Wheelies
WalkeruK88
PostPosted: 22:57 - 07 May 2005    Post subject: Wheelies Reply with quote
Right i decided to have a quick go at attempting to wheelie my bike never done it before so
Set off walking pace clutch in couple of hand fulls clutch out lovely it worked but how the hell do you do it at higher speeds i.e 10 or 20 mph the bike just seems to jump foward
PostPosted: 00:24 - 08 May 2005    Post subject: Re: Wheelies Reply with quote
What bike?
Nath
PostPosted: 00:47 - 08 May 2005    Post subject: Reply with quote
Try:
Arrow sitting/leaning further back on the seat
Arrow giving the handlebars a bit of a tug
Arrow bouncing the forks down first then dropping the clutch as they bounce back up
Arrow doing it with less petrol in the tank
Arrow revving it harder
Or just give up untill you're on a bigger bike. I used to occasionally wheely my cg125 but never mastered it(often just ended up lurching like you describe). I tried out the bros without going up to the redline but could only get it to wheely off the line - I think i'm going to forget wheelying for the time being as I don't want to drop the bike or kill the engine, and I find wheelying off the line a little scary to be honest Confused
Hard livin', hard luck.
PostPosted: 00:51 - 08 May 2005    Post subject: Reply with quote
I had a play on a Bros 400. Clutched in first at slow speed it came up quite nicely I thought.
Nath
PostPosted: 01:02 - 08 May 2005    Post subject: Reply with quote
Well when I tried it my chain was knackered and the new rear sprocket I've now fitted is 1 tooth larger which does seem to have made a noticable difference to acceleration/gearing. I also think the bike is running better after removing the carbs to check the valve clearances and changing the plugs/airfilter. I suspect the airfilter case may also have not been correctly installed onto the carbs previously.
In other words I did some stuff to it and it now feels like it has a bit more pull so perhaps it would go up more easily(though I never tried really hard to wheely it whilst moving previously). Also, I had it dynoed today and it only made 29.5hp at rear wheel, so maybe my bike is a bit down on power from what it should be. Not sure I really want to bother with wheelying though as the engine probably isn't quite so bullet proof as the cg125 and i'd be gutted if I dropped and damaged it.
I have thought about getting a cheap hack/project though, specifically for mucking about and acting a twat on Thumbs Up
The last post was made 21 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.45 - MySQL Queries: 16 - Page Size: 46.08 Kb
