ZL 1000
levi_t1
PostPosted: 00:43 - 21 May 2005    Post subject: ZL 1000 Reply with quote
Can someone tell me where the oil level should be on the ZL 1000 when it is up-right and running? Looking through the site window?
Hello to all
BlackSheep
PostPosted: 00:48 - 21 May 2005    Post subject: Reply with quote
well i havent got a kwak but on most bikes the oil level should be between the two little lines next to the sight glass upright on a level surface a couple of mins after the bike has been running
prefably nearer to the top line
if the bike is running the window will look empty , check it a couple of mins after you switch your engine off
GSXR 1100 StreetFighter
White Noise
Mr Dudwee
PostPosted: 00:50 - 21 May 2005    Post subject: Reply with quote
went the engine is running the oil will be all over the place! so you won't be able to get a level at all, turn the engine off, leave it for a while for the oil to drain to the bottom of the sump, them making sure the bike is level and upright, the oil level should be between the min and max level lines in the sight glass, if it doesn't have those lines buggered if i know. Rolling Eyes
WN
levi_t1
PostPosted: 00:55 - 21 May 2005    Post subject: Thanks Reply with quote
I have a 1976 Kaw 900 LTD and that is the way it is ,oil level lines, on that bike. But whats throw-in me is that there is no oil lines on the ZL 1000. so I'm thinking its in the middle of the site window
Hello to all
ZRX61
Victor Meldrew
PostPosted: 01:42 - 21 May 2005    Post subject: Reply with quote
About 3mm from the top of the window... not the middle...
levi_t1
PostPosted: 02:05 - 21 May 2005    Post subject: oil level Reply with quote
3mm from the top........Running? and upright? or on the kickstand and not running?
Hello to all
ZRX61
Victor Meldrew
PostPosted: 02:50 - 21 May 2005    Post subject: Reply with quote
As stated by others: upright, NOT running, if the engine was running you wouldn't see any oil...
The last post was made 21 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 48.84 Kb
