| Andy C |
 Andy C Tree Seeking Missile
 Posted: 22:14 - 14 Jun 2005 Post subject: Why my day at college was well good and carp at same time!! |
Ok today was my second day on the road with my RS125, i wake up at about 8 have 4/6 lessons free but have to go do photography coursework so ride in and basically i forgot some photos and had to be in today so had to drive back! it 22 miles each way so today i did 88miles, im killing and feel really drained as never done that much!! The CDI restriction really pissed me off aswell but was easier to ride today, however i have just taken my bike apart and derestrcted the CDI and hope it works!! i going to get bus in tomorrow as today took a lot of my petrol money!!
The point is it was really cool driving today when all my friends in lessons (well most werent) but sucks as not used to that much driving and aching from it! well guess it will help in the long run! ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
| White Noise |
 White Noise Mr Dudwee
 Posted: 22:17 - 14 Jun 2005 Post subject: |
doesn't sound that carp
sucks about the lack of petrol money!
what MPG are you finding it to be?
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| Andy C |
 Posted: 22:20 - 14 Jun 2005 Post subject: |
thats the thing i have no idea, i fueled up twice today but dont know how much its got left, i put it £9ish of 98 and be running it in so revs were quite low, on my ped £9 was x2 the journey so was think this would be simular to RS? any idea on how to check? i tryed shaking it but have no clue what it sounds like full and empty so a bit clueless!lol, had it on reserve after 2 out of the 4 length on journey and fill up at start of 3/4, if that make sence!
any idea how to check how much is left WN? ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
| Shaun |
 Shaun Likes 'em bent
| White Noise |
| Andy C |
 Posted: 22:31 - 14 Jun 2005 Post subject: |
cool yea i think that its quite low now!lol, i got the CDI out drying as filled the opening with silicone sealent as derestrected it and too tired to go put it back in, bike looks somwhat different!! well a little bit anyway!i have a photo actully... ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
 Posted: 22:45 - 14 Jun 2005 Post subject: |
I am not so sure that using silicone sealant in contact with wiring is such a good idea. Silicone sealant is usually made up with ethanoic acid (vinegar) which would corrode wiring and electrical connections
Did the stuff you used smell of vinegar?
Epoxy resin would be better for that kind of job. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Andy C |
 Posted: 23:01 - 14 Jun 2005 Post subject: |
really?!? i used bathroom sealent and it smells of...*snifs* well a little of vinigar but only because im thinking of it now. i dont know but i think i may buy another of ebay as a backup and maybe redo some time, is it a really big problem? ill check the bottle thing tomorrow. ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
 Posted: 23:24 - 14 Jun 2005 Post subject: |
If you used bathroom sealant, it almost certainly has ethanoic acid in it. If you have got the stuff on any bare metal connections or printed circuits it is very likely to corrode them, possibly quite quickly (think what would happen if you left a copper coin in a glass of vinegar overnight).
I would try and get the stuff off if I were you. Not sure how best to do it as the stuff is sticky as hell.
Off the top of my head, I would probably use some paper towel to remove as much as you can then maybe flush it out with a weak solution of bicarbonate of soda (baking soda) to neutralise the acid. Follow this by a flush out with clean water then allow it to dry fully. As long as there is no power going through it until it is dry, water shouldn't damage anything.
I would then seal the hole properly with epoxy.
:EDIT:
| Quote: | Not recommended for bonding to substrates where acetic acid released during cure could react to the surfaces to which the sealant is in contact. (E.g. concrete, cement, mortar, certain metals). | https://www.antel-uk.co.uk/tds/as47.html ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Andy C |
| White Noise |
 Posted: 23:28 - 14 Jun 2005 Post subject: |
epoxy resin, can buy it from most DIY places, homebase, B&Q et al
| ApriliaRs125 |
 ApriliaRs125 Scooby Slapper
 Posted: 06:41 - 15 Jun 2005 Post subject: |
andy your bike looks very clean for 88mile today , i suspect you cleaned it before taking the picture
scott ____________________ *aprilia rs125 2005 UKRS https://www.theukrsclub.com
*peugeot speedfight 100 1999 Aprilia Forum https://www.apriliaforum.com |
| Andy C |
The last post was made 21 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
