dam need a little help
kingsknight
PostPosted: 21:56 - 18 Jun 2005    Post subject: dam need a little help Reply with quote
my starter motor relay has die. all it does is click and does not let out power to the starter motor.
anyone know where i can buy a relay from and if so how much?
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
alains
PostPosted: 02:28 - 19 Jun 2005    Post subject: Reply with quote
https://www.davidsilverspares.co.uk 01728 833 020
ref honda 38501-KG8-004 around £25
Guest
PostPosted: 07:06 - 19 Jun 2005    Post subject: Reply with quote
Clicking starter relay is usually a sign of a low battery
kingsknight
PostPosted: 10:00 - 19 Jun 2005    Post subject: Reply with quote
battery is fine thanks anyway
Robby
Dirty Old Man
PostPosted: 10:32 - 19 Jun 2005    Post subject: Reply with quote
How do you know the battery is fine? A battery can appear to function fine and in fact not have enough power to turn over the engine.
As a basic rule, it takes a lot of current to crank an engine, and very little current to light a headlight.
Try hooking up a known working battery - like a car battery - first.
bish777
PostPosted: 13:57 - 19 Jun 2005    Post subject: Reply with quote
I keep just such a battery to hand for such things.
Also check nothing in the wiring is loose, and that the relay isnt full of water or dirty etc
GSXR1100J
Gazdaman
I did a trackday!!!
PostPosted: 20:36 - 19 Jun 2005    Post subject: Reply with quote
I completely agree with previous posts.
Happened on my mum's XJ900, clicking starter motor was a knackered battery.
Try leaving the headlight on and thumbing the starter, if the headlight dims fairly majorly then it's fairly likely to be a duff battery.
Although obviously that's not a foolproof testing method.
Gaz
kingsknight
PostPosted: 20:49 - 19 Jun 2005    Post subject: Reply with quote
i brought a new battery and there is no power coming out of the relay what so ever
kingsknight
PostPosted: 20:50 - 19 Jun 2005    Post subject: Reply with quote
and the relay clicks even if the starter motor is not connected to the relay
kingsknight
PostPosted: 21:19 - 19 Jun 2005    Post subject: Reply with quote
so i take it a lot of you dont think its my relay which is gone?
bish777
PostPosted: 21:24 - 19 Jun 2005    Post subject: Reply with quote
sounds like faulty wiring. Get your probe out.....
GSXR1100J
kingsknight
PostPosted: 21:35 - 19 Jun 2005    Post subject: Reply with quote
there is power going into the relay but non coming out of the relay surely it has to be the relay?the lights dont even dim when i press the start button.
There are 2 power leading running into the relay and 2 which are connected to the starter motor its self.
i have tested that there is power going into the relay and i tested if there was power coming out of the relay which it is not.
how can the wiring stop the power coming out of the relay????
ZaphodBeeble
PostPosted: 23:12 - 19 Jun 2005    Post subject: Reply with quote
Just to make sure, can you check if there is power getting to the starter motor? Make sure you press the starter button when you check it. Mr. Green
If there IS power getting to the starter then I expect it will be dodgy brushes.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
kingsknight
PostPosted: 23:15 - 19 Jun 2005    Post subject: Reply with quote
when i press the button there is no power going to the starter motor
kingsknight
PostPosted: 19:27 - 20 Jun 2005    Post subject: Reply with quote
ok found out what the problem was. One of my bushes and its spring got crushed by the motor. I used my mates bushes and spring out of his starter motor and it worked fine.
my new question is, i know i can order new bushes but can i order new springs??????????
kingsknight
PostPosted: 08:59 - 21 Jun 2005    Post subject: Reply with quote
bump
Simonbt
PostPosted: 09:09 - 21 Jun 2005    Post subject: Reply with quote
try asking the same place you can get the brushes (not bushes....)
Confused Confused Confused
The last post was made 21 years, 152 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 89.87 Kb
