runnin bike in question.
houlsby
PostPosted: 00:04 - 07 May 2005    Post subject: runnin bike in question. Reply with quote
hi tomoro im goin to pick up my rs after its rebuild i have the powervalve fitted but also have the restrictor (blanking plate). would i be better to put the restrictor in to stop me from thrashing the bike or will i have to run the bike in at even lower revs if i do? cheers. kieran.
WalkeruK88
PostPosted: 00:09 - 07 May 2005    Post subject: Reply with quote
run it in and dont kain it for 200 miles around ( may be completely wrong but thats what i was told ) once you feel the powerband realy kicking in then its run in i believe
houlsby
PostPosted: 00:12 - 07 May 2005    Post subject: Reply with quote
i was told a thousond miles last re-build tho? but i did rag it everyware! hence the reason i want the restrictor put in!
DynaMight
PostPosted: 00:18 - 07 May 2005    Post subject: Reply with quote
It can be painful running in a RS125 esp if you're used to a full power one, I had to keep mine below 6k rpm for about 500miles they said. Old one legged men on pushbikes were overtaking me, But it is something that's better done on a 2stroke.
Although I got to about 200miles and took it upto 10-11k in short bursts, Then let all hell loose at about 300-400miles.
JonB
Afraid of Mileage
PostPosted: 01:00 - 07 May 2005    Post subject: Reply with quote
Running in bikes are a pain aren't they?
Keeping the Bandit under 6,000 RPM is quite hard.
DynaMight
PostPosted: 01:15 - 07 May 2005    Post subject: Reply with quote
Just give it a good thashing upto the restrictions!
houlsby
PostPosted: 01:24 - 07 May 2005    Post subject: Reply with quote
thats what i was thinkin with havin the restrictor in i wont have to worry an just thrash it up to its restriction! Wink
dainesefreak
PostPosted: 11:15 - 07 May 2005    Post subject: Reply with quote
No. Still running mine in and it's fairly nippy Wink
Take it up to 6000 rpm but don't keep it in the same rev range for long periods of time, you shouldn't stress the engine, vary the revs. You can accelerate fairly briskly but no full power starts. Get yourself out for a weekend and do it in chunks on some nice quiet B roads where you won't get hassled.
If you don't need the restrictor then don't put it in, it will just make the whole thing seem even more horrible. You just need to be patient and get at least a couple of hundred miles out of the way, then give yourself a few more revs to play with to keep yourself happy, not too many though.
It will be over in no time and you'll have at least another 10k till rebuild time. Shocked Wink
The last post was made 21 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 55.21 Kb
