how do you jump a bike...
gimpy limp
PostPosted: 21:24 - 25 Apr 2005    Post subject: how do you jump a bike... Reply with quote
jump as in the battery ...you can blow the thing jumping a motorbike battery using a car battery and jump leads can't you?
What if you used one of them booster packs for cars? or dyou need to buy a seperate bike booster?
https://images.orgill.com/200x200/6644611.JPG
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
lilredmachine
PostPosted: 21:25 - 25 Apr 2005    Post subject: Reply with quote
I jump mine with a car battery, still 12 volts. Works every time.
binge
Emo Kiddy
PostPosted: 21:26 - 25 Apr 2005    Post subject: Reply with quote
Erm...
Why not stick it in gear, Clutch in, and get sombody to push you. When you get enough momentum going, Dump the clutch and boom boom.
If not, I dont think you will blow it up if you are just doing it the once. I may be wrong. But Dam_buster jumped his moped from his car battery.
<|Ben|>
Shaz
PostPosted: 21:29 - 25 Apr 2005    Post subject: Reply with quote
First of all, jumping a bike battery with a car battery doesn't create any problems. I've done it numerous times.
If there isn't a car (or jump leads) nearby, you can jump start a bike by:
Rolling it along a straight road (preferably downhill) in neutral and then when you've collected enough speed (about 4-5 mph) kick it into first gear and the bike should jump into life. If it doesn't work the first time, try a few more times. If it still doesn't start, then find a car to jump start it with.
Good Luck. Thumbs Up
I don't hate Rocky Balboa...I PITY the fool...And I will destroy any man who tries to take what I got!
gimpy limp
PostPosted: 21:32 - 25 Apr 2005    Post subject: Reply with quote
how fast dyou have to be going to do that? in a car you ned to get up to about 10/15 mph then dump it.
I'd prefer another method tbh
gimpy limp
nevermind posted that reply same time as you, cheers
pipnet11
PostPosted: 21:55 - 25 Apr 2005    Post subject: Reply with quote
Iv jumped bikes off cars, other bikes, and those booster thingys without problems Thumbs Up
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
Aikman666
PostPosted: 23:48 - 25 Apr 2005    Post subject: Reply with quote
First?! Are you mad?! That will just burn your tyres! Highest gear up ou can get offers least resistance
Will work for petrol
My Design Blog
gimpy limp
PostPosted: 23:52 - 25 Apr 2005    Post subject: Reply with quote
what gear would you recommend?
didn't quite understand that part, would 2nd be safer? You don't think it should be done in first then I take it?
Aikman666
PostPosted: 23:57 - 25 Apr 2005    Post subject: Reply with quote
The higher up you get the less likely your back wheel will just lock up, and in top gear, when the bike does start (you'll need to have the throttle open a baw hair) youre not going to go anywhere cus ure engine will be at low revs, just grab a fistful of clutch, rev, and take for a SMOOTH ride
My Design Blog
gimpy limp
PostPosted: 23:59 - 25 Apr 2005    Post subject: Reply with quote
ahh right, i gets ya
Fortuna
PostPosted: 00:22 - 26 Apr 2005    Post subject: Re: how do you jump a bike... Reply with quote
GAAAAAAH!!!
Misinformation. You will not harm a 12v motorcycle by using a car battery. The car battery just has a higher capacity of energy stored.
This has been asked before Here
beast rider
PostPosted: 00:24 - 26 Apr 2005    Post subject: Reply with quote
How do i jump a bike?..........................
Not tried iy but i spose i would take a long run up the just leap with all my might as high as i can get! Wink
Very sorry but someone had to say it, i know you was all thinking it.
Fortuna
PostPosted: 00:28 - 26 Apr 2005    Post subject: Reply with quote
Or wait in the bushes 'till it gets dark, then pounce on it.
gimpy limp
PostPosted: 00:32 - 26 Apr 2005    Post subject: Reply with quote
or climb up a step ladder next to it, wait patiently for a small gust and over you go.
plugger147
PostPosted: 01:04 - 26 Apr 2005    Post subject: Reply with quote
ride it up a ramp and don't stop at the end.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
Scotsman37
PostPosted: 01:12 - 26 Apr 2005    Post subject: Reply with quote
I remember someone jump started a car from another vehicle and he was warned do not attempt it, but he shrugged it off and we stood back watching him ask the driver of the other vehicle to start up his articulated lorry, yes an artic !
Suddenly you could smell the waft of freshly burning insulation from through out all of the electrics of the car.... None the less he had to call out a recovery vehicle to get it towed to the nearest garage for major rework job. When the recovery guy turned he to walk around the corner so as not be seen laughing his head off ! Smile
He spent a pretty penny trying to get that car fixed because everything electrical was wasted !
Moral of the story is do not hook up to another vehicle that exceeds your own voltage output.
Will87
PostPosted: 01:53 - 26 Apr 2005    Post subject: Reply with quote
Run and jump starting is easy follow this simple procedure:
1. Turn ignition on, set bike into 2nd gear preferably and hold in clutch.
2. Run along side bike until at what is deemed a fast enough speed by you.
3. Jump so you land on the saddle and at this exact moment release the clutch.
4.Hopefully the engine will have started, if so pull clutch in and place bike in neutral.
There is another way, this is for the more experienced, stick the bike into 2nd or 3rd again and then roll the bike until just past compression, clutch in, run jump etc and it should fire almost instantly!
Flip
PostPosted: 02:28 - 26 Apr 2005    Post subject: Reply with quote
Your step 3 would interesting if the timing was out. Laughing
mr.z
PostPosted: 03:14 - 26 Apr 2005    Post subject: Reply with quote
Jumping is perfectly safe if done propperly UNLESS (afaik) you are unfortuneate enough to have a fuel injected bike or any complex computer controlled gubbins.. spikes kill these reguarly (spoke to a bmw owner who had just payed £800 for a new ecu after a botched jump start).. not allways but be carefull! There are "ecu savers" on the market which will protect from this sort of thing...
If you jump from a car DO NOT start the car.. excess voltage will fry things.. Vans+ anything biger might run from 24volt systems, as mentioned is not a good thing...
If you jump from another battery or car or whatever...
Get the jump lead + and connect to the bike + terminal
Clip the other end to the donor battery + terminal
Clip the - lead to the - terminal on the donor
Then clip the - lead to the - on the battery or a suitable grounding point on the frame.
As soon as you get it going remove in reverse order Thumbs Up
Bump starting is very easy runing jumps are not needed...
Ignition on, stand by the left of the bike, second gear,
hold the clutch in, run forward with the bike till your going a decent speed and smoothly let the clutch out (shouldn't need to be let all the way out),
when it catches pull the clutch back in and give it some revs (dont go mad, brake covered) to keep it alive,
(now you have it going you can stop running Razz) when its runing and not going to die (warmed up, if it was then it will be ok straight away obviously) put it back in neutral and get on when your ready... (make sure you have the front brake covered all the time your doing this!)
Dead easy... done this with my cg, a mates 125, and my old cx...
Will87
PostPosted: 13:40 - 26 Apr 2005    Post subject: Reply with quote
Bumping is easy, have to do it all the time on my Uncles vet as it has no clutch and i have seen many classic road racers with no kickstart, bump all the way.
Fortuna
PostPosted: 17:29 - 26 Apr 2005    Post subject: Reply with quote
Yeah, like he says don't start the car.
Arctic is 24v so no wonder the car fried Rolling Eyes
Andy99
PostPosted: 17:42 - 26 Apr 2005    Post subject: Reply with quote
Well you say it's easy to bump start bikes,it depends on the bike.
Ever tried bump starting big V twins?Not easy at all.
Nothing gets the point across quite like a raised middle digit.
Just call me General Crazypaws.
mr.z
PostPosted: 17:56 - 26 Apr 2005    Post subject: Reply with quote
The cx is pretty frickin big Razz 240kg maybe a bit more... as is the transalp, not tryed that one though yet.. if its engine resistance/capacity you just go up a gear + work the clutch out very carefully..
plugger147
PostPosted: 17:59 - 26 Apr 2005    Post subject: Reply with quote
just tow it for a bit you'll soon have it going.
The last post was made 21 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 133.36 Kb
