CBR600 owners!!!
The#Doctor#
PostPosted: 11:30 - 23 May 2005    Post subject: CBR600 owners!!! Reply with quote
I have just derestricted my bike (fy model btw) and have noticed a vibration at about 6000rpm which wasn't thre before is this normal if not what could it be and how do i fix it??
Thanks
Bendy
Mrs Sensible
PostPosted: 11:38 - 23 May 2005    Post subject: Reply with quote
I've never noticed a vibration.
cbrbiker
PostPosted: 12:25 - 23 May 2005    Post subject: Reply with quote
Doc, not encountered this myself, but a) I haven't had a restrictor fitted and b) I've got a 600RR anyway.
However, certainly worth asking the chaps on www.cbr-forum.org.uk as there are certainly some there who know their stuff.
My Bikepics page
www.trackdaypix.com
Claud 14.7 to 1
PostPosted: 12:32 - 23 May 2005    Post subject: Reply with quote
Check bar-ends, foot hangers etc. If something like that is bolted on loosely it can make a difference.
Vibes shake them loose over time. My RHS foot hanger was almost falling off before it noticed it. Shocked
It's an easy starting point. Thumbs Up
kaillum
PostPosted: 12:59 - 23 May 2005    Post subject: Reply with quote
if you mean more of a hesitation rather than a vibration..
had the same on mine, the bike kinda stutters between 5 & 6k.. apparently its down to an enviromental dip thats there to get round some EU emissions ruling or something...
on the later fuel injected ones, apparently its built into the mappings of the FI.. on the earlier ones its a restriction in the exhaust.. mines the last of the carb'd models, therefore replacing the end can solved it..
PostPosted: 15:14 - 23 May 2005    Post subject: Reply with quote
Flat spots at half peak power are a common bodge to help bikes get through the drive by noise tests, and are also a common result of the way bikes are tuned to produce power over a certain rev range.
However, if it is vibration I would suggest you balance the carbs first. And double check the airbox is properly in place.
The last post was made 21 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 48.08 Kb
