Spray Painting Fuel Tank
soad
PostPosted: 10:49 - 20 Apr 2005    Post subject: Spray Painting Fuel Tank Reply with quote
I am about to go and spray my fuel tank. I have sanded it down to get rid of the shiny surface. Do i need to put a layer of primer on or can i just spray the paint direct onto it?
Barry_M2
PostPosted: 10:50 - 20 Apr 2005    Post subject: Reply with quote
Are you doing it the same colour?
soad
PostPosted: 10:51 - 20 Apr 2005    Post subject: Reply with quote
Yes same colour (blue)
Only thing is, where i had to use a file to get the decals off there is some little bits of metal showing as the file totally took off the paint, should i spray these small bits with primer or will it be ok?
ZRX61
Victor Meldrew
PostPosted: 15:39 - 20 Apr 2005    Post subject: Reply with quote
Yeah, just spot prime it where the metal is showing & then throw the paint on. If the only things showing are blue & bare metal you'l be fine... if there are other colours showing where ya feathered it out then ya could throw a coat of sealer on it to stop bleed thru.
Barry_M2
PostPosted: 15:45 - 20 Apr 2005    Post subject: Reply with quote
Make sure its totally flat where your paint has chipped, you'll need to rub it back if its not or the finish will not be that good.
If you've gone down to bare metal, you will need to primer it.
thuganomics16
PostPosted: 00:17 - 21 Apr 2005    Post subject: Reply with quote
The chances are once the paint is on you will see loads of marks which were very difficult to see before, if you are unsure of anything your best bet is to stick on a tiny bit of filler on the bare metal and sand it down to make a nice smooth surface, then prime it. If you do decide to do this and need help with anything let me know.
However if you do decide to spray the bare metal with primer dont just slap the paint on afterwards, MAKE SURE YOU FLATTEN THE PRIMER with a very fine grade of wet and dry otherwise it will be very noticeable after the final coat of paint is on.
hope this helps mate Very Happy
thuganomics16
PostPosted: 00:20 - 21 Apr 2005    Post subject: Reply with quote
oh almost forgot when flattening the primer with the wet and dry make sure it is very wet or you will cock it up even more lol best of luck Very Happy
bumper
PostPosted: 13:12 - 21 Apr 2005    Post subject: Reply with quote
Also before you prime it use a rag and some thinners and wipe over the whole of the tank to make sure there is no silicone particles on there other wise you may find a reaction will eccor which will leave little dimples in your paint work which you will not be able to paint over......
plugger147
PostPosted: 22:09 - 22 Apr 2005    Post subject: Reply with quote
And if it's been painted before (other than original)it may be worth putting a cote of barcoat over it to stop reaction between the new paint and the old stuff(you'll know if it reacts when you put the primer on).I like to prime thing's at least the day before so the primer sinks,if there are any outlines where the metal spots where flat it down and prime again.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
The last post was made 21 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 59.9 Kb
