rs 125 help
dransy
PostPosted: 21:50 - 04 May 2005    Post subject: rs 125 help Reply with quote
hey people my rd 125 wont go past 6 thousand rpm it gets to 6thousand rpm then wnt go no further , to get it through the flat spot i have to pull clutch it give it ait more revs then let the clutch out
any 1 know wots causin this? cheers
R4nger
PostPosted: 21:56 - 04 May 2005    Post subject: Reply with quote
The power valve
dransy
PostPosted: 21:59 - 04 May 2005    Post subject: Reply with quote
ive cleaned the powervavle though it comes in about 7 - 8 thousand but thats only if i dip the clutch
paulthewitt
PostPosted: 22:33 - 04 May 2005    Post subject: Reply with quote
maybe your ecu is screwed.there are a number of "specialists" over on
www.125ccsportsbikes.com
who know the rs125 inside out (literally) who may be more help. as the majority of people on here ride bigger 4stroke bikes.
Paul
Method
PostPosted: 22:37 - 04 May 2005    Post subject: Reply with quote
Realy? and there was me thinking RS's still used carb's Wink
maybe you mean the ignition unit / CDi?
Think you'll find mate, there are a lot of people here who can be classed as "specialists" amongst other things. Just because people ride "bigger 4stroke bikes" doesnt mean we / they dont know their stuff when it comes to the smaller bikes...
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Villers
PostPosted: 00:23 - 05 May 2005    Post subject: Reply with quote
has the ECU been modded to remove the environmental dip? Fairly easy to do, remove ECU and dig the silicone out of the back, snip the bridge, re-seal, re-fit and mod complete. Hopefully will get rid of the dip. And im a 'big bike rider' too, but we all have to start somewhere!
good luck
PostPosted: 00:31 - 05 May 2005    Post subject: Reply with quote
The cdi mod is to get round a flat spot that is engineered in between 5000 and 6000rpm. It has no effect outside that range. The power valve should open at 8000rpm (give or take 200rpm).
As such from the description it sounds like neither of these.
Added to which he said RD125. In which case it could be numerous things, but such a bike is likely to have a large flat spot at half peak power. Not much you can do to get rid of it without loosing the peak power as well.
cunni
PostPosted: 10:07 - 05 May 2005    Post subject: Reply with quote
My RS125 had the same problem, until it reached 81 degrees in the engine, then it was fine. Is your bike running at the right temperature?
TL1000R Parts For Sale!
houlsby
PostPosted: 10:13 - 05 May 2005    Post subject: Reply with quote
if ur bike was running at 81 degrees m8ty then u got problems! unless u were in the town or slow moving traffic ect then it was just overheatin! my rs runs at between 69 and 73 when its out of the garage and not blowing up on me. dransy have you cleaned ur powervalve? that might help. go onto 125ccsportsbikes.com like saidabove there all good guys on there n will help. cheers. houlsby
cunni
PostPosted: 10:19 - 05 May 2005    Post subject: Reply with quote
Oh, I thought that was normal temp. Maybe my power valve was playing up too? Although I did ride fast everywhere, trying to stay with 1000cc machines down the twisties!
Never mind, I sold it last year! tee hee.
PostPosted: 12:31 - 05 May 2005    Post subject: Reply with quote
About 80 is the correct temperature. The thermostat does not even open until the mid 70s.
cunni
PostPosted: 12:44 - 05 May 2005    Post subject: Reply with quote
Then my bike was fine. I hate when I get doubts in my head! tee hee.
Well, as stated above, my engine wouldn't run freely until it was completely warm, at 80-81 deg C.
It would struggle to get over 6000rpm. But then I was doing 80-95mph from Nottingham to Chesterfield on it daily and some sunday rampages! Laughing
dransy
PostPosted: 20:21 - 05 May 2005    Post subject: Reply with quote
i mean RS 125 sorry missplaced d with s Sad
rs not rd Sad lol soz
dave1rs
PostPosted: 22:00 - 05 May 2005    Post subject: Reply with quote
If your bike is an 03 or newer then its normal,you need to do the cdi mod to remove the dip,it wont solve the problem totally(will get a minor splutter).
When i got my 04 it was just like a brick wall and didnt want to go past 6000rpm unless you changed down a gear until i did the mod.
For advice on RS's i highly recommend 125ccsportsbikes.com or apriliaforum.com some good advice available on both sites,but also a lot of childish spam.
dransy
PostPosted: 22:53 - 05 May 2005    Post subject: Reply with quote
can it be anything to do with the carb set up?
dave1rs
PostPosted: 09:22 - 06 May 2005    Post subject: Reply with quote
Not if its the standard carb,you wont need to touch that unless you fit an aftermarket exhaust,it is jetted very rich and the standard exhaust on 03 and above has a catalytic convertor,it only needs rejetting to fit an aftermarket one.
The last post was made 21 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 90.67 Kb
