Obscure tool boffin help needed
Zoffo
PostPosted: 19:40 - 14 May 2005    Post subject: Obscure tool boffin help needed Reply with quote
Seen a couple of these type of questions answered on here in the past so thought I'd post this here
https://ixxra.co.uk/ipw-web/bulletin/bb/viewtopic.php?p=70193#70193
https://hyperbikes.forumsplace.com/
tatters
Exxon Valdez
PostPosted: 19:46 - 14 May 2005    Post subject: Reply with quote
its for removing molen soilder, plastic nose is replaceable
mchaggis
PostPosted: 19:49 - 14 May 2005    Post subject: Reply with quote
A 'desoldering tool'. The solder will set pretty quickly, then when you push the plunger, the metal rod will push the bit of solder out of the nozzle.
https://store1.yimg.com/I/abccables-store_1841_371625872
I must not be a troll...
Mmmm, Guinness
Zoffo
PostPosted: 19:54 - 14 May 2005    Post subject: Reply with quote
Thanks guys. Fookin quick as well Thumbs Up
PostPosted: 20:40 - 14 May 2005    Post subject: Reply with quote
You can get a coil of 'wick' that does a similar job and will remove a lot more solder. Those sucker things are really meant for desoldering the tiny blobs on printed circuit boards to remove and replace a defective componant.
If you think about it, you use a piece of sponge to remove excess solder directly off the end of your hot soldering iron and printed circuit boards are made of plastic, melting is not that much of an issue with electronic solder. Plumbing solder can stay motlen for a longer period and might cause problems.
White Noise
Mr Dudwee
PostPosted: 20:47 - 14 May 2005    Post subject: Reply with quote
As stinkwheel says though its called desoldering braid, i find it easier than the sucker, you just melt the solder and the braid attracts the molton solder
https://shop.store.yahoo.com/tmt/prodsol.html
WN
Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight
The last post was made 21 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 49.41 Kb
