Wave discs - any good?
McJamweasel
BCF Junkie
PostPosted: 23:54 - 19 Apr 2005    Post subject: Wave discs - any good? Reply with quote
Just like it says on the tin really, has anyone actually used them and if so how do you rate them?
Going2fast
PostPosted: 00:00 - 20 Apr 2005    Post subject: Reply with quote
Never used them but from what i know /very limited/ they are good for getting rid of the heat generated. So all in all on the road you prob only see a slight increase in performance but on the race track alot.
As said thats from a very limited knowledge i have Embarassed
Andy
Passed My Test 15/03/05 Very Happy Very Happy
BikePics Profile ||| 96' RVF 400 ||| 01' CBR 600 F Sport ||| 2009 Yamaha YZF-R6 Delivered 23/06/09
/-\ndy
Frost
PostPosted: 00:17 - 20 Apr 2005    Post subject: Reply with quote
Wavey front disc'c are for tart value only. Unless your thrashing it round a track your very unlikely to get the disc'c hot enough to require waveys.
A wavey rear disc is something i would consider as i use the rear brake alot and standard ones can get quite hot after i've been abusing them on a long ride.
Sparks!
Sir Tart-a-lot
PostPosted: 00:20 - 20 Apr 2005    Post subject: Reply with quote
Mmmmmmm wavey discs Drooling
p.s discs are mostly tart, if you want to stop quicker then change your caliper.. most brake improvements IMO are in the lines, pads, caliper, m/cylinder and finally the disc.. in that order.. IMO.
Shaun
Likes 'em bent
PostPosted: 00:26 - 20 Apr 2005    Post subject: Reply with quote
In the same post you said they're for tart value only! Rolling Eyes
Sparks!
Sir Tart-a-lot
PostPosted: 00:28 - 20 Apr 2005    Post subject: Reply with quote
Read his post again.. he said tart value because you don't get them hot enough on the road, however he sits on his rear brake which makes it really hot so a wavey might be of use..
Turbo Busa
PostPosted: 00:30 - 20 Apr 2005    Post subject: Reply with quote
Cosmetic value only, far better ways of spending your money to improve your braking
Sparks!
Sir Tart-a-lot
PostPosted: 00:31 - 20 Apr 2005    Post subject: Reply with quote
But tart, is good Wink
https://www.cwimedia.co.uk/other/misc/Bike%20Pics/My%20KTM%20450%20EXC/New%20Pictures/disc-caliper.jpg
I'm suprised zxr400er hasn't auctioned off his parents in order to afford some wavey discs for his zxr400tartmobile yet.. hehe
Johnny GSX-R
PostPosted: 00:33 - 20 Apr 2005    Post subject: Reply with quote
Had them on my BIRD for a few weeks and quickly removed them as they were pants. I felt a lot of flutter through the front brake lever and found they were grabby at low speed. Thumbs Down Thumbs Down
Shaun
Likes 'em bent
Unless he sits on his rear brake for the whole ride out then it obviously won't get hot enough unless he is on a track will it! Confused
Just seems a bit like he is criticising something that he hasn't got to me!
Sparks!
Sir Tart-a-lot
PostPosted: 00:34 - 20 Apr 2005    Post subject: Reply with quote
He is right though.... Wink
Dr Nick
PostPosted: 00:41 - 20 Apr 2005    Post subject: Reply with quote
Yams wrote:
All you need is a working bike to put them on Wink
is that it
Frost
PostPosted: 00:43 - 20 Apr 2005    Post subject: Reply with quote
That clear enough for you shaun?
As i said front disc's are big enough and with the load and heat spread betwean 2 large discs directly in the airflow its going to take some real hero riding to get the front disc's hot enough to justify Wavey's.
Sparks!
Sir Tart-a-lot
PostPosted: 00:44 - 20 Apr 2005    Post subject: Reply with quote
3 weeks Wink And the discs are already fitted Razz Laughing
Reevo8
Guessing they are to take away the problems of heat fade! If you have chnged the pads, and the lines I would say maybe go for the disc as the other bits should be fine!
05 ZX10R, (**05 WKR) Very Happy
Shaun
Likes 'em bent
PostPosted: 00:52 - 20 Apr 2005    Post subject: Re: Wave discs - any good? Reply with quote
Was that not clear enough for you martin?
Frost
PostPosted: 01:02 - 20 Apr 2005    Post subject: Reply with quote
I've used them, can't say i noticed any difference, but then i hadnt ridden the bike before it had them fitted.
From all the reviews i've read of them, and comments from everyone i've heard who has them, heat is the only thing they mention.
They are obviously designed to behave exactly like normal disc's only be more effective at dissipating heat, which they do very well.
The issue isnt how well do they dissipate heat, but one of do you actually need greater heat dissipation. If your going on track a great deal, then yes you probably do. Otherwise no you don't.
If you don't NEED the discs then you could still get them, but they would only serve to mike your bike look better rather than effect performance noticeably.
Stop trying to highjack the thread with pathetic nit picking shaun.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 10:39 - 20 Apr 2005    Post subject: Reply with quote
DaFrostyOne wrote:
they would only serve to mike your bike.
No thanks Razz
Oh and for my 2 pence... Mcjam does actually know what a track looks like. I.e, not wholly tart value by your first point Martin.
McJamweasel
BCF Junkie
PostPosted: 10:45 - 20 Apr 2005    Post subject: Reply with quote
maurice wrote:
... Mcjam does actually know what a track looks like....
Yeah, its that grey blur that goes past your head as you bounce a bit. Razz
What discs would you lot recommend then? Mine will be coming up for replacement soon-ish and I'm thinking that I may as well spend a bit more on some better ones than standard. They will be used for the road and in the wet and money is definately not unlimited - that counts out a PFM conversion then! Razz
sickpup
Old Timer
PostPosted: 11:23 - 20 Apr 2005    Post subject: Reply with quote
It is possible to overheat your brakes on the road. I turn the front discs blue on my Fireblade through heavy breaking, I go through 2 front tyres to each rear but I'm a heavy front end rider and no my brakes aren't seized.
If the disc makes so little difference why do A.B.E. make three different compound discs depending on usage?
Wavey discs do shed heat quicker and also skim the pads clean constantly so yes they should break quicker but also shred pads. A lot of the breaking ability comes down to transference of heat so high Iron content discs will always work best regardless of the pettern.
PostPosted: 15:06 - 20 Apr 2005    Post subject: Reply with quote
I am dubious that they will do anything to stop themselves over heating. Less surface area that a conventional disk, and also less metal in total so they will heat up more quickly.
What they will do is skim a layer from the top of the pad as an edge passes them, and also allow the escape of the layer of gas that is generated between the disk and the pads.
mchaggis
PostPosted: 15:14 - 20 Apr 2005    Post subject: Reply with quote
To be honest, I don't think that they'd do that any better than grooved and/or drilled normal discs. Heat dispersal, pad cleaning and allowing the gas and associated powder to escape are what drillings are all about afterall.
I must not be a troll...
Mmmm, Guinness
PostPosted: 15:34 - 20 Apr 2005    Post subject: Reply with quote
I agree with you. Suspect they do a better job than most drilled disks, but grooved disks will do much the same job (except the grooves seem to disappear with age).
Akiraprise
PostPosted: 19:40 - 20 Apr 2005    Post subject: Reply with quote
I heard that wavey disks help increase braking power due to the overall mass of the disk is alot less than a conventional circular disk and hence needs less braking power to slow down.
I've not actually used them so cannot say whether this is true or not but I heard that off of Bikes Aloud or something (a program on men and motors).
May be wrong - anyone care to correct me?
mchaggis
PostPosted: 19:55 - 20 Apr 2005    Post subject: Reply with quote
The rotational inertia of those wavy discs will be negligably less than conventional circular ones. The amount of brake force used to slow the brake disc is a negligible part of the overall force used to slow the bike. A red herring methinks.
To increase the braking force, either increase the brake pressure, the effective radius of the brake disc, reduce the rolling radius, and/ or increase the coefficient of friction between the disc and pads.
Mmmm, Guinness
The last post was made 21 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.24 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 133.46 Kb
