ARROW EXHAUST
trafficdodger
PostPosted: 21:45 - 19 Jun 2005    Post subject: ARROW EXHAUST Reply with quote
Hi people i have an arrow exhaust on my bike just wanted to know if these are just end pipes or do they go up to the manifold and are they restricted.
Sorry if i sound dumb but i know nothing about bikes.
Thanks
Present bike Yamaha R6
alains
PostPosted: 22:23 - 19 Jun 2005    Post subject: Reply with quote
the silencer does not change anything to the power , it just make the sound !
trafficdodger
PostPosted: 22:31 - 19 Jun 2005    Post subject: Reply with quote
Just had a look at the exhaust again and it is just a slip on end so the chances are it still has a restrictor at the manifold end if the previous owner has not touched it.
Thanks
alains
PostPosted: 23:01 - 19 Jun 2005    Post subject: Reply with quote
no restrictors on arrow exhaust !
Gazdaman
I did a trackday!!!
PostPosted: 14:33 - 21 Jun 2005    Post subject: Reply with quote
alains, if he just has some arrow end cans then the restriction might still be present elsewhere.
Whereas if it's a full arrow system, then there will indeed be no restriction in the exhaust.
Doesn't stop there being an inlet restriction or CDI though. But then I know next to nothing about NSRs. Or whatever bike this is.
Gaz
alains
PostPosted: 15:04 - 21 Jun 2005    Post subject: Reply with quote
yes , indeed , most of the uk models have no rectrictions even on electronics , i am talking about post 1992 models (JC22) . these restrictions are applied on import models except italian . if you look the writting on the CDI , anything different of CI626 have restrictions (advance locked at 10500 RPM) . on rc valves control box any different of TV-78 2.9 have restrictions (70% openning)
exemple in france we have CI639 and TV-124 , restricted
stevo as b4
PostPosted: 19:37 - 21 Jun 2005    Post subject: Reply with quote
Thats interesting to know, so if you had one of the older NSR125 imports, a new pipe, and removing the intake restrictor if fitted, would still not give full power. Ive heard that the NSR125RK models with the round headlights are quite hard to de-restrict, and if they have the restricted CDI and RC control box, then its expensive as well!
trafficdodger
PostPosted: 19:40 - 21 Jun 2005    Post subject: Reply with quote
Mine is a nsr on a xplate (2000) does mine have a restricted CDI unit.
alains
PostPosted: 20:04 - 21 Jun 2005    Post subject: Reply with quote
do not think about RK or something else , think about prior 1993 or after . there was no restrictions on the JC20 except the NSR125F , the restrictions applies in some européan countries after 1993 due to their change of legislation . but english models has not been changed . if you give me your serial number , i can tell you if it's restricted (for exemple mine is ZDCJC22B0WF205348)
B is for france , W is 1998 , 205348 is the frame number
for france the CDI is CI639 , the control box is TV-124 all restricted , the barrel is different and the RC valves system also . recently i have rebuild my top engine (at 15000 miles) and fit all the UK system (barrel+piston+rings+valves+electronics) . as i was before my top RPM was 10800 , now i have reached 12000 and i may tune my valves a bit better .
trafficdodger
PostPosted: 23:37 - 21 Jun 2005    Post subject: Reply with quote
Thanks alot i will get the number when i get the bike back, where will i find the serial number.
Thanks
trafficdodger
PostPosted: 23:48 - 21 Jun 2005    Post subject: Reply with quote
Thanks
alains
PostPosted: 00:17 - 22 Jun 2005    Post subject: Reply with quote
if you've got your bill , it should be written on it . have you the uk a paper which goes with any vehicule ? if yes the id number must be on
trafficdodger
PostPosted: 12:46 - 22 Jun 2005    Post subject: Reply with quote
Ah i found it it's zdcjczzeoxf222576.
alains
PostPosted: 14:03 - 22 Jun 2005    Post subject: Reply with quote
so your bike is a UK one from 1999 , no restrictions on it ! the only thing you can improve is the exhaust . you can either de-restrict it or buy a race one {1) jollymoto 402 carb , 2) gianelli , 3) arrow , in order of value/money} all £220-250 , or de-restrict your genuine . in this case your main jet which is 135 must be replace by 142 with a race exhaust and 138 with a de-restrict exhaust . you must also check if the restrictor plate is still beetween the carb & the reed valves , if yes take it off . replace the fiber reed by carbon reed . fit a sparkplug BR9EIX in cold days & BR10EIX in hot days . see https://www.sparkplugs.co.uk (£6.84 each) , for the jets see https://www.dellorto.co.uk (£2.95 each) , for the carbon reed i do not know a uk site but here i order mine https://www.blue-oil-france.com/default.php?cPath=210 (ref : 360451 about £24 inc VAT)
the site for jollymoto https://www.jollymoto.it , i can get in touch with the boss if you want one . hope this will help
trafficdodger
PostPosted: 14:13 - 22 Jun 2005    Post subject: Reply with quote
Thats brilliant im pretty sure it has an full arrow system on it i will try to have a look at the restrictor plate if it is still there betwwen the carb and reed valves. Btw what are reed valves and are they easy to replace if you dont have a clue about bikes. So i also need a 142 jet for my carb if i have a full arrow system. Are these easy to fit also.
Thanks for all your help
Nige
alains
PostPosted: 14:18 - 22 Jun 2005    Post subject: Reply with quote
pass me a pm with your mail adress , i will give you my mail adress , it will be more convenient to give you pictures and exponations
The last post was made 21 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 87.56 Kb
