Clutch Slip
Liono
PostPosted: 21:13 - 13 Jun 2005    Post subject: Clutch Slip Reply with quote
Probably a bit of a daft question, but what exactly is clutch slip? Not as in slipping the clutch when moving slowly, but as in "I was accelerating away and the clutch started to slip"?
Villers
PostPosted: 21:15 - 13 Jun 2005    Post subject: Reply with quote
My RS125 needed new clutch plates when I got it, it would slip under accelleration. You would feel the bike begin to lose steam but the revs would start going ape shit and then if they bit the bike would surge a bit! HTH.
tatters
Exxon Valdez
PostPosted: 21:27 - 13 Jun 2005    Post subject: Reply with quote
caused by:
worn clutch plates
ill adjusted clutch cable
fully synfectic engine oil (can happen on some bikes, or on bike using replacement EBC clutch plates)
a clutch kit is about £40 which would include 6-7 friction plates and possibly replacement springs (not really needed). changing the plates on most jap bikes is quite easy with a bit of common sense.
pipnet11
Without trying to be cocky, its when your clutch slips. Feels strange when it happens, which on classic bikes is quite often. In gear, open throttle, revs go up but your speed doesnt, or not as much as the engine anyway. Basically its when the clutch can not handle the amount of power/torque that the engine is trying to put through it.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
nick.h
PostPosted: 21:34 - 13 Jun 2005    Post subject: Reply with quote
Is it like when the bike slips out of gear?
Because i think this is what happening to my bike.
It happens every time i go out on it, i'll be riding along, in forth say, and then the revs will go apeshit, ill pull in the clutch, then select the gear and it will be fine again.
It did while i was slowly riding behind a rs125, he thought i wanted to race him Embarassed
Nick
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
Villers
PostPosted: 21:38 - 13 Jun 2005    Post subject: Reply with quote
Could be a possibility mate but it would do it under load in every gear if your clutch was on its way out!
Liono
PostPosted: 21:58 - 13 Jun 2005    Post subject: Reply with quote
This is what made me post this topic actually as I've noticed this happening a couple of times now, usually if I'm accelerating 'enthusiastically'! Thanks for the advice everybody, I know actually know what people mean when they talk about clutch slip now. I'd guessed it was something along these lines, but thought it was worth checking. Thumbs Up
Wave2k
G's Stalker
PostPosted: 22:03 - 13 Jun 2005    Post subject: Reply with quote
my bike is doing it atm
give it a handfull and at 10,000rpm it slips and shoots to the redline
Ducati 1299 Panigale
2009 Corvette C6 z51
White Noise
Mr Dudwee
PostPosted: 22:04 - 13 Jun 2005    Post subject: Reply with quote
mine is doing it, i think! Laughing
newish clutch so i think that the cable needs adjusting!
WN
PostPosted: 22:19 - 13 Jun 2005    Post subject: Reply with quote
As above. Tends to happen more in the high gears, up hill, full throttle, etc.
If it is doing it in a particular gear it tends to suggest something else.
Davo
Davo To The Rescue!
PostPosted: 22:38 - 13 Jun 2005    Post subject: Reply with quote
I found out the clutch was slipping on the busa, when I decided to show some Merc AMG that he couldn't out accelerate a busa, the clutch slipped then bit, producing a rather spectacular wheelie.
One way I test for clutch slipping is to trundle along slowly, put it into third then crack the throttle fully open (be sure to cover the rear brake in case it does the above)
Dom_
Points Mean Prizes
PostPosted: 23:46 - 13 Jun 2005    Post subject: Reply with quote
Mine does it like mad when cold. Confused
Visitor Q
$25 whore
I have a cbr 600 and it doesnt like powerwheelying in first even when you rock the revs (take it to 10k, snap throttle shut then fully open), let alone straight out power delivery.
I should be so lucky to have to worry about flipping it from a 3rd gear rollon Crying or Very sad
Damn litre+ bikes Evil or Very Mad
Davo
Davo To The Rescue!
PostPosted: 23:48 - 13 Jun 2005    Post subject: Reply with quote
Damn litre+ bikes
Nah, what I meant was having the clutch slip and then bite again, gives the same effect as clutching up a wheelie.
Visitor Q
$25 whore
PostPosted: 23:52 - 13 Jun 2005    Post subject: Reply with quote
Damn litre+ bikes
Oooooh... Still... the cbr doesnt clutch up in second let alone third...
Again with hating litre plus bikes. Altho i do recall a certain small wheelbased ktm 250 two stroke that wheelied VERY well in third so perhaps its just lardy 600's
Crying or Very sad
PostPosted: 00:05 - 14 Jun 2005    Post subject: Reply with quote
Nick
Nah, that sounds like your bike is jumping out of gear.
Clutch slip is a bit more subtle and usually starts in top gear, spreading to the lower gears as it gets worse.
I would liken the effect to riding along in top then pulling in the clutch lever ever so slightly, the revs rise but the bike goes no faster. It sounds like engine noise recorded on a casette player that has started to chew up the tape.
mchaggis
PostPosted: 00:28 - 14 Jun 2005    Post subject: Reply with quote
You can get the effect by maladjusting your clutch so it never properly quite engages fully. It's fine until you get to a hill or unless you accelerate vaguely enthusiastically. I could explain it in technical detail if you want, but I can't be arsed. Smile
It's not exactly a hard concept to grasp anyway, mainly just to do with the clamping force and the coefficients of static and dynamic friction. Other factors are the amount of torque you're applying to the clutch, the difference between engine and wheel speeds, the amount of meat left on the plates, and the adjustment mechanism.
Are hydraulic clutches self-adjusting? I'd have thought so. Thinking
I must not be a troll...
Mmmm, Guinness
Suzuki
Roger
PostPosted: 10:51 - 14 Jun 2005    Post subject: Reply with quote
That really depends what bike you've got.
New clutch plates and springs for my gixxer cost about £115.
Then factor in an oil change, oil filter, and new gaskets, and you're looking at about £150.
Click here to see my clutch change...
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
tatters
Exxon Valdez
PostPosted: 11:28 - 14 Jun 2005    Post subject: Reply with quote
think you,ve been had mate
https://www.patternparts.net/stock_refine.asp?model=19&category=12&model_go.x=14&model_go.y=7
Suzuki
Roger
PostPosted: 11:39 - 14 Jun 2005    Post subject: Reply with quote
I had genuine Suzuki parts though, not EBC.
Also, I didn't pay for them, so not overly fussed. Was a birthday present.
Nice link though Thumbs Up
The last post was made 21 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.29 - MySQL Queries: 15 - Page Size: 115.54 Kb
