Aprilia RS 125 Engine -----HELP!!!!!!!
RS125_Tecky
PostPosted: 18:47 - 20 Apr 2005    Post subject: Aprilia RS 125 Engine -----HELP!!!!!!! Reply with quote
I have a 2000 model full power RS 125 With 15,000 kms on the clock. Its been working mint since I got it in August last year but recently the engine has lost power somewhere.
Firstly from 2,000 to 5,000 rpm the bike starts dieing and tries to cut out, you have to keep on the cluth to get it going why is this happening???
Also the power valve isnt as responsive as it was, from 4th gear its struggles when it gets to 8,000 rpm and slowly builds up to 11,000 rpm even though it used to fly from 8,000 rpm to 11,000 rpm in all gears???
Ive had a new piston kit put in less than 50 miles ago and the air filter and power valve were both cleaned out!!!!
CAN ANYONE PLEASE HELP AS ITS REALLY PISSING ME OFF, CHEERS Very Happy
[/b]
PostPosted: 18:54 - 20 Apr 2005    Post subject: Reply with quote
I really hope you are not taking it to 11000rpm only 50 miles after a new piston was fitted.
Have these problems occured just since the piston was fitted?
Rough ideas, power valve sticking, power valve upside down, piston wrongly sized (there are several sizes to get the clearance correct for the barrel), blocked air filter, blocked carb jet, etc.
RS125_Tecky
PostPosted: 18:59 - 20 Apr 2005    Post subject: Reply with quote
I havent bin taking it to 11,000 rpm since the new piston but the problem was happening before the new piston and i thought a new piston would help, but obviously it hasnt.
Ive cleaned the air filter and power valve out but not the carb, i will try that.
PostPosted: 19:10 - 20 Apr 2005    Post subject: Reply with quote
That is strange. It has just lost power, not misfiring or anything? Is the idle at normal revs? Not overheating? Can you see the power valve operating (should be visable on the solonoid under the tank, it should be open below 2500rpm and close from there to around 8000rpm where it opens again)?
Without looking I am at a loss with what you have said so far without clutching at straws (eg, 2 stroke oil pipe disconnected, gearbox oil very low, someone shoving something in the silencer).
RS125_Tecky
PostPosted: 19:37 - 20 Apr 2005    Post subject: Reply with quote
the bike isnt misfiring or overheating, where should the idle be???? When i lift the tank up where abouts should i look to see the solonoid to see if its opening at 2,500rpm?????
cheers for the help
PostPosted: 19:48 - 20 Apr 2005    Post subject: Reply with quote
Idle on the RS125 is "1500rpm, plus or minus 100."
I reckon it sounds like fuel starvation, cleaning the carb out might help. Also make sure that the power valve is correctly adjusted, opening when it should be.
Cant add anything as Kickstart has said most of the likely possibilities. Razz
Good luck. Thumbs Up
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
RS125_Tecky
PostPosted: 20:05 - 20 Apr 2005    Post subject: Reply with quote
How do I check that the power valve is correctly ajusted??
Lee_367
PostPosted: 21:51 - 20 Apr 2005    Post subject: Reply with quote
Try this, its out of the owners manual. Very Happy
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
PostPosted: 01:16 - 21 Apr 2005    Post subject: Reply with quote
The solonoid for the power valve is a gold coloured cylinder on the inside of the r/h frame rail.
The last post was made 21 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 63.13 Kb
