clutch at lights question.
danclarkie
PostPosted: 23:26 - 08 May 2005    Post subject: clutch at lights question. Reply with quote
when at traffic lights should i keep it in 1st with clutch down or go to neutral then find 1st just before i set off? i havent got my bike yet but i always leave it in 1st in my car at the lights. a biker friend of mine told me that leaving it in 1st will wear the clutch out and will smooth the plates and that since its a bike it only has small plates anyway??
help Very Happy
Bah Humbug
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
mchaggis
PostPosted: 23:45 - 08 May 2005    Post subject: Reply with quote
Pulling the clutch in won't fully seperate the plates, depending on how far out the biting point is set from the lever. I tend to just leave it in 1st and hold the clutch in whilst waiting, but if it's a large junction and the cycle just caught me then I'll change into neutral. Then I don't have to sit there for 3-4 minutes holding the clutch in waiting for the lights to change.
(Most) bikes have wet clutches which can cope with slipping for extended periods. I'd change into neutral if my hand is aching, or just hold the clutch in if I don't want to faff about with the Hendon shuffle.
I must not be a troll...
Mmmm, Guinness
loply
PostPosted: 23:49 - 08 May 2005    Post subject: Reply with quote
I was taking my clutch apart today and from what I saw the plates will still (loosely) rub against each other even with the clutch in, as stated above.
I honestly have no idea if this is sufficient to wear them down though.
If I had to guess I would say it doesnt matter but Im just guessing- Probably someone else can confirm.
Yamaha SZR660 Caution to the wind, the throttle pinned!
kawakid
PostPosted: 23:54 - 08 May 2005    Post subject: Reply with quote
I was told for my test
That if Im at the first in the queue, then I am expected to be in first gear and ready to go.
If further back netural is fine.
When breaking, go through your gears and be down in first by the time you stop, that way your not doing an irish jig on the road.
I've a twin and a 4.
danclarkie
PostPosted: 00:04 - 09 May 2005    Post subject: Reply with quote
the police drivers handbook teaches a system of "gears to go Brakes to slow" were you dont use the engine braking of the gears to slow you down you just arrive at the gear your in then de clutch but i argue with my dad that using the engine braking will reduced wear on the brake pads and so saves money so i dont know i think i will use the gears to slow me down though for one thing it just sounds cooler. thanks for the advice anyway Very Happy
Bah Humbug
strag
PostPosted: 00:17 - 09 May 2005    Post subject: Reply with quote
Brakes are made for stopping the bike, why not use em? Brake pads are cheaper to replace than a clutch etc. You also have more control over the bike than if you use engine braking. That said, its up to you.
carbon bling
Davo
Davo To The Rescue!
PostPosted: 00:24 - 09 May 2005    Post subject: Reply with quote
The reason that this is taught that it is cheaper to replace a set of brake pads than it is to replace a gearbox or possibly and engine.
On a bike there is always a possiblility through lack of experience (not having a dig at anyone, I've done it) that down changing gear too early will cause the rear wheel to lockup and to throw the rider off.
mr.z
PostPosted: 00:38 - 09 May 2005    Post subject: Reply with quote
A cg125 gearbox costs about £500... all the pads cost about £20, these are as cheep as bikes get...
Brakes are cheeper, made to be sacrificed... but in reality i use both at the same time more often than not... partly because it just sounds ace all the burbleing and mini backfires, especially when upseting the locals Shifty
Theroreticaly you should have it in neutral and have the back brake on while waiting... because being shunted from behind if your in first and your hand slips (which is quite likely) then you stall, and find yourself under the car thinking... shat... or give it an accidental hand full and wheelie into the oncomeing traffic...
If the lights have been on red for ages i'll stay in gear, if they just went red i'll put it in neutral... simple really Smile
Mr C
PostPosted: 12:35 - 09 May 2005    Post subject: Reply with quote
always have an escape route planned when you stop and you should be in first gear, clutch in, watching the mirrors and ready to dart down your escape route if/when you see that vectra sliding up behind you
you should really only select neutral when you have two vehicles stopped behind you giving you a decent buffer from the vectra piling into the back of them
you should never be shunted from behind using this technique
187.3bhp = 201mph
map
Mr Calendar
PostPosted: 13:43 - 09 May 2005    Post subject: Reply with quote
Once upon a time there was the thing called the 'Hendon shuffle' for waiting at lights. Taught to police riders at Hendon, hence the name.
Basically approach junction in first, foot on brake. Then front brake on, switch leg down and change to neutral. When lights changing go into first, swap leg down, foot back on rear brake, release front brake. The thinking is you always have the brake on so safer from rear shunt (do a google for more info.).
However, having said all that from what I gather this shuffle is now seen as somewhat unprofessional. I believe Mr. C's comments about keeping an escape route (so keep bike in gear) is now the accepted approach.
However, having said that, if you've got a heavy clutch (or as said 2 vehicles behind you) then changing to neutral offers some relief. Clear as mud then Wink Rolling Eyes
FYI the method you need for passing the test is just to keep it in first with the clutch in. Anything else is for advanced training.
HTH Thumbs Up
Fruit'n'nut
PostPosted: 14:06 - 09 May 2005    Post subject: Reply with quote
I'd agree with the above - but it doesn't work when the woman behind you sits with her car in gear for two-three minutes, then her foot slips off the clutch when her leg gets tired .... Wink
Power Ranger Very Happy
Mr C
PostPosted: 14:15 - 09 May 2005    Post subject: Reply with quote
or a lump of toilet ice from a 747 falls on your head
jeez how many possibilities do you want covered Rolling Eyes
187.3bhp = 201mph
mchaggis
PostPosted: 14:17 - 09 May 2005    Post subject: Reply with quote
The woman getting tired and accidentally letting her foot off the clutch is only going to hit you at maybe 5 mph though. The drunk driver who forgets to brake from 50mph might do you a little more harm.
Mmmm, Guinness
Fruit'n'nut
PostPosted: 18:29 - 09 May 2005    Post subject: Reply with quote
Mate, the " Wink " was implying that I have a little personal experience in the matter ... Wink
alliamc
PostPosted: 18:33 - 09 May 2005    Post subject: Reply with quote
My bike seems to only like selecting neutral when I'm chaning from first to second Rolling Eyes
Alli x
https://www.bikepics.com/members/alliamc/
Mr C
PostPosted: 20:04 - 09 May 2005    Post subject: Reply with quote
ok so you WERE the one in a billion then
stand easy eveeryone, it's covered Wink
187.3bhp = 201mph
Craggles
PostPosted: 20:12 - 09 May 2005    Post subject: Reply with quote
I always kept the clutch in/first when I did my test. I saw my instructor sat behind me in neutral, both feet down and hands off the handlebars.
If I'm sat in traffic I'll use neutral, else my left hand will fall off. If I've filtered to the front of the lights, I'll keep the clutch in - need to get going quick once they've changed!
Judging from the answers on this post - any way is fine as long as you're happy with it. Each method has its advantages and disadvantages.
Craig
If this signature is blue, you're riding too fast
Fruit'n'nut
PostPosted: 20:51 - 09 May 2005    Post subject: Reply with quote
Lol, yep Confused
Minor shunt, kept upright, and I'd left loads of space between me and the car in front Thumbs Up
... I'd have filtered to the front instead of waiting in the queue, but there wasn't much space with a caravan waiting to turn right from the front of the queue in the oncoming lane ... Rolling Eyes Smile
The last post was made 21 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 108.47 Kb
