snapped bleed valve
gimpy limp
PostPosted: 15:03 - 08 May 2005    Post subject: snapped bleed valve Reply with quote
grrrrrrrrrrrrr
bleed valve just sheared off, can you buy new bleed valves? I haven't a clue how i'm gonna get the old one out yet.
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
gimpy limp
PostPosted: 15:05 - 08 May 2005    Post subject: Reply with quote
https://img179.echo.cx/img179/6703/calip5hq.jpg
base
PostPosted: 15:10 - 08 May 2005    Post subject: Reply with quote
yes you can buy bleed valves easily, juts go to your usual bike dealer and they should sort it outt no problem, getting it out can be tricky, a friend took his to a very good welding person who managed to weld a tiny rod onto the broken bleed valve and remove by unscrewing. i would advise against drilling, but thats upto you
Scotsman37
PostPosted: 15:11 - 08 May 2005    Post subject: Reply with quote
Yes you can buy new bleed valves but they vary in sizes and your local dealer can get them for you, except you'll pay a few pounds for just one !
gimpy limp
PostPosted: 15:21 - 08 May 2005    Post subject: Reply with quote
thinking if I sharpen one of me screwdrivers and give that a few whacks with the hammer on it it'll either break up or it'll go in and I can unscrew it with the screwdriver then.
2t-Screamer
PostPosted: 16:25 - 08 May 2005    Post subject: Reply with quote
leave the old 1 in, This happened to me on my RD and you can actually buy a giant bleed nipple that replaces the bolt that holds the pipe to the caliper, i paid £15 for mine from a shop that blatently overcharges so you should get 1 for £10 anywhere else
visit Collective Knowledge
Gazdaman
I did a trackday!!!
PostPosted: 17:08 - 08 May 2005    Post subject: Reply with quote
Got any more info on those 2t-screamer?
My bleed nipple's snapped off the rear caliper on the TZR.
Gaz
2t-Screamer
PostPosted: 17:33 - 08 May 2005    Post subject: Reply with quote
unfortunatly i dont know what there called, and can't find any reference to them on the web Shocked
i got mine from steves spares (hull) 01482 442115 just ring him and tell him that your bleed nipple has snapped and you need the alternative 1 that replaces the pipe clamp bolt,
i believe he calls them "second chance bleed nipples" or something like that anyway
bish777
PostPosted: 18:05 - 08 May 2005    Post subject: Reply with quote
it is possible to mostly beleed the system by using the last bolt anyways!
GSXR1100J
gimpy limp
PostPosted: 21:20 - 08 May 2005    Post subject: Reply with quote
that sounds like just what I need, even tried and impact screwdriver which you whack with a hammer and it turns but that didn't work.
it goes from one pipe/connector thingy from the master cylinder and seperates into 2 hoses. Can I do what you said bish777?
The last post was made 21 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 64.31 Kb
