About to bolt these on...
minesweeper
Whoah there!
PostPosted: 20:43 - 25 Apr 2005    Post subject: About to bolt these on... Reply with quote
Just got my new calipers through the post for my rvf400 (off a cbr900 rry)
https://i13.ebayimg.com/03/i/03/d8/20/fa_1_b.JPG
Any recommendations (with links) for pads and would fitting a new master cylinder be a sensible addition?
With these fitted to my lightened rvf the breaking should be impressive Twisted Evil
binge
Emo Kiddy
PostPosted: 21:19 - 25 Apr 2005    Post subject: Reply with quote
Before you do so.
Get some braided hoses, I see they only have the "rubbers" on.
<|Ben|>
minesweeper
Whoah there!
PostPosted: 21:22 - 25 Apr 2005    Post subject: Reply with quote
When i bought them they had rubber ones, but fitting them to the braided i already have on my rvf Smile thanks for the advice mate.
mchaggis
PostPosted: 21:39 - 25 Apr 2005    Post subject: Re: About to bolt these on... Reply with quote
If the total slave cylinder area of the new calipers is the same as the old calipers, then I wouldn't bother.
If the new area is more than the old, you'll have to put a in lot more effort/ lever travel at the lever to get the same braking effect. Fitting a larger master cylinder would probably be a good idea if possible in this case.
If the slave area is less than it was before, you'll no doubt have much sharper and more sensitive brakes. Fitting a smaller master cylinder to get the same ratio between the master and slave area as before might depend on how you want the brakes to feel and whether you want to run the risk of grabbing a handful and going over the front with an emergency stop.
I must not be a troll...
Mmmm, Guinness
Claud 14.7 to 1
PostPosted: 21:46 - 25 Apr 2005    Post subject: Re: About to bolt these on... Reply with quote
Hopefully not. Wink
Should stop pretty well though. Sweet calipers, I'm jealous.
minesweeper
Whoah there!
PostPosted: 08:56 - 26 Apr 2005    Post subject: Reply with quote
If by slave area you mean pad size, these ones are larger then the standard rvf jobbies. Looks like i better start hunting an r1 or fireblade master cylinder down Cool
Claud doesnt the cbr400 have any options for brake upgrades?
matt
Claud 14.7 to 1
PostPosted: 09:49 - 26 Apr 2005    Post subject: Reply with quote
Yes but Claud has no money. Laughing
I'm sure I've seen an adaptor plate made up, so it can take those same calipers. I think I'll fit some braided lines, and improve them the cheapo way, the've got to be worth £20.
Your Rvf will stop stupidly fast with those on. Thumbs Up
PostPosted: 14:18 - 26 Apr 2005    Post subject: Reply with quote
Not pad area. The area of the pistons on the brake calipers.
The last post was made 21 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.85 - MySQL Queries: 13 - Page Size: 57.07 Kb
