arai visors (whats the knack)
Ric
PostPosted: 15:41 - 04 May 2005    Post subject: arai visors (whats the knack) Reply with quote
ive just spent about 25-35 mins fighting with my new arai lid to remove/fit the visor
the quote was within a minute
my old shark a baby could do
this one seems to be crazy i still dont know how i put it back on
altho i can get it off easy enuff now
any hints?
Rob
PostPosted: 15:49 - 04 May 2005    Post subject: Reply with quote
At first they seem impossible but it is actually very easy.
You just have to get over the fear of feeling like the plastic is about to break!! Laughing
I grip the end of the visor like a gun and pull the black trigger with my forefinger then slide the visor upwards and outwards. When putting it back in just slide in and down until it clicks. Make sure the little black trigger is in the out position when you do though.
You will probably go through a few times where the side pod just pops off when you try but it just pops back on again!
Love is 1050cc Smile
WishayKillie
PostPosted: 15:50 - 04 May 2005    Post subject: Reply with quote
Get a Shoei they are so easy to put the visors on and off Thumbs Up just pull two levers and it pops off and to put it back on just pop it back in Thumbs Up simple.
numark1
Scared of girls
PostPosted: 16:14 - 04 May 2005    Post subject: Reply with quote
My AGV is a cunt to fit a tinted visor onto because you can't see what your doing. Confused
VTR SP1
PostPosted: 16:32 - 04 May 2005    Post subject: Reply with quote
Put the lid down infront of you with the visor furthest away.
Lift the visor all the was and the plastic bits will pop out on either side.
put your thumbs on the lid and using index finders pull both plastic bits back hard.
Once they click coutinue pulling up with your index fingers and pull the visor up and out.
EASY.
To put one in put the ends in at the same time and wiggle it quite hard pusing back.
You should hear a click for both sides.
Close the visor and you will be able to see if its in peoperly.
HTH
SP1
EuropeanNC30R...
Gay Hairdresser
PostPosted: 16:38 - 04 May 2005    Post subject: Reply with quote
Sounds like your in the same situation I was in a week ago. How bloody hard do they have to make it! Think it took me something stupid like 3 hours (on and off) to remove and refit the visor the first time Laughing
Fruit'n'nut
PostPosted: 18:54 - 04 May 2005    Post subject: Reply with quote
VTR SP1 wrote:
Put the lid down infront of you ....
What he said, it's dead easy once you get used to it. It did take me a couple of attempts when I first got my helmet - can do it while wearing the helmet now, as long as the little levers don't get shoved under the side-pods Very Happy Wink
Power Ranger Very Happy
Going2fast
PostPosted: 19:11 - 04 May 2005    Post subject: Reply with quote
With an arai its a deffo you need the knack.
I hate doing them at work showing people. I put the lid in front of me, visor facing away. Slight pressure (only slight!!) at the bottom of both pods and lift the catchs, and pull.
Hate the noise they make coming off Sick
I dont understand why Arai still do pods, only advantage i see is that it hides the mechanics of the visor.
ANdy
Passed My Test 15/03/05 Very Happy Very Happy
BikePics Profile ||| 96' RVF 400 ||| 01' CBR 600 F Sport ||| 2009 Yamaha YZF-R6 Delivered 23/06/09
/-\ndy
mchaggis
PostPosted: 19:15 - 04 May 2005    Post subject: Reply with quote
Side pods look nice. They'd be a disaster on the V-flyer though. The visors on those really need the knack. IIRC, the salesman broke the visor on my helmet demonstrating how to put it back in. The flimsy little plastic togs are scary. Confused
I must not be a troll...
Mmmm, Guinness
Ric
PostPosted: 19:16 - 04 May 2005    Post subject: Reply with quote
i kinda got it down to a couple of mins fittin, gettin it off is ok
dont see y the pods dont clip off and then it could be simpler
jus sounds/feels like its breaking wen i do it
lots of jiggling and a bit of pressure
Fruit'n'nut
PostPosted: 19:33 - 04 May 2005    Post subject: Reply with quote
Lifting the catch/lever should push the side-pod out ever so slightly - so you don't need to put any pressure on.
At least, that's how it works on my Quantum-F Confused Question
Claud 14.7 to 1
PostPosted: 19:49 - 04 May 2005    Post subject: Reply with quote
Visor out
Pull visor fully up so the grey levers pop up.
With the helmet facing away pull the levers up, the lid makes a cracking noise each time you flick the levers up.
Then it should have released the visor. Then pull the visor back untill it comes out by itself.
Visor in
I lift the grey levers to a horizontal position which allows more room for "entry", as this will open the gap at the side shields. Sometimes I use a key to move them up if they have dropped "inside" the shield.
Insert the visor from quite a steep angle (an angle more vertical then the visor would be at maxium angle assuming it was fixed on properly)
Then push in and it should click, you may need to jiggle about abit. Practice will make you better. If it feels really jammed take it out and try again.
Even after all this time sometimes one side won't go in and I have to take the visor out and try again. Clapping
Edit : it's possible to do any of the actions one side at a time. No need to try and do both at once, although releasing the visor by pulling the grey levers up can easily be done both at once. Thumbs Up
Bezzer
PostPosted: 21:16 - 04 May 2005    Post subject: Reply with quote
I used to have the same problems until I asked at the Arai Service truck and they showed me using one with a clear side pod fitted so you could see what's happening. The main thing is once you've pulled the side levers out LET GO OF THEM as you continue to lift the visor out. You could see through the clear pod that they just lift the sides of the visor out initially and don't need to be touched again and in fact hamper the visor coming out if you keep pressure on them.
Bikay
PostPosted: 20:08 - 05 May 2005    Post subject: Reply with quote
Sorry to bring this back up but I can't get the visor off by RV. Embarassed
The manual I got with it is for a RX7 so I'm wondering whether I should be pulling up or is there a different release mechanism on this model? I've had the jaw held in place by a friend while I try and lift the visor but it won't budge.
Check out my bikay cha'mone!
Fruit'n'nut
PostPosted: 21:01 - 05 May 2005    Post subject: Reply with quote
Should be the same - the RV uses the same visor type as the Quantum-E/F's, Astro-J/R's, RX7's ...
When you lift the visor to full-open do the little levers pop out of the side-pods? You need to give each of those a push upwards, quite firmly, then lift the visor-ends up and out of the pods.
It's easier to do with the helmet facing away from you.
KevlarPants
PostPosted: 00:25 - 06 May 2005    Post subject: Reply with quote
Below is a link to the arai manual . Page 8 is where they go over the visor removal etc.
I found it plus the advice in this thread really useful as I've not taken the visor off my lid before...
https://www.araihelmet-europe.com/new_site/pdf/Arai_ib_bin_UK.pdf
Silver
PostPosted: 00:28 - 06 May 2005    Post subject: Reply with quote
It's a pain in the arse (although you always get smug people tell you it's easy).
If it's any consolation, it seems to get (a bit) easier with practice/time.
Fruit'n'nut
PostPosted: 00:49 - 06 May 2005    Post subject: Reply with quote
But I did say it took me a couple of attempts, before I found it easy Embarassed Embarassed Sad
Wink Wink
craigT19
Jolly Green Giant
PostPosted: 12:26 - 06 May 2005    Post subject: Reply with quote
yeah aria is easy just push up the little leavers and push the visor back...takes about 10 seconds once u get used to it Thumbs Up
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
Kris
PostPosted: 12:35 - 06 May 2005    Post subject: Reply with quote
My Shoei takes 10 seconds max and doesn't require any fiddly bits at all. Thumbs Up
www.prisonplanet.com
The last post was made 21 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 108.37 Kb
