rs125 siezed chain adjuster nut
TOM M
PostPosted: 00:32 - 18 Apr 2005    Post subject: rs125 siezed chain adjuster nut Reply with quote
the left chain adjuster nut is siezed on me 2001 rs125, any ideas how to free it? ive tried loosening it with loads of wd40 and the spanner but its stuck solid and will probably round off?
2Smoke
PostPosted: 01:26 - 18 Apr 2005    Post subject: Reply with quote
Hi there pretty hard to get at that nut so the best thing to do is to try a proper penetrative fluid. Find your local bike shop that stocks Wurth products and buy a can of 'rost off'. spray a load of this on and leave for 20 mins. Should do the trick. Otheriwse take the wheel and adjuster plate out and get a punch in there to free the bugger off. Damned italian metals eh!
Good luck!
Paul
Scotsman37
PostPosted: 01:38 - 18 Apr 2005    Post subject: Reply with quote
Have you tried using 3in1 Penetrating oil and so you leave it over night to allow it to penetrate the threading.
You could try extending the leverage on the spanner with a tubular bar which will give you more turning power, but I would do the penetrating oil first before attempting it.
When you do get it off smear the threading with copper grease to prevent future seizing of the nut on the thread. You can buy that copper grease at Halfords or any good motorcycle dealer.
ZRX61
Victor Meldrew
PostPosted: 15:54 - 18 Apr 2005    Post subject: Reply with quote
AND!!! use a 6point socket.....
PostPosted: 22:48 - 18 Apr 2005    Post subject: Reply with quote
Is the lock nut undone?
I would suggest spraying loads of proper penetrating oil oil on them and leaving them for a bit. Then hold the back of the bike up and take the back wheel out. This should mean that you can take all the adjuster blocks out of the way then use a socket on the bolts from directly behind.
And do as ZRX61 says use a 6 point socket.
TOM M
PostPosted: 23:07 - 18 Apr 2005    Post subject: Reply with quote
i think im gonna have to take it to a bike shop to be done as i havent got any paddock stands and me dads working away in norway, and i cant hold the bike up and take the wheel off etc.
cheers for the advice though
tom
westendboy7
PostPosted: 23:39 - 18 Apr 2005    Post subject: Reply with quote
Hi. Have you got a nut splitter? Or perhaps you could use a blow torch to heat the nut. Also you could try mole grips
PostPosted: 00:09 - 19 Apr 2005    Post subject: Reply with quote
Not space for a nut splitter there. Using a blow torch will wreck the finish in a fairly obvious place. Mole grips would be too bulky to get a decent grip and damage the bolt so that you would not be able to use a socket.
The last post was made 21 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.82 - MySQL Queries: 15 - Page Size: 55.92 Kb
