| jimster |
 jimster Spanner Monkey
| lap_time |
 lap_time Renault 5 Driver
 Posted: 12:27 - 06 Jun 2005 Post subject: |
To pass your test you have to do lifesavers EVERYWHERE!
Not sure about the first one - sorry, but on roundabouts you have to do a left lifesaver when entering it (no matter where you're going, as you have to move to the left to get onto a roundabout).
As for the others - double check with him. He's there to be questioned if you don't understand. Make him explain the why's as well - if you don't understand why you're doing a certain action then you will forget to do it. ____________________ One post Gordons - just here to sell. |
| T.C |
 T.C World Chat Champion
 Posted: 12:50 - 06 Jun 2005 Post subject: |
A lifesaver is always the very last thing you do before you commit to the turn whether it be at a junction or roundabout.
In Reading, every lifesaver you miss is marked down (bear in mind you can only drop 15 minors), but if there is a persistent failure to do lifesavers it will be deemed a dangerous fault and therefore marked as a failure.
The key is to get the balance right. Too many and you will fail, too few and you will also fail.
So, whether it me a junction or a roundabout, the key is
Observation, signal, manoeuvre, LIFESAVER, and then once the junction has been negotiated, get your position, cancel your signal and observation.
Always start and finish with an observation, the middle lifesaver does exactly what it says on the tin, so that middle one before you commit is all important.
Sorry to say your instructor was wrong, and I know Ian the Oxford examiner very well, and he will fail you if you do it as your instructor states. ____________________ It is better to arrive 30 seconds late in this world, than 30 years early in the next |
| jimster |
| map |
 map Mr Calendar
| Gazdaman |
 Gazdaman I did a trackday!!!
| simonthepiema... |
 simonthepiema... Renault 5 Driver
| DM |
 DM Scooby Slapper
| Chr!S |
 Chr!S Nitrous Nuisance
| BigBoss |
 BigBoss Nova Slayer
| fuzz |
 fuzz World Chat Champion
 Posted: 13:35 - 07 Jun 2005 Post subject: |
If you're positioned on the left in the leftmost lane, you do not need to do a lifesaver before you turn, a mirror check is fine. You do have to do a right lifesaver though everytime you turn right.
Do not position yourself on the white centre line when turning right. No part of your motorbike should cross over the line. I received 2 minors for having the mirrors over the line. If the wheels had been on or over the line it would have been 3 minors in that section and test fail. ____________________ https://www.bikepics.com/members/fuzzbcf/
| jimster |
| T.C |
 Posted: 19:38 - 07 Jun 2005 Post subject: |
Despite what a lot of people have said, it is quite clear and simple, an observation at the start and finish of each manoeuvre, a lifesaver before you commit, left shoulder for a left turn or pre 12 O' clock right shoulder for all other circumstances.
If you look over your shoulder as you go through the turn the bike will follow your line of eyesight and this can result in you drifting, particularly on roundabouts, but a quick scan into the junction as you approach is fine.
If you get your timing right, it will avoid you getting into Nodding dog syndrome which is also a failure as you are obviously doing too many, and if you are doing too many the examiner will form the opinion that your observations are not effective.
But, what do I know and by all means listen to the others, after all I have only trained about 1,000 people to get through their test with a 97% pass rate  ____________________ It is better to arrive 30 seconds late in this world, than 30 years early in the next |
| jimster |
| fuzz |
 Posted: 00:43 - 08 Jun 2005 Post subject: |
You wont fail a test by doing too many lifesavers (unless you do them constantly maybe) but you only need to do them when they are necessary. If you're unsure if they are necessary in a particular situation, ask yourself why you are doing them.
Changing lane - you are moving across your blind spot and so you need to check. Turning right - there could be someone filtering down the middle. Turning left - if you're positioned corrrectly, no-one can be in your blind spot so a mirror check is all that is needed. If you do a lifesaver here you wont fail your test, but you wont fail either if you dont check either. Pulling away from the kerb - you need a very good check here as you are stationary, so turn right around and look back as far as you can.
The examiner wants to see that you know when to use them, and not just because you've been told you should check when changing position.
With roundabouts, you should not change position in your lane, no matter where you are exiting. On the approach to the roundabout, check over the shoulder/s the danger is in (right if you're in the left lane, both when in the middle etc). After you pass the exit before yours, do a left check and signal, then a quick right check just before you exit.
The other times you should do a lifesaver is when a dual carriageway becomes one lane: Look in advance over your shoulder down the other lane. When speeding up you should check to make sure no-one is overtaking you, and when braking to assess the traffic behind you (although a good mirror check can be substituted.) ____________________ https://www.bikepics.com/members/fuzzbcf/
| Biker-Kev |
 Biker-Kev Brolly Dolly
 Posted: 01:38 - 08 Jun 2005 Post subject: |
Why do you think lifesavers are called lifesavers??
possibly because they can save your life??
I think it would be stupid to do as your instructor says, but I am no expert, just a CBT rider with common sence.
Kev ____________________ Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license |
| TheShaggyDA |
 TheShaggyDA Repost Police
| T.C |
| paulodd |
 paulodd Crazy Courier
 Posted: 23:00 - 11 Jun 2005 Post subject: |
Hummm im not too sure what is classed as 'right'. At the end of the day once you have a passed you do what you want when you want. You decide and know when it is best for you to do a life saver and when not to.
I do agree with lap_time tho, do them anywhere and everywhere. Constantly check your mirrors, then they can't say that you didn't do one. Be extra safe than not safe.  ____________________ Paul
1999 Yamaha R6
www.coventrybikers.co.uk / www.norfolkriders.co.uk |
| Liono |
 Liono Spanner Monkey
| Jay1000RR |
 Jay1000RR Trackday Trickster
 Posted: 09:31 - 12 Jun 2005 Post subject: |
If in doubt, do a life saver IMO  ____________________ SUBMARINERS DO IT DEEPER |
| jimster |
| 0ni |
 0ni World Chat Champion
| tonyyzf |
 tonyyzf Brolly Dolly
 Posted: 22:24 - 12 Jun 2005 Post subject: |
Just thought I'd add a wee bit to this post, I realise that you now know that your first instructor was seriously wrong in what he said.
When I was a CBT instructor a few years back I had one girl who wouldn't look over her shoulder before turning, I had to keep telling her over the radio to 'look over your shoulder'
We were coming down a hill in a local town one afternoon about to turn left off the road we were on into a side street, I was about 50 metres behind her when this teenage lad on a bicycle came hurtling past me on the pavement, I could see that he had no intention of stopping and hadn't noticed her indicator, he was riding down the pavement, jumping the kerbs and back up on the other side. I shouted at her to look over her left shoulder which thankfully she did, noticed him and realised that she shouldn't turn. If she had turned into that street without looking she would have had a pillion, pushbike an' all.
Somehow it cured her 'problem' and she went on to pass her test.
You should always look before changing position on the road or making any turn, you don't know where the danger is coming from, you are the only person who has full control of your safety.
DON'T ASSUME FOR ONE MINUTE THAT ANYONE ELSE ACTUALLY CARES ABOUT YOU! |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 04:38 - 13 Jun 2005 Post subject: |
| tonyyzf wrote: | DON'T ASSUME FOR ONE MINUTE THAT ANYONE ELSE ACTUALLY CARES ABOUT YOU! |
Most of them care enough about their insurance premium or that you don't make a mess of their nice shiney car that they will treat you with something slightly above absolute hatred though, maybe more like just whole-hearted contempt instead.
The which annoyed me today was the one which slammed on the brakes in front of me when I mistakenly crept forwards at a roundabout. They'd just left the exit to my right as I was leaving mine, the problem being I was being a bit slow about it. I saw them coming when I'd moved less than 2 feet, so stopped. Instead of carrying on around, they came to a sharp halt right across me, sat there and beeped at me.
Everyone one of the people in the car just sat there and glared at me as if they couldn't believe what I'd just done, which was move literally about 2 feet before getting on the brakes, before they'd actually got anywhere near me.
Because I'd used the front brake, the dive on the forks made it look much worse than it was. My only complaint, as it was clearly my fault, was that they just stomped on the brakes and stopped right in front of me, as though they were expecting me to do something. I nodded at the driver, he scowled back, looked suitably offended and eventually pissed off. I fully expected them to start gesticulating obscenities at me, which would have been quite amusing.
Oh well, live and learn. Everyone makes an occasional mistake, it's how people react to them that matters. Don't great big red and white sails attract people's attention? Evidently not universally.
(People pull out slightly and stop when they see me all the time, even wiggling about on the road doesn't help a lot of the time, it's hardly as if I'm going to do a stoppy in front of them and beep at them as though they don't know I'm there.) ____________________ I must not be a troll...
Mmmm, Guinness
The last post was made 21 years, 91 days ago. Instead of replying here, would creating a new thread be more useful? |
