 Zoffo Brolly Dolly
 tatters Exxon Valdez
 Posted: 19:46 - 14 May 2005 Post subject: |
its for removing molen soilder, plastic nose is replaceable ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
 mchaggis World Chat Champion
 Posted: 19:49 - 14 May 2005 Post subject: |
A 'desoldering tool'. The solder will set pretty quickly, then when you push the plunger, the metal rod will push the bit of solder out of the nozzle.
https://store1.yimg.com/I/abccables-store_1841_371625872 ____________________ I must not be a troll...
Mmmm, Guinness
 Zoffo Brolly Dolly
 Posted: 20:40 - 14 May 2005 Post subject: |
You can get a coil of 'wick' that does a similar job and will remove a lot more solder. Those sucker things are really meant for desoldering the tiny blobs on printed circuit boards to remove and replace a defective componant.
If you think about it, you use a piece of sponge to remove excess solder directly off the end of your hot soldering iron and printed circuit boards are made of plastic, melting is not that much of an issue with electronic solder. Plumbing solder can stay motlen for a longer period and might cause problems. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 White Noise Mr Dudwee
 Posted: 20:47 - 14 May 2005 Post subject: |
As stinkwheel says though its called desoldering braid, i find it easier than the sucker, you just melt the solder and the braid attracts the molton solder
https://shop.store.yahoo.com/tmt/prodsol.html
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
