rs125 brake light
matty8887
PostPosted: 12:32 - 10 May 2005    Post subject: rs125 brake light Reply with quote
I took it off yesterday because i needed a new one, today i come to put the new one on but forgot where the wires went.
Ive had a gues but already blew 3 fuses n im on my last one so i need someone to tell me.
I looked on google and in the aprilia book but nothing.
Hope you guys can help me out, cheers
PostPosted: 12:39 - 10 May 2005    Post subject: Reply with quote
Front or back?
In either case I think they just have a pair of spade connectors and it should not matter which way round these are connected. As such I would suspect the short is somewhere else.
matty8887
PostPosted: 13:13 - 10 May 2005    Post subject: Reply with quote
It aint shorting anywhere else because i put the back light on last night and it worked perfectly but now i forgot which way the wires go. All other electrics is working but if i press the brake then it will blow the fuse again.
I badly need a diagram.
PostPosted: 13:36 - 10 May 2005    Post subject: Reply with quote
There are just 2 wires that go to the pressure switch on the rear brake master cylinder. Pressing the back brake just connects these 2 wires together, and as such it does not matter which way round they connect to the switch.
As the fuse is blowing when you press the brake then that suggests that the wires is shorting to ground somewhere between the brake light switch and the tail light. For example it could be that the wire from the front brake light is disconnected and touching something that is earthed.
matty8887
PostPosted: 14:01 - 10 May 2005    Post subject: Reply with quote
the brake light has 2 wires and a 3rd which is the earth wire so if the earth was in the wrong position this would cause it to short.
That is why the earth has to be in the correct position so i need to know where to put it.
I appreciate all your help kickstart, cheers
Method
PostPosted: 14:03 - 10 May 2005    Post subject: Reply with quote
Take photo's next time mate, what ever you do for the first time, take photos and then annotate them. Sounds lame but it certainly helps you out later.
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
PostPosted: 14:40 - 10 May 2005    Post subject: Reply with quote
Ah, right. It is the brake light at the bulb that you have disconnected. I will check for you tonight if nobody else lets you know first. However with a multimeter take the bulb out and check for a circuit between each of the contacts and the metal contact in the bulb holder (where it pushes on the side of the bulb). This one will be the earth.
matty8887
PostPosted: 19:17 - 10 May 2005    Post subject: Reply with quote
Right i have done it, just looked at the very last page in the manual and it had the wiring diagram and i just used the codes to convert it to the colours.
Its now working great, thanks all and cheers kev for that Thumbs Up
The last post was made 21 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 58.12 Kb
