| White Noise |
 White Noise Mr Dudwee
 Posted: 14:30 - 21 Apr 2005 Post subject: brake questions |
i have a few questions regarding brakes and wonder if anyone can answer them
cheers
1) what sort of gap should there be between the pad and the brake disc when not in operation?
2) in normal operation there should be no contact with the disc and the pad, i am sure no contact!
3) what actually pulls the piston away from the disc once the brake lever has been released? it the hydrallic pressure?
i am asking this as i have reattached the back brake to my bike and the pads grip the disc but don't seem to pull the pads far away enough from the disk when realised!
could this imply a problem with the master cylinder?
Cheers
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| Mr.Everready |
 Mr.Everready World Chat Champion
 Posted: 14:55 - 21 Apr 2005 Post subject: |
look at your front pads !
You should see no space between the pad and the disk. It isnt like a push bike. ____________________ the undemocratically unelected mod of the Scottish section |
| feef |
 feef Energiser Bunny
 Posted: 14:56 - 21 Apr 2005 Post subject: |
There's near enough no VISIBLE gap between the pads and disk... it's just not exerting any pressure on the disk with them when "pulled back"
in some cases, you can even hear an ever so slight drag on the pads when wheeling the bike about with the engine off. ____________________ Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating |
| skyline |
 skyline Scooby Slapper
| mchaggis |
 mchaggis World Chat Champion
 Posted: 15:06 - 21 Apr 2005 Post subject: |
Normally, the movement of the disc will push the pads slightly away, and the rubber piston seals will do a fair amount of retraction too. They are dragged out by the piston as it moves, and will pull it back to return to their original shape. ____________________ I must not be a troll...
Mmmm, Guinness
| White Noise |
 Posted: 15:41 - 21 Apr 2005 Post subject: |
its just on my ride to work this morning i used very little back brake and a lot of front, then once i got to work i touched the discs and the back one was hot and the front was cold implying that the rear pads have been rubbing the rear disk! which is not normal and not good as i fear i will warp the disc!
I have just put new seals in and the brakes don't seem to retract enough!
I figure i am looking to be able to ride the bike without touching the rear brake and the disc should not be getting hot!
Looks like i will be taking the calipers off again tonight!
| LustyLew |
 LustyLew World Chat Champion
 Posted: 16:03 - 21 Apr 2005 Post subject: |
I have a similar problem on my ER5 front caliper. It kept binding so I did as you, stripped the caliper and replaced the seals. It still wasnt right, so it's been off again and cleaned up by the garage. It's still a bit 'iffy', so it might be the master cylinder or lines that are screwed. ____________________ Like a Yorkie - I'm not for the girls  |
| Big Pete |
 Big Pete Spanner Monkey
| White Noise |
The last post was made 21 years, 164 days ago. Instead of replying here, would creating a new thread be more useful? |
