Veering To The Right
DukeRed
PostPosted: 18:55 - 21 Jun 2005    Post subject: Veering To The Right Reply with quote
When I take my hands off the bars the bike veers right. I've shifted my weight about and it doesn't make any difference.
The forks twisted in the yokes last crash and I thought I sorted them but could it be that? i.e. front wheel not aligned with handlebars.
Cheers in advance.
Would going up big kurbs at an angle mess up the alignment?
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
Andy C
Tree Seeking Missile
PostPosted: 19:05 - 21 Jun 2005    Post subject: Reply with quote
i had this problem cept to the left, was rite after crash and think its really hard to get completly stright, a place may be able to do this. correct me if i wrong but i think it is the fort stlightly bent
J.K.R
PostPosted: 21:34 - 21 Jun 2005    Post subject: Reply with quote
Yokes might be twisted, needing adjusted back but theyre probably knackered, frame could have a slight twist.
hth Thumbs Up
www.oldskoolsuzuki.info
VFR400UK
PostPosted: 22:19 - 21 Jun 2005    Post subject: Reply with quote
Mine does this to the left also. i doubt front wheel alignment is to blame as without steering input the front wheel should just point atright forwards no matter if the bars or yokes are twisted.
I think rear wheel alightment is to blame with my bike at least.
You can get wheels laser aligned at some bike shops. they check the alignment, but i think they leave it to you to fix.
DukeRed
PostPosted: 00:31 - 22 Jun 2005    Post subject: Reply with quote
Hmm, the forks look straight enough. Realigned the front wheel again, might have been a bit off. I doubt it will make any difference.
Bugger is I angle grinded the centre stand off because it was scrapping the floor so makes it a bit harder to align the rear wheel.
Blueknyt
PostPosted: 08:18 - 22 Jun 2005    Post subject: Reply with quote
use a couple of Jack stands under the engine area, and use the string method for wheel alignment. as to the forks, i had this on my XJ650 maxim, i loosened the top clamps and heastalk nut and let everything resettle then snuged the top clamps just enough that they still let the fork tubes slide alittle and retorqued the headstock and finnished off the clamps. if it didnt change i would spin one fork tube inside the clamps and see what happen, if there was a change, that told me the forks were bent a hair
good luck
The last post was made 21 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 48.59 Kb
