bandit oil leak
MZ125
PostPosted: 17:42 - 16 Apr 2005    Post subject: bandit oil leak Reply with quote
I was just wondering i have got a oil leak on my bike near 2 the
starter motor the bike is a bandit 600 it only leaks when switch off
there is always a little bit of oil on the ground i was just wondering could this be the gasket has got a small gap & how hard would this job be to do hence replace gasket i have not taken a bike apart before but want 2 do the job myself any advice much welcome cheers
sorry 4 the long post
bandit 600 honest i dont brake the speedlimit I just dont stick 2 it
Guest
PostPosted: 18:47 - 16 Apr 2005    Post subject: Reply with quote
Are you sure it's not just chain lube dripping off the front sprocket area - it collects behind the casing and drips down when the bike's stood.
MZ125
PostPosted: 19:16 - 16 Apr 2005    Post subject: Reply with quote
yeah i am sure it not chain lube cos there is 2much there at times but it might b excess not sure Sad but i think the seal has gone Question
katana
PostPosted: 12:32 - 18 Apr 2005    Post subject: Reply with quote
Mine had this problem, I cured it by replacing the seal behind the front sprocket, the seal around the gear change rod, and the seal around the gear change rod.
Be careful when installing the gears not to damage the seals when installing them and not to move the gearchange rod around as you may not being able to change gear, as I did, but a quick dismantle and wiggle of the change and it all cae back good.
Hope it helps.
garry
PostPosted: 00:36 - 19 Apr 2005    Post subject: oil leak Reply with quote
katana has prob got it right , its prob the seal behind the drive sprocket , which will heat up and expand (seal the gap ) as the bike gets warm , and will contract (expose the gap ) as engine cools .. not a big job , just be carefull as katana says , not to damage the new seal putting it in ..
have fun Laughing Laughing
The last post was made 21 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 43.28 Kb
