Engine problem HELP!!!!!!
RS125_Tecky
PostPosted: 06:27 - 02 May 2005    Post subject: Engine problem HELP!!!!!! Reply with quote
just need a little info.
I was on my Aprilia RS 125 when it started loosing power and then stopped running with a little back fire from the exhaust.
Its now lost all compression and can be pushed when in gear.
The bike did have a new piston kit in it and had only done about 30 miles before it decided to stop running.
I wasn't hammering the bike or anything, i was takeing it easy (as you do with a new piston)
Im now going to sell the bike as a non runner what should i tell people who come to look at the bike??? i should imagine the gearbox and cluth etc. are still perfect.
Its a 2000 model RS
whats the damage that has happened and how much rougly to fix it?
ace2004k
PostPosted: 06:51 - 02 May 2005    Post subject: Reply with quote
sounds like what just happened to my 99rs, most probly nipped a ring
if this is the case you could be lucky! if the piston has done no damage to barrel its gonna b £90 for piston, if not new top end from PJ engineering £230ish!
ZRX61
Victor Meldrew
PostPosted: 07:04 - 02 May 2005    Post subject: Re: Engine problem HELP!!!!!! Reply with quote
Tell em it done blowed up....
RS125_Tecky
PostPosted: 07:45 - 02 May 2005    Post subject: Re: Engine problem HELP!!!!!! Reply with quote
What do you mean "tell em it done blowed up" cant make sense of it
RS125_Tecky
PostPosted: 07:48 - 02 May 2005    Post subject: Reply with quote
i only put a new piston kit in about 30 miles before it stopped running again. i was still running the new one in.
Last time i was lucky and i had nipped a ring and there was no damage to the barrel.
I could get a top end of ebay for around £50. Or would you recommened getting a new top end??
cheers
Robby
Dirty Old Man
PostPosted: 08:34 - 02 May 2005    Post subject: Reply with quote
Pull it apart and see what the problem is.
If you blew it up within 30 miles of rebuild my money's on you cocking up the rebuild.
Make sure the plug is screwed in tight first though.
The last post was made 21 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 48.96 Kb
