04 yamaha dragstar 125 chain n sprocket
gimpy limp
PostPosted: 00:11 - 29 Apr 2005    Post subject: 04 yamaha dragstar 125 chain n sprocket Reply with quote
is this hard to do? a mate has one and he's bought the new parts but the garage want's 50 quid to fit it, if it's not hard to do we'll have a go ourselves (with the haynes manual).
What's involved? neither of us have done it before.
2004 one of these:
https://bike-exchange.com/Yamaha%20XVS125%20Dragstar%20LIB.jpg
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
Frost
PostPosted: 00:14 - 29 Apr 2005    Post subject: Reply with quote
Easy to do provided you can get the rear wheel off the ground.
All you should need is a couple of big spanners (adjustables will do), a socket set, and possibly a pair of circlip pliers.
Git
PostPosted: 00:20 - 29 Apr 2005    Post subject: Reply with quote
And maybe a tool to get the old chain off and rivet the new link on, that's presuming it's not split link jobbie.
R4nger
PostPosted: 00:22 - 29 Apr 2005    Post subject: Reply with quote
Dragstars don't have a center stand so you will need to buy some paddock stands.
gimpy limp
PostPosted: 00:23 - 29 Apr 2005    Post subject: Reply with quote
good good, what's inolved exactly dyou know? quick step by step how-to would be great.
Gazdaman
I did a trackday!!!
PostPosted: 00:35 - 29 Apr 2005    Post subject: Reply with quote
You need to get the back wheel off the ground. Bodge it if need be. (Milk crates or something).
You need to break the chain, (normally there's a split link (it looks different to all the others)) Just slide the little clip out and that link will fall out.
Gaz's tip for the day, attach one end of the new chain to one end of the old chain, and pull it through. Saves you messing with getting it around the front sprocket later.
You'll need to get the back wheel off, nut on each side. DO NOT USE ADJUSTABLE SPANNERS as early recommended. An adjustable is for an emergency, and that's assuming halfords is shut at the time and there's no option of borrowing a spanner.
You may have to take the back disk caliper off, couple of nuts, and give it a gentle persuading smack upwards (depends how worn the disk is) (also depends if you have a disk....)
Then unbolt the sprocket, bolt the new one on.
Easy job TBH.
If you've got a manual it'll be simple, just hope you've got the tools.
Don't use the wrong tool, you'll damage something.
Gaz
gimpy limp
PostPosted: 00:41 - 29 Apr 2005    Post subject: Reply with quote
nice one, thats perfect, yeh tools won't be a problem, got 100's for all the cars, give me a car engine any day but bikes are new to me.
The last post was made 21 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 53.19 Kb
