brake questions
White Noise
Mr Dudwee
PostPosted: 14:30 - 21 Apr 2005    Post subject: brake questions Reply with quote
i have a few questions regarding brakes and wonder if anyone can answer them
cheers
1) what sort of gap should there be between the pad and the brake disc when not in operation?
2) in normal operation there should be no contact with the disc and the pad, i am sure no contact!
3) what actually pulls the piston away from the disc once the brake lever has been released? it the hydrallic pressure?
i am asking this as i have reattached the back brake to my bike and the pads grip the disc but don't seem to pull the pads far away enough from the disk when realised!
could this imply a problem with the master cylinder?
WN
Mr.Everready
PostPosted: 14:55 - 21 Apr 2005    Post subject: Reply with quote
look at your front pads ! Very Happy
You should see no space between the pad and the disk. It isnt like a push bike.
feef
Energiser Bunny
PostPosted: 14:56 - 21 Apr 2005    Post subject: Reply with quote
There's near enough no VISIBLE gap between the pads and disk... it's just not exerting any pressure on the disk with them when "pulled back"
in some cases, you can even hear an ever so slight drag on the pads when wheeling the bike about with the engine off.
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
skyline
PostPosted: 14:57 - 21 Apr 2005    Post subject: Reply with quote
In operation there should be no contract correct, but it may still look like they are very very close
mchaggis
PostPosted: 15:06 - 21 Apr 2005    Post subject: Reply with quote
Normally, the movement of the disc will push the pads slightly away, and the rubber piston seals will do a fair amount of retraction too. They are dragged out by the piston as it moves, and will pull it back to return to their original shape.
I must not be a troll...
Mmmm, Guinness
White Noise
Mr Dudwee
PostPosted: 15:41 - 21 Apr 2005    Post subject: Reply with quote
its just on my ride to work this morning i used very little back brake and a lot of front, then once i got to work i touched the discs and the back one was hot and the front was cold implying that the rear pads have been rubbing the rear disk! which is not normal and not good as i fear i will warp the disc!
I have just put new seals in and the brakes don't seem to retract enough! Crying or Very sad
I figure i am looking to be able to ride the bike without touching the rear brake and the disc should not be getting hot!
Looks like i will be taking the calipers off again tonight!
WN
LustyLew
PostPosted: 16:03 - 21 Apr 2005    Post subject: Reply with quote
I have a similar problem on my ER5 front caliper. It kept binding so I did as you, stripped the caliper and replaced the seals. It still wasnt right, so it's been off again and cleaned up by the garage. It's still a bit 'iffy', so it might be the master cylinder or lines that are screwed.
Big Pete
PostPosted: 16:31 - 21 Apr 2005    Post subject: Reply with quote
It does take some time for the pads to bed in again after the caliper has been off, You need to give it a decent run and some good brake use before you can easily say if its a seal/caliper problem. This is even more of a problem if the discs are seriously worn.
Trust me, I`m an engineer
GarageOfPower.co.uk
White Noise
Mr Dudwee
PostPosted: 16:37 - 21 Apr 2005    Post subject: Reply with quote
The pads are the old ones as they have got a far amount of material left on them,
even if the seals are new?
Think that the discs are fine, but i haven't checked the minimum thickness allowed
WN
The last post was made 21 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 62.36 Kb
