| THCi |
 THCi Nearly there...
| stinkwheel |
 Posted: 03:00 - 12 Jun 2005 Post subject: |
I presume it is for a 125?
Why not do it yourself. Sounds like you already have the bare rim and the tyre yeah? The hard bit is getting the old tyre off, the new one should waltz-on with little effort.
You should be able to 'walk' the tyre on with plenty of soapy water. Just position the tyre ove the rim, soap-up the bead and push one edge down over the rim. Push the bead down into the recess in the middle of the wheel then start pushing the tyre all the way onto the rim working one side then the other. A lot of 125 tyres will push-on by hand, if not, stand on the bead with one foot either side and gradually push the bead over the rim with your weight. You might need a tyre lever to get the last couple of inches over.
If it is a tubed tyre, put the partially inflated tube in now then walk the other bead down in the same way. If it is tubeless, just put the other bead on.
Now inflate the tyre with the valve core removed to seat the beads on the rim, you will hear them 'bang' as this happens (you sometimes have to take a tubeless tyre up to maybe 80psi or so).
The things to remember are:
Use plenty of slippy stuff (such as soapy water) to allow the bead to slip over the rim.
Push the part of the bead that is already 'fitted' down into the middle of the wheel to give yourself more space for fitting the rest of it.
If you use a tyre-iron, be careful not to pinch the tube with it (if fitted).
The last tyre I fitted to a 125, I managed to push it down over the rim by hand. Even the 160 section tyre on my supermoto went on with little effort (took an hour to get the old one off though) ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| THCi |
| THCi |
 Posted: 00:59 - 13 Jun 2005 Post subject: |
Taking it to a local place to get it done, Black Country Motorcycle Training. They're brilliant, really are, local Black country blokes (read: Black Countray blókes ).
Shouldnt cost me much either.  ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die." |
| HurtMePlease |
 HurtMePlease Trackday Trickster
 Posted: 01:40 - 13 Jun 2005 Post subject: |
I know that place, be careful they dont charge you an arm and a leg im not sure what thier like when it comes to fixing bikes but they also give das lessons and they will rob you/mess you around badly as they did with me
check this thread
https://www.bikechatforums.com/viewtopic.php?p=477540&highlight=#477540 ____________________ Hear Thy Call..............................
Rs125 (97) <-Sold|Riding->ZXR400L2(92) Yamaha R6(01) |
| THCi |
| HurtMePlease |
 Posted: 13:06 - 13 Jun 2005 Post subject: |
Dudley mate
I use a couple of people when it comes to repair work though
look up "Kens Motorcycles" in Dudley hes reasonable most of the time! also use a fella called Bruce Cribb "cribby tuning" in Smethwick Though he ripped me off a little when I needed a new front tyre. If you want really good service with quality mechanics I'd go with "All Bike Spares" in Wolverhampton they arent really a small establishment compared to the others
| THCi |
 Posted: 13:50 - 13 Jun 2005 Post subject: |
Where abouts in said bourough?
I live on the Foxyards estate, next to the newish foxes hollow build. And, NOT, on the council estate side of it either!  ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
| THCi |
| map |
 map Mr Calendar
 Posted: 15:20 - 13 Jun 2005 Post subject: |
| THCi |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 00:09 - 14 Jun 2005 Post subject: |
Won't you need your own compressor to inflate it quickly enough to get the beads to pop on properly? That is if you don't do it with a can of lighter fuel or something. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| stinkwheel |
| THCi |
 Posted: 11:51 - 14 Jun 2005 Post subject: |
Cant use pertrol station air pumps to do mine, the hub on the wheel is quite large, so I cant get the metal bit of the hose into the space between the rim and the hub.
Never mind though, its done now  ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
| map |
 map Mr Calendar
| THCi |
The last post was made 21 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
