Cleaning power valve, how?
steve8137
PostPosted: 19:37 - 07 Jun 2005    Post subject: Cleaning power valve, how? Reply with quote
Sorry, it's probably obvious and easy, but i have an Aprilia RS 125 and i have just taken everything out (bettery etc) so i can finally get to my power valve to clean it. That's where i got stuck. I have no idea how, lol. Also how am i supposed to disconnect the actual valve from the bike?
Cheers!!
Dom_
Points Mean Prizes
PostPosted: 19:42 - 07 Jun 2005    Post subject: Reply with quote
Oven cleaner. Thumbs Up
steve8137
PostPosted: 19:45 - 07 Jun 2005    Post subject: Reply with quote
and how do i do it, use a cloth or what?
cheers
dransy
PostPosted: 19:49 - 07 Jun 2005    Post subject: Reply with quote
i rubbed mine really hard with a cloth then filed it but only slightly so it was like new
some of that green stuff u can use when washing dishes wud do it scowerer i think there called
steve8137
PostPosted: 19:51 - 07 Jun 2005    Post subject: Reply with quote
Ok cheers, but i cant clean it yet, i still have the bit inside it and dont know how to get it out? lol any ideas ?
dransy
PostPosted: 19:54 - 07 Jun 2005    Post subject: Reply with quote
after uve took out the bolts that hold it in u shud just b able to slide it out if not give it a bit of a wiggle?
unless its seized up?
ash t
PostPosted: 19:58 - 07 Jun 2005    Post subject: Reply with quote
When i did mine ages ago, it wouldnt come out at first, so i just went for a ride and let it warm up. After this, it came out with a bit of a wiggle.
just use oven cleaner and a cloth to clean it, and WD40 it up, and clean the hole, making sure nothing gets in there...
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
steve8137
PostPosted: 20:28 - 07 Jun 2005    Post subject: Reply with quote
Hoorah!!! I got it out, now which bit am supposed to clean (although its not looking that dirty) could someone please tell me step by step, thanks
ash t
PostPosted: 20:30 - 07 Jun 2005    Post subject: Reply with quote
Just get off any bits of carbon (black hard stuff). the blade should be smooth and a golden/bronze colour.
Before you put it back in, coat it in WD40 or maybe a bit of 2t oil to keep it in good health for abit longer Thumbs Up
dransy
PostPosted: 20:32 - 07 Jun 2005    Post subject: Reply with quote
also u may want to clean the hole that it goes in Thumbs Up
steve8137
Thanks mate SmileSmile
steve8137
PostPosted: 21:19 - 07 Jun 2005    Post subject: Reply with quote
havent cleaned that bit, how hard is it to take and and put back in?
dransy
PostPosted: 21:22 - 07 Jun 2005    Post subject: Reply with quote
not hard at all its simple
ash t
PostPosted: 21:23 - 07 Jun 2005    Post subject: Reply with quote
thats the bit u need to clean. its just above the exhaust port on the side of the cylinder.undo the screws on the housing, and disconnect the cable (clips into the underside of the shaft). then wiggle out the blade.
https://www.125ccsportsbikes.com/forums//index.php?act=Attach&type=post&id=53289
https://www.125ccsportsbikes.com/forums//index.php?act=Attach&type=post&id=53290
hope these help
steve8137
PostPosted: 21:24 - 07 Jun 2005    Post subject: Reply with quote
ash t
PostPosted: 21:28 - 07 Jun 2005    Post subject: Reply with quote
https://www.125ccsportsbikes.com/forums/uploads//post-9-1111237193.jpg
https://www.125ccsportsbikes.com/forums/uploads//post-9-1111237230.jpg
these will help you for when you put the blade back in.
make sure the "sloped edge" is facing down, not up Thumbs Up
dransy
PostPosted: 21:31 - 07 Jun 2005    Post subject: Reply with quote
i was lookin for them diagrams but site i got em from wont let me on says im forbidden lol
steve8137
PostPosted: 21:38 - 07 Jun 2005    Post subject: Reply with quote
how do i get the god dam cable out? sorry im being such a dumbass but thanks for all your help
ash t
PostPosted: 21:39 - 07 Jun 2005    Post subject: Reply with quote
look at the last pic i posted. u see the sort of hole on the left? thats where the cable is. it just pulls out. no tools needed.
steve8137
PostPosted: 21:47 - 07 Jun 2005    Post subject: Reply with quote
this cable si not fuckong moving Sad
steve8137
PostPosted: 22:01 - 07 Jun 2005    Post subject: Reply with quote
Im starting to wish i had never started it now Sad
dransy
PostPosted: 22:05 - 07 Jun 2005    Post subject: Reply with quote
lift it up through that rectangle hole
steve8137
PostPosted: 22:13 - 07 Jun 2005    Post subject: Reply with quote
i think i know what the problem is, just dont know how to sort it. basically if you look in the pic with the numbers, the silver bit just to the right hand side of number 4 is in the slot just on the left of number 4, and it wont move out, i cant seem to pull it out at all.
steve8137
PostPosted: 22:15 - 07 Jun 2005    Post subject: Reply with quote
ash t
PostPosted: 22:17 - 07 Jun 2005    Post subject: Reply with quote
must be stuck shut...disconnect the cable at the top end to slacken it off at the bottom
The last post was made 21 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 124.42 Kb
