Removing spray paint....Help needed!!!
wildcat
PostPosted: 22:09 - 28 Apr 2005    Post subject: Removing spray paint....Help needed!!! Reply with quote
I was out in my garden spraying my cars alloy wheels with tetrosyl wheel paint this morning, ( thet turned out great too) but I had to come inside to answer my phone, while I was inside one of my kids, (none of them will admit it) got the paint and srayed it on my micron can.
How the hell do I get it off???
I didn't notice until 10 mins ago and it is dry.
HELP
https://www.bebo.com/Z1000-Wildkat
Flip
PostPosted: 22:13 - 28 Apr 2005    Post subject: Reply with quote
Aw, crap! Sell the children and use the money to buy a new system? Wink (I'm sure someone will give you a proper answer).
Can you use paint stripper on cans /pipes?
EDIT: Don't use paint stripper 'cause that'll f*ck up the finish on the can. Well brake fluid does. Embarassed )
Mrs Kickstart
PostPosted: 22:24 - 28 Apr 2005    Post subject: Reply with quote
Hi,
Petrol might work, but I do know what it might do to the can,
How about T-CUT or metal polish ?
- and send them all to bed without any tea, and then spend all weekend polishing the car and bike. Very Happy
Regards
C
wildcat
PostPosted: 22:36 - 28 Apr 2005    Post subject: Reply with quote
Ah crap, crap and crap, WTF am I gonna do? Want to get it sorted before Saturday's run to Cookstown 100.
Bloody rug rats!
Who's gonna give me that much money for 3 kids that leave destruction in their wake?? Rolling Eyes
palmer
Fiddled Kiddy
PostPosted: 22:41 - 28 Apr 2005    Post subject: Reply with quote
I'd also recommend t-cut, then when the paint is mostly off get a low abrasion polish to finnish it off.
wildcat
PostPosted: 22:51 - 28 Apr 2005    Post subject: Reply with quote
I have t-cut in the cupboard, but (excuse the ignorance) can you give me an example of low abrasion polish. Embarassed
lilredmachine
PostPosted: 22:52 - 28 Apr 2005    Post subject: Reply with quote
What material is the can? gotta recommend autochrome as a metal polish if it is any sort of shiny finish.
plugger147
PostPosted: 22:54 - 28 Apr 2005    Post subject: Reply with quote
Try tony blair they can finish off anything he might happen to miss.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
wildcat
PostPosted: 23:14 - 28 Apr 2005    Post subject: Reply with quote
@ lilredmachine not sure what it's made of, but yes it's shiney so i'll try autochrome.
PMSL@plugger147 Laughing
wildcat
PostPosted: 00:59 - 29 Apr 2005    Post subject: Reply with quote
Couldn't wait til tomorrow, just tryed t-cut and autosol. Neither worked, Brick Wall
The can is stainless steel I think,
Anymore Ideas anyone...........
....Please Praying
mchaggis
PostPosted: 01:02 - 29 Apr 2005    Post subject: Reply with quote
White spirit and a cloth? Just keep rubbing with a soaked cloth. I don't know what it'll do to the finish, but I can't see it would be anything bad if it's shiney :- chromed?
I must not be a troll...
Mmmm, Guinness
plugger147
wire wool maybe?
wildcat
PostPosted: 01:05 - 29 Apr 2005    Post subject: Reply with quote
I'll try white spirts, but i won't chance wire wool.
I'll maybe try petrol too, (I can test underneath the can first)
Keep the suggestions coming, I'm running out of options.
R4nger
PostPosted: 01:08 - 29 Apr 2005    Post subject: Reply with quote
Use a industrial sander with P40 sandpaper! Laughing
wildcat
PostPosted: 01:13 - 29 Apr 2005    Post subject: Reply with quote
OK
Keep the sensible suggestions coming, cos i'm running out of options. Laughing
tatters
Exxon Valdez
PostPosted: 01:28 - 29 Apr 2005    Post subject: Reply with quote
use some rubbing compound (comes in a little flat tin from car shops)
l can guarntee that it removes tetrosyl wheel paint. got the stuff off my frame.
epz
PostPosted: 03:01 - 29 Apr 2005    Post subject: Reply with quote
if its all on 1 blob you could try a very thin blade like a razor and slice it off, failing that a power washer, those things can cut into concrete so should strip anything though i would take the can off the bike first.
Scotsman37
PostPosted: 03:23 - 29 Apr 2005    Post subject: Reply with quote
With your Micron can there is no paint on it originally? and, if so, try using brake fluid because that eats right through paint if left long enough and leaves you with a metal surface again !
Flip
PostPosted: 04:34 - 29 Apr 2005    Post subject: Reply with quote
I got brake fluid on a stainless Yoshi can and it damaged the finish.
MalcolmT
PostPosted: 06:33 - 29 Apr 2005    Post subject: Another Idea Reply with quote
You could try an OLD 3M green scouring pad, use an old one so it won’t be too abrasive. The can sounds like its coated in high temperature lacquer which could be redone from a can if need be.
ZRX61
Victor Meldrew
PostPosted: 15:47 - 29 Apr 2005    Post subject: Reply with quote
STOP!!
If the paint came out of a rattle can then Laquer Thinner will take it straight off, even if it's dry. Just soak a rag with it & lay it on the paint for a few second & then just wipe it off.
In fact laquer thinner will remove most paint unless it's isocyanate base
feef
Energiser Bunny
PostPosted: 16:12 - 29 Apr 2005    Post subject: Reply with quote
try Cellulose thinners...
if it's a metal can, you're laughung.. I'm not sure about the resins used on CF cans tho.. I DOUBT they use cellulose solluable resins, as may of them use Polyester based resin.. but i'm not sure...
(also depends if it's "proper" CF which has been cured in an autoclave at pressure to produce a wonderful, light, and strong (in a tensile way) material, or if it's glorified fibre reinforced plastic)
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
feef
Energiser Bunny
PostPosted: 16:13 - 29 Apr 2005    Post subject: Reply with quote
ZRX61 wrote:
STOP!!
or Xylene based (i THINK that includes the hammer/smoothrites of the world)
a
The last post was made 21 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 117.07 Kb
