| no_shad |
 no_shad Trackday Trickster
| planet rider |
 planet rider Nitrous Nuisance
 Posted: 12:47 - 22 Apr 2005 Post subject: |
kool when you get it running i think you will like it as there fun bikes to ride restricted or not.
heres mine: https://bikepics.com/members/planetrider/00planet125/
but since them pics ive done a few more mods.
daza ____________________ Xj 900 |
| impaler |
 impaler Crazy Courier
 Posted: 21:12 - 22 Apr 2005 Post subject: |
Once you get it going, you'll really enjoy it - mine was the best bike I've owned so far!
https://www.ian-atkin.net/bikesplanet.html
I once dropped mine doing a U-turn before my test and all the electrics curiously died - turned out a fuse had blown for some reason, so check them if it's giving you grief  ____________________ Monster m600
Web, blog, Bikepics page
An optimist will tell you the glass is half full. The pessimist, half empty. The engineer will tell you the glass is twice the size it needs to be. |
| camcam |
 camcam Trackday Trickster
| no_shad |
 Posted: 18:41 - 24 Apr 2005 Post subject: |
Going to be more work than i initially thought
I've still not had it running, got the battery back to life though and most of the electrics work, apart from the starter motor and i don't think there is a spark.
Any ideas what would stop the starter working?
I've checked the 2 fuses under the seat and 1 under the tank, am i missing any?
Not sure how you can find out when police auctions are on, around here i sometimes see signs up just like how the computer fairs advertise. I actually bought the bike off eBay, the owner of the garage that sold it told me that:
Click |
| impaler |
| no_shad |
| planet rider |
| no_shad |
 Posted: 22:36 - 24 Apr 2005 Post subject: |
No, i've gave up trying to bump it, i don't think there is a spark.
I'm thinking the only way i can check it's sparking is to get the starter going.
Is it possible there is a safety switch that is preventing the engine starting, maybe the stand or clutch lever or something?
My knowledge is very limited, especially until i get hold of the workshop manual
I may order a new battery tomorrow, i'll see how it goes. |
| impaler |
 Posted: 22:42 - 24 Apr 2005 Post subject: |
As far as I remember, there is a sidestand switch, so make sure it's in neutral when you try to start it.
Can you hear the powervalve cycle when you first turn the ignition key on before trying to start it? It's easily audible, so if there's a deafening silence when you turn the key, the battery's definitely a worry. ____________________ Monster m600
| no_shad |
 Posted: 23:04 - 24 Apr 2005 Post subject: |
Yes I can hear the powervalve doing something when i turn it on.
I've been trying to start it in first as neutral is a bit elusive, not sure if it's just cos the gear lever is bent or the box itself is a bit dodgy...time will tell.
So the starter won't operate is it's in gear?
Cheers for the help btw, much appreciated. I should maybe have started this in the Workshop section but nevermind.  |
| impaler |
 Posted: 23:09 - 24 Apr 2005 Post subject: |
I was always pretty careful to make sure I was in neutral while starting, so I can't remember exactly how it works, but it's usually the case that sidestand down + in gear = cut ignition. I'm not sure if this would also stop the starter turning, but I guess it's a possibility
If you're having trouble finding neutral, (with the ignition off) put it in first and rock the bike forwards & back a little bit, that sometimes helps you find neutral. ____________________ Monster m600
| planet rider |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| no_shad |
| cagiva gezzer |
| no_shad |
 Posted: 13:37 - 04 Jun 2005 Post subject: |
V5 came today.
Going to sort out my CBT this weekend and hopefully i'll be on road early next week.
I think the fork seals need replacing, will see if the mot tester notices  |
| no_shad |
 Posted: 14:45 - 14 Jun 2005 Post subject: |
The bike is now taxed and tested, good news is it sailed through it's MOT.
I'll get some pics up sometime.
Bad news is there is a vibration from the front wheel when i get the speed up, feels like the wheel has a chunk out of it (wheel itself looks fine).
Fingers crossed it's the bearings.
Second problem is the clutch is about to die, and from what it looks like it's not exactly a trivial task to replace it
Great fun pottering about on it though, the powerband is quite vicious first few times you hit it.  |
| impaler |
 Posted: 14:48 - 14 Jun 2005 Post subject: |
If you're even luckier it might have just lost a balance weight and needs rebalancing... ____________________ Monster m600
| no_shad |
| no_shad |
 Posted: 16:00 - 20 Jun 2005 Post subject: |
| paulthewitt |
 paulthewitt World Chat Champion
 Posted: 18:43 - 20 Jun 2005 Post subject: |
let mitomondo be your friend...
https://mitomondo.co.uk/main.html
i hear his service is good, does all cagiva parts. phone him.
Paul |
| no_shad |
| no_shad |
 Posted: 01:31 - 28 Jun 2005 Post subject: |
Checked the front bearings today, found one side had a bit of play, replaced them and yay the nasty vibration has almost gone (possibly mentally scarred). Bike has gained 10mph (rider not worried about the front going walkabouts above 70?).
Bike is getting better by the day.  |
The last post was made 21 years, 86 days ago. Instead of replying here, would creating a new thread be more useful? |
