APRILIA RS125 EXTREMA WENT BANG!!!!
john0207
PostPosted: 22:09 - 19 Apr 2005    Post subject: APRILIA RS125 EXTREMA WENT BANG!!!! Reply with quote
WELL I DIDN'T REALLY GO BANG, I WAS RIDING HOME AS NORMAL AFTER WORK AND WHEN I STOPPED STEAM ERUPTED FROM THE BIKE. IT DROPPED COOLANT BUT NO OIL ,BUT LET GO A LOT OF STEAM.I JUST FITTED A PIPERCROSS AIR FILTER AND A NEW CLUTCH CABLE AND IT RAN LIKE A DREAM ON THE WAY TO WORK BUT NOT SO ON THE RETURN JOURNEY. IT DID BUMP START WHEN I GOT HOME BUT WOULD NOT START FROM THE BATTERY. OK SO I THOUGHT MAYBE THE SPARK PLUG WAS KNACKERED. SO I PUT THE STANDARD PLUG ON AND BUMPED IT AND I RAN BUT IT WAS VERY ROUGH. STILL NO OIL COMING OUT BUT I FEAR A NEW ENGINE OR A VERY SERIOUS REBUILD IS REQUIRED.
PS
WHEN I TRY TO START ON THE BATTERY IT SOUNDS LIKE ITS FLOODED, TURNS OVER BUT DOES NOT FIRE, BUT WILL AS I SAY BUMP START..........
SORRY TO RANT , BUT I WAS REALLY LOOKING FORWARD TO THE SUNNY DAYS OF RIDING, AND NOW I DONT THINK ILL BE ABLE TO PAY FOR THE PETROL............
(1994 RS 125 EXTREMA) ROTAX 123 ENGINE I THINK)!!!!!!!!!!!
CHEERS IN ADVANCE FOR ANY HELP
REGARDS
JOHN
PostPosted: 23:15 - 19 Apr 2005    Post subject: Reply with quote
Where is the water coming from?
Best case scenario you have just dislodged a clip on a water hose when fitting the cable / filter.
Bomberman
PostPosted: 03:43 - 20 Apr 2005    Post subject: Reply with quote
DID YOUR CAPS LOCK BUTTON EXPLODE AT THE SAME TIME? Wink Very Happy
john0207
PostPosted: 20:49 - 20 Apr 2005    Post subject: Reply with quote
caps lock now fixed thanks
but bike is still buggered
you are probably right about the pipe coming off as the water appears to be coming from that area (rad) . but i would of thought it would have blown off due to the pressure i.e head gasket, ive been told its probably the piston or a piston ring that goes first usually. so some engine work will be required.
i am thinking the worst, there is a rotax 123 engine on ebay for £160 which would be an easy fix but i wouldn't know the condition of the engine until its fitted
rotax 123 for 1994 aprilia is correct i think?????????????
cheers
john
PostPosted: 01:00 - 21 Apr 2005    Post subject: Reply with quote
Doing the head gasket on a Rotax 123 engine is very easy. The "gasket" is 3 rubber O rings. One seals the head to the barrel (the only one that is under real pressure), the other 2 seal the cylinder head cover to the barrel / head.
This is certainly far easier than swapping the engine over.
Check where the water is coming from exactly as that should let you know.
It is possible that it has snapped a ring, especially if it has seriously overheated. Best thing to do there is a compression check to see how it is.
The last post was made 21 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 47.09 Kb
