from completely draining out. I could have removed the petcock but was not inclined to do so. Peering inside with a torch, I did not find any debris in the tank. This whole ordeal has made me hypersensitive to consistent smoothness of engine operation, and I have experienced an occasional hiccup that, prior to June 12, I would not have given a second thought. These instances are rare, however, the last one occurring 540 km ago. I am inclined to believe that the coil and spark plug change has done more to alleviate the condition than anything else I have done. The bike is running great under some fairly extreme weather conditions. In the past month, the thermometer has reached 46C in my area, and I have ridden frequently in temperatures up to 42C after filling the crankcase with Shell Helix 20W-50.
sickpup
Old Timer
PostPosted: 07:19 - 27 Sep 2026    Post subject: Reply with quote
CR6HSA plugs are a resistor type plug, it's what the R in the name means.
jeffyjeff
PostPosted: 16:22 - 27 Sep 2026    Post subject: Reply with quote
Thank you. Can you comment on what the other letter designations stand for?
jaffa90
PostPosted: 19:33 - 27 Sep 2026    Post subject: Reply with quote
Google states,
Code BreakdownC: Specifies a 10 mm thread diameter with a 1.0 mm pitch, requiring a 16 mm hex wrench/socket to tighten.R: Indicates a built-in 5 k-Ohm resistor (radio muffled) used to suppress electrical and radio frequency interference (RFI).6: Represents the heat range index (on NGK's scale, lower numbers are hotter and higher numbers are colder, making 6 a medium-hot baseline typical for smaller 4-stroke engines).H: Denotes a 12.7 mm (1/2 inch) thread reach/length, categorized as a short base.S: Stands for a standard copper core center electrode.A: Signifies a special design or non-standard tip configuration differing from base models.
jeffyjeff
PostPosted: 23:44 - 27 Sep 2026    Post subject: Reply with quote
This is very informative, thank you. I find it interesting that Yamaha would specify both a spark plug cap with 5 k-ohms resistance and a spark plug with 5 k-ohms resistance. Clearly they have. I wonder why.
jeffyjeff
PostPosted: 13:04 - 25 Nov 2026    Post subject: Reply with quote
ANOTHER UPDATE: Only a few hundred kilometers since this overconfident post, and now the problem has returned with a vengence. Once again, 80 kph - 6600 rpm, total loss of throttle response and uncontrolled deceleration...exactly the same symptoms as occurred on 12 June 2026, only this time on a cool November afternoon. It happened six times on two rides over a two day period. Here is the interesting part: I have determined that it is not the downshift that restores my throttle response when this happens, but rather the clutch action. On the last four consecutive occurrences, I was able to restore normal engine operation simply by pulling and releasing the clutch lever. I have been able to confirm that my issue is not related to the side-stand switch, because that circuit is entirely independent of the clutch switch (side stand operation kills the engine when the transmission is in gear regardless the operation of the clutch switch). Apparently, my abnormal condition is ignition system related, but why? how?
My Haynes manual contains four wiring diagrams; two for the YBR and two for the XT125R. I have determined that the closest one that matches my bike is the 2005-06 YBR diagram because it is the only one that matches the 8 ECU wire connections and it indicates a single diode in the harness.
https://live.staticflickr.com/65535/55672607756_94d578793a_b.jpg
Tracing the clutch switch circuit (lower left corner) there is no direct or indirect connection to the ignition circuit, or the ecu for that matter. The clutch switch solely provides an alternate ground for the neutral switch in the starting circuit. I cut open the harness because I wanted to verify the number of diodes in the block. This is what I found:
https://live.staticflickr.com/65535/55672710753_e2c825044d.jpg
A single diode attached to a nylon block connector. I checked it with my meter set to the diode test position: OL in the reverse bias connection, and 0.439V forward bias. Haynes says check continuity, no specification other than that, so going by that, it appears that the diode is good.
AI says that the most common diode failure is to fail short circuit (conduct current in both directions). Could that be happening? What if my diode is intermittently failing short circuit? I traced out the clutch switch circuit to see what might happen if the diode failed- short, and indeed there is a connection to the ECU albeit through the neutral light filiment and the failed diode.
https://live.staticflickr.com/65535/55673018030_914fe09fef_b.jpg
So I'm thinking maybe I'll swap out the diode for a new one, but it will take awhile for me to source one and get it here. In the meantime, I intend to reassemble the bike and keep on riding. If the ignition loss happens again, i"ll keep a close eye on the neutral light when I operate the clutch lever. If I notice a blip on the neutral light, that would (in my mind) support my hypothesis.
I suppose this all sounds a little far-fetched; I swear I'm not making it up. If anyone on this forum has a comment or suggestion, I'd like to hear it. Thanks.
Rob Fzs
PostPosted: 13:11 - 25 Nov 2026    Post subject: Reply with quote
Are you sure its not seizing?
or your clutch switch needs bypassing.
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
jeffyjeff
PostPosted: 13:24 - 25 Nov 2026    Post subject: Reply with quote
I've seized enough two strokes to know a seized engine when I see one Wink no, this is definitely not that. Bypassing the clutch switch might allow the starter to engage a running engine if the start switch were to be accidentally bumped while riding.
no, this is different.
Rob Fzs
PostPosted: 13:32 - 25 Nov 2026    Post subject: Reply with quote
You're wasting hours on a 125 that you probably could have replaced the whole loom on by now.
Bypass the clutch switch like most normal people do, don't press the starter button while you're riding, like most normal people avoid to do and check the oil.
You might have even fouled the plug, this is all basics.
Easy-X
PostPosted: 12:52 - 26 Nov 2026    Post subject: Reply with quote
I don't think replacing the diode is going to do much. Looking at the wiring diagram...
1) If you removed the diode you could only start the bike by pulling in the clutch
2) If you bypassed the diode then the neutral light would come on when you pulled the clutch (but you should still be able to start the bike with either neutral engaged or the clutch pulled in)
Other than that, the clutch switch only offers an alternative ground path for the starter relay (which you stated already).
If pulling the clutch in is "restoring power" then either there's some wiring issue and the clutch switch is shorting something else to ground (other than the starter relay) or taking the load off the engine is what's having the real impact.
Some other things to bear in mind. Calling it an "ECU" is a bit generous as there's no control over fuelling via an injector. The unit controls timing (VR crank sensor input, coil output), provides a tacho output and controls the headlight. It's more like a smart transistorised ignition unit with a couple of extra features.
Depending on how smart the ECU is, it will have various ignition timing modes (acceleration, deceleration, starting) and it calculates which mode to be in from the crank position sensor. The problem here is separating out whether this is an electrical problem, a fuelling problem, or something else.
Given this is a carb engine, the amount of fuel and air drawn into the engine is dictated entirely by engine speed and how far the carb slide is open, the ECU only dictates timing of the spark. If one were to disrupt spark timing while still drawing in the same amount of air and fuel, I would expect misfiring and spluttering rather than a smooth loss of power Thinking
jeffyjeff
PostPosted: 20:42 - 26 Nov 2026    Post subject: Reply with quote
Thank you, Easy-X, for your thoughtful, logical comments. You're right that the term "ECU" is a bit of a misnomer, I only use it because that is how it is identified on the wiring diagram.
Due to the instantaneous onset of power loss and the restoral of throttle response via clutch operation, I tend to lean toward the abnormal engine operation being electrical in nature. Point well-taken that it could be a fueling issue or something else, but the symptoms suggest to me that if the cause is not electrical in nature, then it is probably "something else".
As stated earlier, my bike is an orphan, and I am not entirely sure that the diagram I am following accurately represents the electrical system on my bike. My carburetor has a throttle position sensor on it, although nowhere to be seen on the diagram. So the ECU has the TPS and the crank position sensor to compute spark timing, and one output to the ignition coil. How the clutch switch figures into the equation is anyone's guess. It might well be necessary to do a little exploratory surgery on the wiring harness to see if there is evidence of errant electrical contact (or ground) between circuits.
Compounding my problem is my travel schedule this year, which will prevent me from focusing on the issue in a way that might result in a speedy solution.
I think, to begin with, I am going to remove the diode and continue riding. If/when the power loss returns, the bike's response to clutch operation will indicate which side of the diode to focus my diagnostic attention. If clutch operation continues to restore throttle response, then the clutch switch is abnormally affecting one of the ECU inputs, power, or ground. If clutch operation fails to restore throttle response, that would suggest that the diode is integral to power recovery when the symptoms manifest. Hopefully, if I can determine why the clutch operation is restoring throttle response, it might lead me to the source cause of the power loss. At least that is something I can do now without violating the wiring harness too much.
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.06 - MySQL Queries: 13 - Page Size: 124.92 Kb
