race sequence shifting
v4forlife
PostPosted: 09:53 - 08 Jun 2005    Post subject: race sequence shifting Reply with quote
ok, i was wondering about this quite alot lately, watching the bsb and moto gp, and wonderd if it could be done without a new set of rearsets. so i jump on to 400gb and low and behold, there is a thread about it Shocked spooky or what!!
but anyway, i find that its very easy to do on the nc, just undo a bolt, whack the link thing 180 and put it back on:)
i love it. i took to it like a duck on water with lots of swimming badges in lenghts.
it just feels more natural, dunno why tho.
anyone else ridden a race sequence before??
www.wilcollinsphoto.co.uk
Method
PostPosted: 10:26 - 08 Jun 2005    Post subject: Reply with quote
Sorry for sounding like a noob, but whats a race sequence?
Is it like a different size / shape lever making it easier to connect with or a shorter length for travel so its just a quick little tap and its up? or is it something a bit more technical or Confused Embarassed
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
numark1
Scared of girls
PostPosted: 10:28 - 08 Jun 2005    Post subject: Reply with quote
It's funny letting people ride your bike when its like that. Just be careful not to accidently change down a gear instead of up when going for it. Thumbs Up
Method
PostPosted: 10:29 - 08 Jun 2005    Post subject: Reply with quote
Oh so its a reverse system? Down for up and up for down?
numark1
Scared of girls
It means the gear are the other way round on the lever i.e one up 5 down istead of one down 5 up.
Method
PostPosted: 10:35 - 08 Jun 2005    Post subject: Reply with quote
Ok i get you now! Laughing Cheers Thumbs Up
Personally i would find that pretty awquard, i had a grasstrack bike that had that type of gear system, and it was very confusing. Out of habbit i would be kicking up, only to find me almost over the bars due to engine braking Laughing
Suzuki
Roger
PostPosted: 11:00 - 08 Jun 2005    Post subject: Reply with quote
The reasoning behind it is that when you're in a tight left turn, you can still change up through the gears, without needing your foot under the lever (which would prevent you leaning the bike over so far).
TBH, you're never going to need this on the road. Unless you're a lunatic.
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
Jrod
Page 3 Girl
PostPosted: 11:07 - 08 Jun 2005    Post subject: Reply with quote
I'll just be off to change mine now then. Mr. Green Laughing
phill.c
PostPosted: 11:13 - 08 Jun 2005    Post subject: Reply with quote
never heard of this before. sounds interesting and wouldn't mind givin it a try. can it be done on any bike?
CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed Smile
Will87
PostPosted: 11:34 - 08 Jun 2005    Post subject: Reply with quote
Does sound interesting, changing shift patterns is easy tho, for the first few rides you just got to remember how the gears work, i ride a bike for normal gears, then wrong foot and unside down then wrong side and hand gear change!
Suzuki
Roger
PostPosted: 11:55 - 08 Jun 2005    Post subject: Reply with quote
Translation? Confused Thinking
Will87
PostPosted: 11:58 - 08 Jun 2005    Post subject: Reply with quote
Three bikes:
Old Honda - What you would consider a normal gear box, left hand side, 1 down 4 up.
Norton ES2- Right hand side, 1 up 3 down.
BSA Roundtank- Right hand side hand change.
Zero-G
PostPosted: 12:25 - 08 Jun 2005    Post subject: Reply with quote
I used to want to do it on the NSR. Seemed more natural to press down to go up a gear and pull it up to go down one. Confused
Infact I think I did do it once or twice Embarassed
When A Man Loves A Chicken
hawkeye
PostPosted: 12:39 - 08 Jun 2005    Post subject: Reply with quote
I've done it, but then took a pillion and forgot... interesting Rolling Eyes You can only do it on bikes with a shift arm type linkage ie where a linkage arm is mounted to the footpeg and the gearbox. If you have a lever coming towards the peg, but not actually connecting with it, then you can't do it. That doesn't make sense, but nevermind Razz
Might change mine for the Nurburgring...
'89 R/W/B NC30
'The car in front is... in my way'
v4forlife
PostPosted: 13:49 - 08 Jun 2005    Post subject: Reply with quote
well in the long run, im gonna make my nc into a just barely road legal track bike, and its useful for the track.
and on the nc, its so easy, that i can change it back if i feel the need. only takes like 10 mins, so no problem there
PostPosted: 13:58 - 08 Jun 2005    Post subject: Reply with quote
I doubt it to be honest.
It's useful if you're a very, very fast racer or are already used to bikes that have it as standard.
Otherwise I suspect it will get in the way.
A couple of times I have had a bike nocked down a gear on track - with a big rear end slide the results.
Doing it at redline while leant over could get very nasty and the resulting injuries and damge to the bike would make you slower on track in the long run I suspect.
Also will cause problems when you get on someone elses bike I suspect.
Andy99
PostPosted: 15:44 - 08 Jun 2005    Post subject: Reply with quote
I had a 350LC which had down for up and up for down gear sequence it was fine to start with when i was thinking about it or out for fast rides. However it soon became a right pain as i'd forget, go to change down usually in traffic and end up red lining the poor thing.
Besides not all racers use this even at the top level of racing,the only time it helps is changing up when leant over. How many people here on trackdays have ever wished for a reversed sequence i certainly haven't,so whats the point?
Nothing gets the point across quite like a raised middle digit.
Just call me General Crazypaws.
v4forlife
PostPosted: 17:02 - 08 Jun 2005    Post subject: Reply with quote
well screw you guys, i prefer it.
besides its cool to say you have it done:)
duno, i red that it was easy so i thought i would try, and took to it really easy, and it only takes like 10 mins to do on the nc, so if i get in trouble and do normal shifting, then ill think that in those situations i would do the same, so ill just change it back
i do need some rear sets though, as i almost ablitirated my hero blob on the right side Embarassed Laughing
taken both sides off now
and i need leathers
EuropeanNC30R...
Gay Hairdresser
PostPosted: 17:09 - 08 Jun 2005    Post subject: Reply with quote
Hero blob on my rhs snapped off the first time it touched down!
lap_time
PostPosted: 17:19 - 08 Jun 2005    Post subject: Reply with quote
Oh come off it! I have difficulty enough trying to remember which way I'm supposed to be going - let alone having an upsidey-downy thingy! Very Happy
One post Gordons - just here to sell.
PostPosted: 18:43 - 08 Jun 2005    Post subject: Reply with quote
Erm, I believe people were giving you advice to try and prevent you breaking your bike and yourself Neutral.
As people get annoyed with me pointing out, just because you think it's cool, don't expect others to Very Happy.
pipnet11
PostPosted: 19:40 - 08 Jun 2005    Post subject: Reply with quote
British bikes were all doing it that way round 60+ years ago.....
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
v4forlife
PostPosted: 11:07 - 09 Jun 2005    Post subject: Reply with quote
Erm, I believe people were giving you advice to try and prevent you breaking your bike and yourself .
lol, i know, i was just messing. if anything bad happens like a go the wrong way in a shit ya self moment or at high speeds, then ill change it straight back. im carrying the tools to change it if im out with me anywhoo:)
The last post was made 21 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 121.1 Kb
