| themadatter |
 themadatter Nova Slayer
 Posted: 01:46 - 21 Apr 2005 Post subject: CG125 RAN OUT OF OIL ! ADVICE ? |
Hi there,
My CG ran out of oil.
It was going fine..better than fine even.
And then it just conked out, like running out of petrol.
Wen it came to a halt it gave a little pop, and that was that.
Wont start.
100% out of oil WOOPS
will turn over with the kick starter.
There was no knocking before hand.
I can smell burning oil when i try to start it so im thinking this could be a simple ring failure ?
Should I tear it apart and expect to replace piston and bore or should I not even bother and source a new engine ?
Anybody done this before.. ?
Thanks for any help
Jamie |
| Flip |
 Flip Super Spammer
 Posted: 01:56 - 21 Apr 2005 Post subject: |
Do you not have an oil light?  |
| mchaggis |
 mchaggis World Chat Champion
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 02:05 - 21 Apr 2005 Post subject: |
There's no oil in it at all?
You may have fused the engine parts together which got no oil!
Try filling it up with more engine oil because it's cheaper than buying a used engine to see if the original one still works either that you've got an oil leak some where on your bike - possibly requiring a new gasket set?
Can you not find any signs of leakage ? |
| themadatter |
| ZRX61 |
 ZRX61 Victor Meldrew
| Adam_P |
 Adam_P World Chat Champion
 Posted: 18:28 - 21 Apr 2005 Post subject: |
Hmm, running out of oil on a 125.... expensive.
I almost did that on my KH125 years ago. It coughed and spluttered just as I got to the garage. Bought a couple of litres of oil, poured in and left to gently tick over and bleed itself in. 'twas fine.
But sounds like you've run a bit farther past that point though.
Means you'll spend more time checking it in future. (We all go through this phase, it's only natural! ) ____________________ Colin McRae MBE 1968 - 2007 RIP
Orwell Rolls in his Grave
God is imaginary |
| Aikman666 |
 Aikman666 World Chat Champion
 Posted: 18:57 - 21 Apr 2005 Post subject: |
If its a 2 stroke and it has lost compression then there will be no force pumping the oil round, chances are your rings blew, lost compression and you have a shit load of oil sitting in your crank case..thats me assuming its a 2 stroke? ____________________ Will work for petrol
My Design Blog |
| mchaggis |
| lurker |
 lurker Trackday Trickster
The last post was made 21 years, 162 days ago. Instead of replying here, would creating a new thread be more useful? |
