my bikes seized but witch parts
killergibbo
PostPosted: 01:21 - 15 Apr 2005    Post subject: my bikes seized but witch parts Reply with quote
well ive got a rs125 2002 model
its not had any oil in the gear box it was empty the bike has seized becuase i can not push the bike forward in 6th gear
the elec start dont work it just ticks tryin to turn the motor
but what i wanna know is what will i need to replace it never seized because of not havin 2t is cos there was no oil in the gear box will i need a new gear box??
Matt2301
PostPosted: 03:13 - 15 Apr 2005    Post subject: Reply with quote
sorry mate but it sounds like you fooked that bike right up. However, ill try and help. So what are you trying to say, that you let the gearbox oil run out totally?
killergibbo
PostPosted: 03:31 - 15 Apr 2005    Post subject: Reply with quote
ok i got the bike from a shop yesterday and they sold it me with out engine oil in it the bike is second hand and i have no watty
we r goin thought the stages of me tryin to get my money back so if i dont i wanna know if i can fix it
ok there is no oil in the gear box the back wheel slides wen in 6th gear but i can pull the bike backwards wen in gear with cluth out
i want to know if its the gear box that will be fucked or if it will be the whole engine i really need sum help on this 1 sum1 plz help me
the bikes a rs125 2002 gp1
the bike cost me £1700
how much will parts cost me if i can do it surly the bike aint trash it must be able to fix it
Ric
PostPosted: 04:21 - 15 Apr 2005    Post subject: Reply with quote
siezed usually means the piston i thought, which will mean in gear it wont turn at all, pullin in the clutch will let it wheel
the gear box oil should have affected the piston, as only 2t oil would
i assume the gear box has done summin untoward, sorry mate
killergibbo
PostPosted: 01:51 - 16 Apr 2005    Post subject: Reply with quote
so i need a new bottom end so whats the bottom end lol i mean do i just get a new gear box or what ?
Patto
PostPosted: 02:40 - 16 Apr 2005    Post subject: Reply with quote
Just to get the facts straight , if you are talking about a seized gearbox then the engine should start and run ok.
If it won't start off the button due to a transmission fault ie. locked into a gear or two then pulling in the clutch should get it to turn over and start,
If it won't then the clutch has a clearance/ release problem
if the transmission is dry the the clutch will likely be fried
Thats one problem and the reason it will not crank
secondly 6th gear sounds like it may have welded it self to a shaft
with excessive heat.
A gearbox/ engine strip will be needed to determine what parts are defective.
So an example shopping list may be:-
A set of clutch plates poss clutch basket etc
6th speed gear
shaft
bearings
gasket set
after costing that lot and labour for a mechanic to do it for you
you might decide to try and find a engine from ebay or a breakers
as being a cheaper option.
although I have no personal experience of that particular aprillia bike only the af1, and have only rebuilt Suzuki motors. I think it would apply to most 2 stroke setups.
best of luck
hope you get your money back
1700 is a lot for duffa
Patto
when the missus don't play, stick "her" in the shed and get the bike out
ZRX61
Victor Meldrew
PostPosted: 04:26 - 16 Apr 2005    Post subject: Reply with quote
Good fucking grief, learn how to read/write English & start again FFS! Rolling Eyes
R4nger
PostPosted: 10:57 - 16 Apr 2005    Post subject: Reply with quote
Warrenty does not matter from the shop whatever it says, it just adds to your existing consumer rights. You should get your money back. Go speak to your local CAB and Trading Standards.
houlsby
PostPosted: 11:33 - 16 Apr 2005    Post subject: Reply with quote
where ever you bought it from go back, take the bike with you and get your money back, if the fault is yours i.e you knew it had no gearbox oil in the bike then it is YOUR responsability. but otherwise get them to either: give you your money bk or take them to court, but for 1700 quid it must of done a few miles, if your bike isnt turning over then its possibly your engine thats seised (i dont know much but mine has done the same) and i have had 2 new engines in 2k hope this hleps m8
R4nger
PostPosted: 11:45 - 16 Apr 2005    Post subject: Reply with quote
Mind you, the pre-ride inspections do say that you have to check oil levels so if he did go to court then the dealer could argue that he did not do his checks and therefor it is his own fault.
If they did not tell you it had no oil and you can prove that bikes normally have oil in them when sold.
killergibbo This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
houlsby
PostPosted: 09:39 - 17 Apr 2005    Post subject: Reply with quote
have you spoke to the dealer yet?
BikerBen
PostPosted: 11:49 - 17 Apr 2005    Post subject: Reply with quote
This post could have been resolved in 3 threads for crying out loud. If you just explained clearly in the first place there wouldn't be all this confusion. I hope people read robby's new post about spelling out problems clearly with correct grammar.
*sigh* Rolling Eyes
My NSR --> https://members.boards.ie/instinct/Diagonal.jpg
Now proud owner of a 1999 ZXR 400
The last post was made 21 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.01 - MySQL Queries: 13 - Page Size: 75.52 Kb
